Old 05-25-2009, 03:33 PM   #1
Draco_w1 is on a distinguished road
Does anybody get a radiator smell from there XB
Hi I'm new to this site i joined hoping to get some answers to my problem wich the dealership cant seem to help me with . When i got my XB i would ocassianaly smell radiator fumes after i got out from the car, i took it back to the dealer twice and they told me they contacted there engineers in L.A and never heard of anything like it, because there is no leaks. they told me it must be the long life radiator fluid that i get a wiff of when i get out of the car, but im not buying this bull i worked in a dealer shio before and i know this is not normal can any body help me out?
Draco_w1
Draco_w1 is offline   Reply With Quote
Old 05-25-2009, 08:43 PM   #2
mORON mODERATOR
Cravin's Avatar
Re: Does anybody get a radiator smell from there XB
Check your heater core maybe thats got a leak. Is your car a gen 1 or gen 2 xB?
Cravin is offline   Reply With Quote
Old 05-25-2009, 09:02 PM   #3
Gotta open the hood when you smell that and try to look for the source.
"Engineers in LA"- thats a new one
Old 05-25-2009, 10:53 PM   #4
regulatin' on foolz......
check all connection on hoses, tubing w/o-ring area and petcock. and like cravin posted, check heater core/radiator heater assembly by blasting the heater with motor running. when my heater core had a leak, i smelled that radiator fluid smell and then, my front windshield fogged up on my celica supra.
click here for the 04-06.5 heater assembly pdf doc.
Old 05-26-2009, 09:17 PM   #5
Its a second gen 2009 there are no leaks i looked maybe its under something slightly covered ill check again this weekend
Draco_w1
Old 05-26-2009, 10:16 PM   #6
MOVED to gen2 "performance & tech help"
Old 05-28-2009, 11:36 PM   #7
yelotoxbop is on a distinguished road
You have a leak. Anytime you smell anti frz its because its leaking. check all fittings after you get out of your car when it is still hot. Do you know any one that has a rad presure tester.
yelotoxbop is offline   Reply With Quote
Old 06-16-2009, 03:20 PM   #8
aslader13 is on a distinguished road
I get that from mine sometimes after a long drive. My level has been fine, I marked the tank with a sharpie for reference and its been right on whenever I check it. From the research I found the cooling system on the xb is a little different than norman because we have no radiator cap. We have a coolant box with pressure cap above the radiatior. That is because the radiator is below the motor and due to gravity you could never fill it. The smell of coolant is from the pressure in the cooling box. This is what I could find out. I am not 100% of the accuracy but it makes sense. I hope this helps and if you findout anymore please post because I'm curious to find out why also.
aslader13 is offline   Reply With Quote
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
2nd Gen Strup Header
Borla Dual Exhaust
Page generated in 0.15698 seconds with 13 queries
