Old 12-04-2007, 01:42 AM   #1
eaglespeed91 is on a distinguished road
Smells like coolant!
Every time i get home or any where that i go it smells like coolant. Is that somthing normal do all u guys get that same smell? Its not leaking or anything what do You guys think?
eaglespeed91 is offline   Reply With Quote
Old 12-04-2007, 01:58 AM   #2
Re: Smells like coolant!
mine did that for a bit. but it went away. so i dunno.
ketchup_xb is online now   Reply With Quote
Old 12-05-2007, 11:30 AM   #3
wrczx3 is on a distinguished road
We dicussed this over at another forum and have come to the conclusion that it is some sort of pressure release device on the overflow tank that burps out the extra pressure in the cooling system. A lot of other people have the same smell but no coolant has to be added so obviously it isn't a coolant leak.
wrczx3 is offline   Reply With Quote
Old 12-08-2007, 02:56 PM   #4
ToyotaTech is on a distinguished road
that is true about the over flow tank, of course its a fluid its gonna expand and retract depnding on the temp but if its anymore then a very slight smell then i would be looking closer IMO. the 2az in the 2nd gen and the 1nz in the first gen are notorius for water pump leakage so i would give it a look. i check mine at every oil change because i have replaced several in camrys etc under 10k. also the leakage may be so slight that u may not be able to tell by looking at the over flow tank it may take some time for the coolent level to drop, but u usally can see it visablly on the pump.
ToyotaTech is offline   Reply With Quote
Old 12-08-2007, 05:18 PM   #5
Thanks toytech but I looked all over the engine compartment. I had it on a lift to have a look around too. I have had my XB for 4 months so even if it was a very very small leak at the water pump it would have needed coolant by now.
Old 04-16-2009, 07:56 PM   #6
whitenoise808 is on a distinguished road
Any updates on this? I am a service manager at a Toyota dealership and have seen this in numerous vehicles and one client is especially concerned. Any help on this topic would be great.
whitenoise808 is offline   Reply With Quote
Old 04-17-2009, 09:33 AM   #7
I have an 09, I've had it since last August. Every once in a while I smell the same thing on my, but it's usually after I've been driving it hard. My guess is the overflow receiving some of the expanded Antifreeze and it's giving off the smell because of the Steam...
I've had the smell on other cars before in the same way, so I'm figuring it's the same thing...
Old 04-17-2009, 10:18 AM   #8
ronhawk62 is on a distinguished road
I've had the smell on mine off and on since new, with 18000 miles coolant level is still full.
ronhawk62 is offline   Reply With Quote
Old 06-23-2009, 06:09 PM   #9
TocsinXXVII is on a distinguished road
I havn't noticed this problem on my 09, but it is intresting that you are smelling it. If you havn't seen a leak it brings me to wonder, what about the heater core? Since the heater core is on the other side of the firewall and goes directly into the vents. Just an idea and because most problems on heater cores start off with the connections coming frail or loose.
TocsinXXVII is offline   Reply With Quote
Old 09-05-2009, 09:18 AM   #10
I haven't noticed the smell in months, its just gone away.
Old 09-21-2009, 08:14 PM   #11
Rattylumpkins's Avatar
Rattylumpkins is on a distinguished road
I was smelling something sweet while in mine but it turns out I dropped a lollipop on the exhaust manifold while pouring anti-freeze in it. I still smell it though......
Rattylumpkins is offline   Reply With Quote
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
Borla Dual Exhaust
2nd Gen Strup Header
Turbo 08 Xb
Page generated in 0.21619 seconds with 13 queries
