Old 04-21-2009, 02:06 PM   #201
xB27's Avatar
xB27 is on a distinguished road
Re: What kind of gas mileage are people getting?
yea i got the OEM 17" gunmetal rims with Pirellei P6 235-45-17 tires and notice a pretty big drop in gas mileage was getting between 27-29 MPG now im getting 23-25 thinking of putting in the TRD coldair intake to improve a little bit
xB27 is offline
Old 04-21-2009, 02:06 PM   #202
Grasschopper's Avatar
Grasschopper is on a distinguished road
Originally Posted by Steve64 View Post
What air pressure & tire size are you running with the 18's?
225/40r18 with the factory suggested 35 psi in the front and 32 psi in the rear.
Grasschopper is offline
Old 04-21-2009, 02:23 PM   #203
seppuku27's Avatar
Originally Posted by Fashstyle View Post
I'm getting 22 MPG and it's pretty consistent. 19" rims with ZR rated tires. Could that be effecting my MPG?
Yes 19 inch rims are going to be heavier than stock 16s unless you got some forged rims and spent a fortune. Not only is it affecting your MPG but its affecting your braking, acceleration, and handling.
seppuku27 is offline
Old 04-21-2009, 02:29 PM   #204
Steve64 is on a distinguished road
The Benefits of Correct Air Pressure - Discount Tire,
paragraph 4.
Fashstyle, depends on the air pressure. A low profile tire, sidewall, distributes weight differently than it's taller counterpart.
Steve64 is offline
Old 04-23-2009, 02:21 AM   #205
mirv's Avatar
mirv is on a distinguished road
I'm getting about 28mpg on my stock 2008
mirv is offline
Old 05-15-2009, 09:17 AM   #206
Well with my tire pressure now a couple PSI higher per a pm I got here I am now getting better gas mileage. Last 3 tanks were: 27.26, 28.5 and yesterday 29.24. I am VERY happy with better than 29 mpg.
Old 05-15-2009, 09:26 PM   #207
Draco_w1 is on a distinguished road
I got 31 at about 75:
Draco_w1 is offline
Old 05-16-2009, 09:43 AM   #208
homerhitta is on a distinguished road
with a combination of highway and city driving i get about 23-24.
i don't think that's too bad though....i used to get 24-25 everywhere though....
homerhitta is offline
Old 05-16-2009, 12:26 PM   #209
it seems that my XB is just starting to break in when i first got it i was getting about 285 mile from a tank about 9 months ago now its at 301 per tank so its going up
Draco_w1 is offline
Old 05-21-2009, 01:07 AM   #210
superd6199 is on a distinguished road
wow......i get 23 at the most! something must be wrong with my 09 6.0 xb! i now have a lil over 1 thousand miles on her and still haven't hit 65 mph on the highway!
superd6199 is offline
Old 05-25-2009, 03:15 PM   #211
Yeah i dont know whats up with your XB have you checked your tire pressure?
When i got my XB i would ocassianaly smell radiator fumes after i got out from the car, i took it back to the dealer twice and they told me they contacted there engineers in L.A and never heard of anything like it, because there is no leaks. they told me it must be the long life radiator fluid that i get a wiff of when i get out of the car, but im not buying this bull can any body help me out?
Draco_w1 is offline
Old 05-26-2009, 10:18 AM   #212
Hummer_Lite is on a distinguished road
The least expensive way I found to improve my mpg was to check my tire pressure. All 4 tires were at different pressures with the lowest at 22psi. I picked up 4.5 mpg (local driving 25-50 mph) by setting all 4 to 35psi. I'm now getting 30.5 (no hwy).
It is a plain vanilla '05 with stock 185/60/15 tires/wheels but I think the principal applies to 2nd gen also.
Draco w1
I had the same problem with a pickup that drove me nuts until I found that the overflow tube on the radiator neck had not been securely fastened after a shop repair. Check to see if it is tight or just replace it - a couple of feet of drain tube is cheap.
You could also pressure test check your radiator cap. Check first to see that its the correct pressure and that its seated correctly.
Last edited by Hummer_Lite : 05-26-2009 at 10:18 AM. Reason: Automerged Doublepost
Hummer_Lite is offline
Old 05-26-2009, 10:57 AM   #213
My driving is nearly all highway. I have a 32 mile commute to work and nearly all of it is on 4 lane highways. One section is taken at 60 mph and the other at 68 mph. I work on top of a mountain so 15 min of the drive to work is going up...on the other hand 15 min of the commute home is going down and thus using less fuel.
Old 05-26-2009, 04:38 PM   #214
Tire pressure is a player. There is also a difference, auto to manual & summer to winter gas formulas. It seems that this year's warm weather mix is not so good here in the NE. Grasschopper, how has your mileage changed? I've lost a little from last year - not so much that it's a problem -2mpg. 2008 auto 18's w/225/40 38psi. I'm going to 40 psi - at 40 there is the same tread ( flat ) as 38..... There are several people here that are at 45 ( Mini's w/225/40 18's )....... I'll let you know
Steve64 is offline
Old 05-26-2009, 09:30 PM   #215
Thanks for the tip Hummer_lite i will look into it
Draco_w1
Draco_w1 is offline
Old 05-27-2009, 09:56 AM   #216
I don't know that I see a huge change in the winter...I see a bigger change from one brand to the next. I have a BP Visa and was only using their gas for quite a while...then I had to get another brand because I was out and wasn't close to a BP station...I got 2-3 MPG better economy that tank so I stuck with them for several months. I have recently noticed that BP has new signage with "Invigorate addative" on it so I tried it and saw no drop off from the other brand so I am back to BP (5% cash back for those purchases so...). I don't know if they really changed anything or if it was something else...but I am getting 27-29 mpg now with BP gas or the other gas.
Old 05-27-2009, 11:12 AM   #217
"Invigorate additive" Can I drink this? I could use some.
I'm going on a long trip Friday that involves city & highway. I'll compare with the same from last year. As of now the weather will be almost identical.
Steve64 is offline
Old 05-27-2009, 01:52 PM   #218
jtbox91 is on a distinguished road
long trips i get 30. In the city i get 28/29
jtbox91 is offline
Old 05-30-2009, 11:15 AM   #219
shotime is on a distinguished road
last week i drove 150 miles @ 65 got 33.7 mpg 09 xb love the car checking fuel with fill up not on computer
shotime is offline
Old 06-04-2009, 07:26 PM   #220
wattspd is on a distinguished road
I was getting an average of 20mpg with 20's and driving it like a fool.
wattspd is offline
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
2nd Gen Strup Header
Borla Dual Exhaust
Page generated in 0.31151 seconds with 13 queries
