I have never done an exhaust before but from seeing those instructions provided on that link it doesn't sound that hard. I do car audio installation so I am thinking I should be straight with tools. Any suggestions on installation?
Yes it takes some tweeking!! I had to put shims on the one side wher it mounts to the car, So the exhaust would be leval on each side. But im a perfectionist. I do mostly car audio so you should be ok!!! Good luck bro!!!
I too am curious to know if this enhances performance. I went to youtube and found a couple of videos with this exhaust installed. It seemed to sound like a standard intake/exhaust modded XB. As far as performance, it would seem like that exhaust split and re-route would add more "length" for the exhaust escape, which in many cases drops performance. I could be wrong, but I'd be interested in knowing if this installation does indeed increase performance.
I just got done installing mine and I love it. Its just loud enough and looks bad a$$!! I didnt see much as far as performance maybe a little but I love the sound.
yes. an axle back only replaces from the end of the stock resonator to the muffler unlike a cat back it bolts on from the stock spipe all the way to the back in which case you remove the stock midpipe.
