Old 02-01-2008, 12:53 PM   #1
Pimpnit869 is on a distinguished road
Oil change time!!!!
Hello forum! Its oil changing time for the 08 xB! I wanted to see what everyone was running in there 08 xB (synthetic or conventional)? I was thinling of running semi synthetic. any thoughts?
Thanks Jay
Pimpnit869 is offline
Old 02-01-2008, 02:00 PM   #2
bagged06box
magicmechanic86 is on a distinguished road
Re: Oil change time!!!!
synthetic is good oil but you have to be carful it has ways of finding the smallest spots and letting them leak. but it is rare. I have had this happen once before, but on a good note when i switched back it stoped. so give the syn, a chance its good stuff...
magicmechanic86 is offline
Old 02-01-2008, 03:59 PM   #3
dokutman is on a distinguished road
dont forget , if your scion is new, first 2 oil changes should be free of charge at the dealership
dokutman is offline
Old 02-07-2008, 12:19 AM   #4
wg45678 is on a distinguished road
Dont' bother with semi-synthetic. You pay most of the cost of full synthetic and get virtually none of the benefit. Suggest watching specials (like Pep Boys or Checker) and buying full synthetic. Bought 5 Qts of at Checker for $0.99/qt after rebate. PepBoys is advertising 5Qts Pennzoil Synthetic and PureOne filter this week for $23.
wg45678 is offline
Old 02-28-2008, 09:33 PM   #5
kev_xb is on a distinguished road
i run full synthetic changed every 2-2.5k miles (i get my oil for free from work ) and I've got 17000 with a squeaky clean leak free engine... spend the lil extra and go synthetic... its worth it.
kev_xb is offline
Old 02-28-2008, 10:10 PM   #6
its what you do with it.
WhiteNoise's Avatar
Aren't synthetics supposed to run longer between changes? I guess if the oil is free.
WhiteNoise is offline
Old 02-28-2008, 10:57 PM   #7
Rocket_Sciontist's Avatar
Rocket_Sciontist is on a distinguished road
Amsoil has a 25,000 and a new 35,000 mile or one year ,between changes oil out now!
Rocket_Sciontist is offline
Old 02-28-2008, 11:42 PM   #8
yeah your supposed to be able to run my synthetic for 6000, but i get it for free and I use the lifts at work to do it... and I'm on the clock, and it certainly cant hurt to change your oil early... ideally when you change your oil you want it to look clear, like new oil... so the more frequently you change it the better. I guarantee you'll be alot better off in the long run if you change it before it needs it.... and i wouldn't recommend using 25k or 35k oil.... you should still change it every 3 months... wether you've hit the mileage or not...
kev_xb is offline
Old 02-29-2008, 12:50 AM   #9
WhiteNoise's Avatar
Interesting opinion Kev. I still think changing it out that frequently, especially on a camry engine, is overkill. I am willing to bet that with regular oil changes I will still get close to 200k out of my xB. Well my son will cause as soon as he is of age its his.
Old 02-29-2008, 03:41 PM   #10
Yea, all that blow-by funk still goes in the oil. The sloppier the tolerances, the more contaminated the oil gets.
Let’s keep our little squirrels tight!
Old 03-11-2008, 10:41 PM   #11
i wasn't saying every one should change their oil as frequently as i do, like i said i get it for free and i can do it on the clock, but you should change it every 3000 or 3 months, its alot better for your engine....
kev_xb is offline
Old 03-15-2008, 01:35 PM   #12
jahfakin's Avatar
jahfakin is on a distinguished road
......you can change your oil every 25K-35K miles, if the engine was designed with that in mind. My 99 BW Beetle has 170K on the orig engine and clutch, and it's still running. I change the oil every 10K, just like the manual says. But the VW uses a timing belt, and not a chain, so changing the oil every 10-15k is fine. Some cars (GM cars like Saturn I think....not too sure) requires frequent oil changes to prevent the timing chain from getting all sludged up. But this is not true with all engines that use a timing chain. The xB2 manual says to change the oil every 5K....so I'll change it when it's at least 5K (probably a little longer).
As for the whole "ideally when you change your oil you want it to look clear" is not true either. You can't determine the concentration of contaminates in used oil, just by looking at it. Not all forms of contaminates will discolor motor oil, take water for example. It needs to be sent out to a lab, for analysis. I've also read that a good Syn Oil is fine up to 10k-15K in these Toyota engines (based on an oil analysis). So yeah, changing you oil at 2500K is a waste.
My xB2 break in period is just about over. So I'll be switching to syn real soon (0w20). I've only used Mobil 1 full syn oil over the years, and been very happy. Not cheap, but it's considered the best on the market. Used 10w30 in GT mustang...100K at the time I sold the car, not a single engine related issue. 0w40 in winter or 5w40 in summer in the VW Beetle w/ 170k and still running on orig turbo, engine and clutch (syn tranny fluid).
jahfakin is offline
Old 03-16-2008, 12:23 AM   #13
I'll debate the "Best on the market" statement compared to Amsoil!
http://www.amsoil.com/lit/g1971.pdf
Both are good , and both are expensive, but in the long run, are worth it!
Old 03-16-2008, 06:20 AM   #14
rosconey is on a distinguished road
i used mobil 1 on my 06 corolla-wally world has 5qt bottles for 20 bucks-
i thing i do enjoy is a oil change,i cant stand the idea of some moron stripping my oil drain plug-im the only moron allowed to do that with my vehicle
rosconey is offline
Old 03-16-2008, 10:35 AM   #15
jahfakin's Avatar
yeah Amsoil is excellent stuff too, forgot about them. it's just hard to get, have to go through auth dealers. While the mobil stuff I can get at the local pep boys or autozone
Pep boys did that to my VW a few years back. Stripped the drain plug on my aluminum oil pan....they denied responsibility and I had to get a new oil pan. since then, I do my own oil changes on that car. I used a Pela oil extractor to change the oil......no need to get under the car.
I don't think that works on Toyotas, only German cars.
jahfakin is offline
Old 03-17-2008, 04:34 PM   #16
first off...i wasn't saying if its not dirty then its all good to go... but you definitely don't want it to look dirty, and as i stated previously i get my oil for free and can change it on the clock, so it doesn't hurt to change mine before its due. and i was talking about 2nd gen xBs when i said it should be changed every 3k, if your using synthetic you could go 6k. i do work with this stuff every day. toyota says to change it every 5k because they want you at the dealer every 5k maintenance and they want to make the money on the oil change too, i would recommend every 3k if your not using full synthetic... but thats just my professional opinion...
oh...fyi anyone who wants amsoil, hit me up, they sponsor my race team and i can get you whatever you need...
kev_xb is offline
Old 03-17-2008, 06:31 PM   #17
I also am a dealer of Amsoil! But I would limit to locals only.
Shipping would be a killer
Old 05-01-2008, 08:32 PM   #18
Invertalon is on a distinguished road
Send a message via AIM to Invertalon
I just did mine today at 9950mi, filled with M1 0W-20... Plan to do 5,000mi OCI's.
Very easy to do on this car!
Invertalon is offline
Old 05-02-2008, 10:59 AM   #19
Andydeelight is on a distinguished road
The Guy gets his oil for FREE and he gets PAID to change his own oil! If this was the case for me I would change it every other week. Just because I can
Andydeelight is offline
Old 05-02-2008, 03:34 PM   #20
seppuku27's Avatar
You would still have to change the oil filter at 3k to 5k miles anyways. Its still going to get dirty at the same rate.
seppuku27 is offline
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
Borla Dual Exhaust
2nd Gen Strup Header
Turbo 08 Xb
Page generated in 0.24337 seconds with 13 queries
