Old 10-01-2008, 05:11 PM   #41
mcdady099 is on a distinguished road
Re: tsudo dual fireball exhaust
I am really thinking about getting the tsudo...but not sure how its going to sound. how does it sound with the silencers in?
mcdady099 is offline   Reply With Quote
Old 10-01-2008, 06:04 PM   #42
its what you do with it.
WhiteNoise's Avatar
So Jealous, I need a higher paying job.
Old 10-01-2008, 06:13 PM   #43
To me, the exhaust sound nicely integrates with the minor engine mods I've made (pulley and home brew CAI.) It's not loud at all, but I consider it appropriate for a "sporty" vehicle ! Definitely NOT the same as stock!
Old 10-01-2008, 11:22 PM   #44
Natzryd is on a distinguished road
The Gen 2 xB does not produce any additional power from an axle back exhaust system. Its all for looks and sound.
The exhaust has two cats, a mufller and sound resonator.
The mid section is the primary block for better exhaust flow.
Import Tuner dyno'd the gen 2 with strup header (removes first header) and trd axle back exhaust and only say a gain of 5 hp.
That's because the mid section is the best and plug to exhaust flow.
To make a difference you have to replace the mid section (muffler & 2nd cat) wtih a high flow cat. & add the strup header to get rid of the first cat.
Otherwise you'll make sound and no extra power.
Natzryd is offline   Reply With Quote
Old 10-02-2008, 09:48 AM   #45
seppuku27's Avatar
^^ Most people are just looking for sound. But then there are people that sound = faster.
Old 10-05-2008, 09:06 PM   #46
I just installed the Tsudo Dual, and part of my motivation was indeed the hope for some slight performance boost -- after all, the Tsudo SURELY flows better than the oem! In any case, although performance improvement would be nice, it wasn't something I was counting on !
Old 10-07-2008, 10:46 PM   #47
I just installed my Tsudo today. I like how it looks, but its to quit for me. Also I had to add 8 washers on the drivers side and 3 washers on the passenger side to make the gap the same. The gap is only 1/4 inch. Its should be 1/2 according to speed element.
Old 10-08-2008, 12:38 AM   #48
Claydohxb
donthateonthebox's Avatar
donthateonthebox is on a distinguished road
I had to put washers in mine too. Most aftermarket part dont just bolt on lol, Like thay say.
donthateonthebox is offline   Reply With Quote
Old 10-08-2008, 06:08 PM   #49
That's not what speed-element told me via email (which I reported on ScionLife where you also posted), he said he used 1/4", and 1/2" should definitely be safe. So he seemed to think 1/4" was probably OK as a minimum. I decided to go with 1/2" for max safety !
By the way, I accept the Tsudo Dual probably has minimal if any effect on horsepower, but I'm wondering if it helps the torque any? I made a standing start left turn at a light controlled intersection today than I could swear was quicker than ever before, it seemed to jump (I'd been forced to wait for cross traffic during a quick green light -- didn't want to lose it .) The rest of the exhaust is stock, but it really did seem to come on stronger than before (torque, not horsepower!)
Old 10-08-2008, 08:33 PM   #50
I just dont understand why they didnt weld the hangers up a little higher so that you do not have to use washers.
Old 10-09-2008, 09:57 AM   #51
seppuku27's Avatar
Torque is a function of horsepower. I bet its just your butt dyno not being calibrated.
Old 10-09-2008, 12:11 PM   #52
The factors that produce torque are not identical to the factors that produce horsepower. An obvious example is stroke. Long stroke engines naturally have torque at low rpm. Short stroke engines require rpm and gearing to produce torque. An example is those old four banger VW Beetle engines -- not much horsepower, but plenty of torque.
As for my "butt dyno", can't say !
Old 10-12-2008, 12:23 PM   #53
trd_matrix is on a distinguished road
Thats a sweet exhaust system
trd_matrix is offline   Reply With Quote
Old 10-13-2008, 02:42 PM   #54
Here're a couple photos I just took yesterday:
Old 10-15-2008, 05:33 PM   #55
Sorry guys, less than 1 hp and less than 1 torque.
Import tuner (2nr) dynoed the 08 xB with trd axle back exhaust and there was no noticable gain but nice sound.
The reality is simple,
If you look at the exhaust system 2 cats and a muffler, that is what is restricting the system.
besides even the pipe size gives you the answer, starts at larger diameter on the s pipe into the mid muffler and cat and then comes out smaller. Clear indicator that most of the restriction come of the mid section.
One side note, the strup header will give an added 5hp for $400.
Plus keep in mind freeing up a restricted exhaust system usually does not help torque as much as hp. Something to do with back pressure allowing the engine to create more torque. In the end though the added hp makes up the difference.
I get my header, high flow cat and tsudo dual exhaust put in on Friday. I'll report back what happens.
Old 10-15-2008, 09:49 PM   #56
Don't know to what degree what you say is true, but my impression is my CAI intake and pulley mods complement the exhaust mod and gained some performance ground. I guess there's no way to be sure without someone taking some honest dyno measurements !
Old 10-15-2008, 10:19 PM   #57
kalcricho is on a distinguished road
i bought my exhaust and cai last night i cant wait it to get here, my exhaust is 3 inches and ends in 4 wooo
kalcricho is offline   Reply With Quote
Old 10-16-2008, 08:44 PM   #58
Depending on what you do for a "scuba" replacement, it sounds like you're dropping back hard on your back pressure. Is that such a good idea with a n/a engine (or are you targeting a turbo or supercharger?) In any case, good luck !
Old 10-17-2008, 09:53 AM   #59
seppuku27's Avatar
I am willing to bet that the dual exhaust would make you loose a hp or two instead of going with a single.
The reason you think your car is faster is because its making more noise and you just paid 350 so your mind is trying to tell you it was a worth while investment.
Old 10-17-2008, 01:34 PM   #60
I was refering to torque, not HP, but since you believe so strongly in a single exhaust, why are you bothering with this thread???
SLR performance chip
Best Intake?
Oil change time!!!!
free h.p. air box mod
Borla Dual Exhaust
2nd Gen Strup Header
Turbo 08 Xb
Page generated in 0.24043 seconds with 13 queries
