06-22-2008, 10:59 AM
| Got Camber??? |
06-22-2008, 11:09 AM
#2 | | Undercover Moderator
| Re: Got Camber??? Nice goin', Ned!! So, what's the secret? |
06-22-2008, 11:42 AM
| Re: Got Camber??? My tech at the dealership came up with the idea of a wedge-spacer. After 6-7 different size (mm) plates we finally got it done. |
06-22-2008, 06:50 PM
#4 | | ClubxB's OG Member
| Re: Got Camber??? |
06-23-2008, 11:17 AM
#5 | |
| Re: Got Camber??? Looks good Ned, good to see it worked out. Now where's my set?  |
06-23-2008, 02:35 PM
| Re: Got Camber??? Nice,,,was it a custom shim job? or can we all get on board? |
06-23-2008, 08:44 PM
| Re: Got Camber??? Madd, this is a custom spacer shim that we came up with. I got impatient for one to be released so we made our own. I will talk to my tech at the dealership and see if he can mass-produce them.
Here's a side shot of the rear wheels:  |
06-24-2008, 03:02 PM
| Re: Got Camber??? Tks for responding, I too was waiting , talked to Van @ one ton garage a while ago, still no news on gen 2 camber shims, I would def be interested in a set for mine. |
06-24-2008, 10:29 PM
#9 | | Site Sponsor
| Re: Got Camber??? |
06-25-2008, 12:12 AM
#10 | | bB Squad
| Re: Got Camber??? you should mass produce these....mad BANK yo!! |
06-25-2008, 03:16 AM
#11 | | Banned
| Re: Got Camber??? Awsome man!
now ok hows this work?
I look at how the rear is set up..
if you just shim the axle part.. the Caliper will stay the in the stock position..
so if the axle moved 3deg and the Caliper wasnt shimmed.. your brakes wont work right.. or wear right..
How many Deg is teh camber and was the Caliper also shimmed? |
06-26-2008, 03:16 PM
| Re: Got Camber??? Marshall, thanks for the kind words. Both axles and calipers were shimmed and just enough to for the pads to clear the rotors. Next week my tech will start cutting more plates. Price TBD. |
06-26-2008, 09:45 PM
#13 | | CNC DUDE
| Re: Got Camber??? Is toe correction built into the camber shims? Or do the 08's not need it? Curious. |
06-27-2008, 06:32 AM
#14 | | Registered User
| Re: Got Camber??? No. Toe correction is not built-in. The 2G def needs toe correction as the 1G did. |
09-23-2008, 05:03 PM
#15 | | Registered User
| Re: Got Camber??? looks great, wat are you lowered on? |
12-16-2008, 05:03 PM
#16 | | bBsquad reppin
| Re: Got Camber??? I need to see pics of this. someone said it couldnt be done I heard |
12-16-2008, 05:12 PM
#17 | | Haole Grandpa Moderator
| Re: Got Camber??? If anyone can do it you can Dan.
I'm interested to see how the caliper clearance was obtained... |
01-02-2009, 05:28 PM
#18 | | Registered User
Join Date: Dec 2008 Location: corpus christi texas for now
| Re: Got Camber??? Sick camber ......... I tried it figure out something like that ........lol but before I knew it I was to drunk to think |
01-06-2009, 12:17 PM
#19 | | Registered User
| Re: Got Camber??? |
01-20-2009, 03:16 PM
#20 | | Registered User
| Re: Got Camber??? Quote:
Originally Posted by azztinthebox saweeeeeetttttt | x2 very nice. Love the look. |
