Old 05-03-2008, 12:44 AM   #21
Rocket_Sciontist's Avatar
Rocket_Sciontist is on a distinguished road
Re: Oil change time!!!!
Originally Posted by seppuku27 View Post
You would still have to change the oil filter at 3k to 5k miles anyways. Its still going to get dirty at the same rate.
The oil does get dirty at the same rate. We need a better filter to trap this dirt. With Amsoil's EAO filters, they guaranty 25K or 1 year.
It's a special material. http://www.amsoil.com/storefront/detail.aspx?ID=3444 Before this your right! With conventional filters, the oil would last, become contaminated, and the filter would have to be changed. Check it out!
Rocket_Sciontist is offline
Old 05-04-2008, 11:13 AM   #22
seppuku27's Avatar
I don't know if I could go that far on an oil change. I think 5k is for one oil change.
seppuku27 is offline
Old 05-09-2008, 08:39 AM   #23
uzaXb08's Avatar
uzaXb08 is on a distinguished road
Full synthetic Moblie 1 or Royal purple . Are the only two brands of oil I used, the mileage in between changes 3500 to 5000 will vary on the stop and go as the more hwy driving less changes. I gotten great results from both .
uzaXb08 is offline
Old 06-09-2008, 01:38 AM   #24
DV048 is on a distinguished road
on the subject of oil changes - and this is really going to single me out as a complete newb at this - but does the TRD oil filter make ANY difference if you're doing regular oil changes between 3-5K?
DV048 is offline
Old 06-19-2008, 10:50 PM   #25
xB newb
whiteboyslo is on a distinguished road
Originally Posted by jahfakin View Post
but the VW uses a timing belt, and not a chain, so changing the oil every 10-15k is fine. Some cars (GM cars like Saturn I think....not too sure) requires frequent oil changes to prevent the timing chain from getting all sludged up. But this is not true with all engines that use a timing chain. The xB2 manual says to change the oil every 5K....so I'll change it when it's at least 5K (probably a little longer).
why the heck would a timing belt vs a timing chain make a difference on oil life?
Mike
whiteboyslo is offline
Old 06-22-2008, 09:41 PM   #26
Simply Scionic
daddysxb's Avatar
daddysxb is on a distinguished road
Originally Posted by dokutman View Post
dont forget , if your scion is new, first 2 oil changes should be free of charge at the dealership
Is that in writing somewhere? I just took my in for it's first oil change and I had to pay for the oil change and the tire rotation.
daddysxb is offline
Old 06-23-2008, 08:39 AM   #27
CYBERICK1 is on a distinguished road
Yeah! I am with DV... Same question.
I thought about getting the "OEM" oil filter from the dealer and... (probably someone is gonna put me at shame for saying this since you are all fighting between Amsoil and Mob1 but... here it goes...) I thought about using 'Quaker State' for oil!
I've always used QS on both of my past cars (1999 Eclipse and 1996 Yukon) and I've always got the "OEM" Oil Filters (Mitsubishi and AC Delco respectively) changing them every 3,000 miles without excuse. Honestly never had a problem with either the Eclipse nor the Yukon as far as motor goes...
Now that I see you all arguing about this 'X' vs.'Y' Oil it seems to me it'll be one heck of an issue for me now... Mob1 or Amsoil? I got a question though... I noticed that on that PDF it all about >Sync Oil<. My question is... True or False that just because they make the "BEST" SYNC Oil doesn't mean that they make the best REGULAR oil? I wasn't planning on going Sync at all... boy... things are getting complicated... Sync or Regular? Amsoil or Mob1... QS or X Brand...
In any case... I have 3,648 miles to decide what to do with my first Oil change... Hope you guys help out on making a good decision...
BTW, Kev... What Oil are you using?
CYBERICK1 is offline
Old 06-23-2008, 10:38 AM   #28
xB Version 2.0
TunerChick's Avatar
TunerChick is on a distinguished road
K & N filters and Royal Purple oil. My brother works at Advance Auto Parts and got the Royal Purple on sale for around $30/case...so we will use it till it's gone then change to Amsoil since we finally found a local dealer!
TunerChick is offline
Old 06-23-2008, 11:59 PM   #29
I've always used Castrol prior to becoming an Amsoil dealer! It's a great "dino" oil. The OEM Toyota filter is pretty good also. Both will cover you for 3 to 5K miles. The benefits of sync. lubricants are reduced wear, reduced temperatures, and extended drain intervals, just to name a few.
AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases Shameless plug
Old 06-24-2008, 12:36 AM   #30
kev_xb is on a distinguished road
im using QS, because i get it free from work, but i have no complaints about the quality of it, i use full synthetic and QS filters, and thats what ive used on all my cars cept for my BMW.
kev_xb is offline
Old 06-25-2008, 08:08 PM   #31
xB newb
it's in the literature you received with the car. i THINK it's in the preventive maintenance schedule.
Mike
Old 06-26-2008, 03:01 AM   #32
NEW BOX OWNER
JDMLIFE is on a distinguished road
Mike
ive had both my oil changes done at thte dealer and enterd a raffle for another change so thats three in all and complaind abuot my alignment so they balanced them for free and rotated them on my oil change i just got fu$%&ed on my trade in but its all good they even wash it for free too, too bad that they dont top off the tank
JDMLIFE is offline
Old 06-27-2008, 09:59 AM   #33
seppuku27's Avatar
I don't trust dealers I know people that work at them and they will steal anything they get their hands on. Also they don't give a shit about your car. They will do burn outs and drive all crazy in your car. I just skipped the free oil changes and did them myself.
Old 06-27-2008, 10:46 AM   #34
Wawazat?
toaster's Avatar
toaster is on a distinguished road
I was offered 2 freebies too. I went in for the first one, it took so long that I could have made my own oil faster! (1hr 45 min) I never went back for the second. My time is too valuable. I go to the 10 minute place now, and don't have to get dirty, or hot or have to figure out what to do with the old oil. I sit in air conditioning, have a complimentary cookie and coffee and they throw in a free carwash too. BTW, I just converted to Mobile 1 a week ago.
toaster is offline
Old 06-27-2008, 03:47 PM   #35
seppuku27's Avatar
I like getting dirty though. And I know its done right with me doing it.
Old 06-27-2008, 04:34 PM   #36
I like the way you think!! Following that Dinosaur around for collections/deposits could be dangerous!
Old 07-12-2008, 01:53 PM   #37
rosconey is on a distinguished road
did my first oil change today-3514 miles-
all i could find was pennzoil in 5-20 that wasnt synthetic -
took it out on the highway and noticed the rpms for 65mph dropped about 100-from 2500 to 2400-
they must have had a japanese strongman install the filter-ive never ever ever had such a hard time getting one off-
rosconey is offline
Old 07-14-2008, 10:19 PM   #38
the factory filters are always super tight, lol. anytime i do an oil change on a brand new car its a ***** to get off... Pennzoil makes good stuff tho
kev_xb is offline
Old 07-15-2008, 08:47 PM   #39
jetcar's Avatar
jetcar is on a distinguished road
My ancient Previa tells me when to change the oil.... about every 6-8K, it'll light up. I usually don't get around to it till about 12K. When I finally change the oil, it always looks like honey, and I only use the cheapest crud and filters I can find. It's got about 225K on the clock, AND it still runs like a top. Never had any internal motor problems, AND it gets 26MPG still.
SO
Just HOW is expensive synth/semi-synth oil supposed to help??? I mean, besides making the oil companies rich? :-)
I mean, the idea of buying an economy car and putting $8/quart oil in it leaves me semi-speechless.
jetcar is offline
Old 07-15-2008, 10:10 PM   #40
seppuku27's Avatar
Synthetic oil doesn't break down like normal motor oil and it protects alot better than regular oil. I would never think of doing oil changes at 12K thats just waiting too long on regular oil. I buy 5 qts of Mobile 1 at Wal-Mart for 25 dollars so thats 5 dollars a qt.
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
Borla Dual Exhaust
2nd Gen Strup Header
Turbo 08 Xb
Page generated in 0.35145 seconds with 12 queries
