Old 09-16-2008, 12:29 PM   #41
09noo_x_b is on a distinguished road
Re: Need More MPG - Do you think something is wrong???
sautan did you ever go back to the dealership or anything about this?
09noo_x_b is offline   Reply With Quote
Old 09-26-2008, 10:41 PM   #42
Exposure101 is on a distinguished road
Originally Posted by eggie View Post
What wheels do you have? How much do they weigh?
Fill up. Reset trip odometer. Drive until like half tank. Fill up and note gallons used to fill up tank again.
Divide miles drive by gallons used and that will give you the miles per gallon.
I know this was stated above, but from reading teh post it did not register if you understood that or not.
Heck for kicks, you can swap wheels and tires and see what happens.
Also, an engine should be driven easy for the first 1000 miles to properly break in the internal components. Then do an oil change and swap in synthetic, Mobil 1 is cheap and works just fine.
I def agree with all of this....especially the swapping to synthetic oil!!! Maybe add some lucas oil additive to it....not a lot like 5-10%
Exposure101 is offline   Reply With Quote
Old 09-27-2008, 02:33 AM   #43
sautan904 is on a distinguished road
I think I will go back to the dealer. I have not swap the wheels because the other xB is currently being worked on. The stereo dude took 3 weeks to get my car done and still have problem and now fixing it. Dealer took 10 days to get all the TRD parts!!! I just got the car back and will swap the wheels probably tomorrow. Another tank of testing with stock wheel. If still persist, it will go to dealer. The problem, they always comes out with "No Problem Found" and if you pressure harder, they might not happy! i dunno, i will try.
sautan904 is offline   Reply With Quote
Old 10-01-2008, 12:13 AM   #44
Re: Need More MPG - Do you think something is wrong??? (UPDATE 10/1/2008)
OK, finally I switch the wheel with my other xB. The result is amazing. I cannot believe the difference MPG can change with the wheel and rubber.
xB Blackberry Auto
Old MPG - 17MPG Combined. with 19" 5-Axis Wheels
New MPG - 27MPG Combined. With 16" Enkei Wheel and Stock Rubbers
xB Gold Rush Manual
Old MPG - 30MPG Combined. With 16" Stock Wheel and Rubbers with Fujita Intake.
New MPG - 23 MPG Highway Mile for 40 Miles (no traffic) on 5-Axis Wheels.
5-Axis Wheel 19" 235-35R 19
Well, I do not suggest to size up wheel and tires if you are looking for MPG. Good thing for my Gold xB, it's the show car with all TRD mods and Custom interior. So i do not drive as much. Will add Supercharger in December!!!
Eventhough i only drive for few days but i am so sure. I reset the meter and drive for 2 days... 50/50 local and fwy and read 27.x earlier. Never I saw it reached over 19MPG in the past!!!
Old 10-01-2008, 02:43 PM   #45
Industrial Sports Box
TartanJack's Avatar
For wheels and MPG affect . . . "lighter is better."
Less rolling weight means less mass to get moving and to stop with the brakes. Also, less "effort" to change direction for a lighter rim.
On top of that, lighter means that the suspension has to work less to "suppress" the bouncing of a lighter unsprung mass.
(I could continue, but I won't.)
One of the main reasons I want Rota Slipsteams in 16x7 is that they weigh less than 14 pounds (6-8 pounds less than the 20-22 pounds of the stock steelies), not counting tires (which should add approx. 20 pounds). Oh, and tires of a smaller ratio tend to be heavier, as the sidewalls are stiffer and have more internal structure.
In short, "Lighter is Better."
Old 10-02-2008, 07:15 AM   #46
jahfakin's Avatar
jahfakin is on a distinguished road
Originally Posted by cnstarz View Post
you cant trust the computer anyways,.....
why can't you trust the computer?
I'm the opposite...I always trust the computer....mainly because heat throws off gas pumps (gasoline expands during the hot summers/temp). So in the summer time, you are getting ripped by the gas stations. This naturally affects the MPG calculation, when manually done.
the computer, on the other hand, gets its data directly from the injectors. a more reliable source.
p.s. I think some states have heat sensing pumps, that automatically adjust to the temperature and dispenses the exact amount of fuel everytime.
jahfakin is offline   Reply With Quote
Old 10-02-2008, 09:22 AM   #47
its what you do with it.
WhiteNoise's Avatar
p.s. I think some states have heat sensing pumps, that automatically adjust to the temperature and dispenses the exact amount of fuel every time.
Hawaii is one such state but it sets the pump temp at 80 degrees. That said the tanks are stored well below ground where it takes longer for them heat up. Also a 15 degree increase in temp only changes the volume by 1%. Note this only happens after 60+ degrees.
Old 10-02-2008, 11:28 PM   #48
jahfakin's Avatar
yeah, if the pump is calibrated for 60 degrees, and it's 90 degrees outside in the middle of summer, you are getting ripped. It may not seem a lot, but it adds up. based on your calculation, a 25-gallon fill-up of 75 degree F gasoline equates to a loss of nearly one quart. The same fill-up at 90 degrees F equates to nearly a half gallon.
Old 10-08-2008, 11:24 PM   #49
CrazyMPG is on a distinguished road
xB Blackberry Auto
xB Gold Rush Manual
wow those 19" rims make a difference...btw...do you know the weight for those 5 axis 19" rims with tires versus the stock steelies with tires?
CrazyMPG is offline   Reply With Quote
Old 10-09-2008, 06:03 PM   #50
TartanJack's Avatar
{snip}, a 25-gallon fill-up of 75 degree F gasoline equates to a loss of nearly one quart. The same fill-up at 90 degrees F equates to nearly a half gallon.
Please let me know how you fit 25 gallons in an xB, either generation . . .
I generally put in 6-9 gallons per fill-up.
Of course, over 3-4 fill-ups, that would make some difference.
Old 10-10-2008, 04:27 AM   #51
Not to mention that the pumping station tanks are required to be below ground, and there is a level below ground (4-5 feet I believe) where it is no longer affected by the change in surface temperatures and stays at around 54 degrees (if I recall correctly). so the gas you pump should be the same/ or as close to the same everyday no matter what the temp. However once it's in your tank if you over fill and park in the sun you may see spillage.
Old 10-16-2008, 07:22 PM   #52
xB Blackberry Auto
xB Gold Rush Manual
In addition to lighter is better, narrower is also better when it comes to mpg. Wider tires have greater rolling resistance and also scrub more when changing direction. The other factor is inflation, lower inflation pressure results in higher rolling resistance. Conversely, over inflation will result in more rapid tire wear!
Old 10-16-2008, 11:14 PM   #53
dreeder72 is on a distinguished road
Just for comparison: Im driving an 09 XB with 2700 miles. I average 27mpg city and 33mpg highway, these figures were determined with daily city driving and 1 trip out of state for highway. Everything is stock. I did notice that when the fuel meter read empty I would only get 11-12 gallons into the 14 gallon tank. So I opened the gauge cluster, pulled the gas meter needle off, tossed a gallon of gas in the trunk area and drove it until it ran empty. I then placed the needle back onto the gas gauge pointing to the correct "empty" position. now when I fill up the needle goes well past the full mark but when it reads empty it is really empty. Another thing I noticed was the fuel range feature is NOT accurate, I have had it read 0 miles left till empty and continued to drive for another 50 miles.
dreeder72 is offline   Reply With Quote
Old 10-17-2008, 08:52 AM   #54
TartanJack's Avatar
It's called a "reserve" . . .
Most cars have the gauges designed with a reserve, so that people don't run completely out of gas. Modern fuel injection systems don't "like" running completely out of gas.
I like to keep an idea of how much reserve my vehicles have.
The xB2 has more than 2-3 gallons. So, I should be able to drive about an hour before I am completely out, so don't panic but look for a decent station.
The most I have put in is 11 gallons, the light was on but wasn't on for that long.
My Miata (the "other" car) has 1.5 gallons reserve and an 11 gallon tank, so the most I have put in it is 10 gallons, when "on fumes" and on "e" for a while.
Old 10-17-2008, 10:05 AM   #55
I'm aware of what a reserve is and it's purpose. I guess that it's just personal opinion that 2-3 gallons of reserve is excessive on a 14 gallon tank, the reserve is 15-20% of the capacity. I just prefer to know when I'm empty as opposed to guessing how much is left. That's why I moved the needle.
Old 10-17-2008, 12:30 PM   #56
TartanJack's Avatar
-----Okay.
Old 11-15-2008, 05:35 PM   #57
darita is on a distinguished road
xB Blackberry Auto
xB Gold Rush Manual
So, is the consesus here that with an auto trans and 19s, mileage can go down dramatically or was that just is one specific case? What about others with 19s...what mileage do you get?
darita is offline   Reply With Quote
Old 11-15-2008, 10:24 PM   #58
seppuku27's Avatar
Its all about wheel weight and auto trannys natural get worse gas mileage than standard trannys. Bigger wheels weigh more unless your willing to pay thats why you get worse gas mileage.
Old 11-16-2008, 10:26 AM   #59
So, with a standard trans and middle weight 19s, what do you think I could expect for mpg?
Old 11-17-2008, 11:17 AM   #60
seppuku27's Avatar
Just make sure the 19 with tire is the same weight as the stock rim and tire you will see the same mpg.
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
2nd Gen Strup Header
Borla Dual Exhaust
Page generated in 0.27704 seconds with 12 queries
