Old 06-16-2009, 12:52 PM   #1
aslader13 is on a distinguished road
anyone on the juice?
I have an 08 xb automatic. I was thinking of ideas for hp gain. I know the xb isn't a race car, but I'm just looking to have some fun, maybe beat a few tcs. I don't have experience with nos and am doing some research now. If anyone can help it would be greatly appreciated. I am having trouble finding anyone that has a nos system on a toyota 2.4l with an auto trans. I understand that it could throw off shift points, but what about using the selective 4 speed node and shifting each gear at a higher rpn that normal driving? Thanks for the help
aslader13 is offline   Reply With Quote
Old 06-16-2009, 02:26 PM   #2
seppuku27's Avatar
Re: anyone on the juice?
Are you talking Nos the name brand or are you talking nitrous oxide? eighty8customs (VIP Style box) has a nitrous kit on his not sure the brand name and I believe he has an auto. I have never used nitrous with an auto tranny (never owned an auto) so I couldn't tell you anything about shift points I don't see how it would throw them off though.
Do some more reading before you put nitrous on your car. I would only run a 50 shot or 75 pushing it on a stock engine.
Nitrous Oxide Systems - DIY NOS KIT FOR CARS!
NOS & Nitrous Tips - Tech Review - Turbo Magazine
I have some better links on my home computer I will send you.
Old 06-16-2009, 03:08 PM   #3
I meant nos as a general term for a nitrous oxide system, not any brand in particular ( zex, nos, nitrous express.....) I was thinking of a 50 or 75 shot. I had also read about progressive controllers that gradually introduce the nitrous untill fully open instead of blasting it all at once. I will definitely check out the places you have mentioned and I appreciate the help.
Old 06-16-2009, 03:44 PM   #4
seppuku27's Avatar
You should look into electronic bottle opener (your going to mount it in the back right?) so you don't have to go to the back and open and close it all the time. Also you will need a safety switch for when your WOT that is the only time it will activate the nitrous. Also a way to retard your timing when your spraying is needed. I'd also get a A/F gauge so you can see your not running lean, it will give you piece of mind.
Take a look on your local craigslist and try and find a used setup and add to it everything else you will need.
Old 06-16-2009, 03:58 PM   #5
I definitely check out cl for a kit. I will absloutely have my tank tested before install. The electronic bottle opener sounds like a good idea also, but I may just take the tank out untill I go on a cruise or something. I don't need my wife burning up all my nitrous going to get groceries. I really want this for fun. My xb is a daily driver so reliability is a big factor, that's why I'm doing as much research and trying to get as much info as I possibly can. That's another question I have. I know its very general but here it is. How much reliability will you sacrafice with a nitrous kit. I know there are many variables like 25-100+ shot, pressure switches and more. I would like to do a reliable 50 shot with a progressive controller. If that sounds right. How necessary is a blow off valve? I kind of want to keep the nitrous a secret, so when all my tc buddies get left behind they won't know what hit them. Thanks again for the help, ideas and advive. Suggestions are always welcome on tank placement, brand and anything else. Thanks again for the help
Old 08-23-2009, 11:39 AM   #6
RcBOX is on a distinguished road
let me start with answerinng a few of your questions
How necessary is a blow off valve? Not need as you do not have a turbo or a supercharger so no excess air pressure is noy needing to be removed. You will want a purge valve however this is what makes the system work at its peak by clearing out any air in the system. all it is is another solinoid that you hook up in series with everything else and hooked up to a button in the car.
Next a progressive control is not needed with a 50 shot. it is nice but seriously you are going to tune it for very small amounts of spray until you get to the full 50 shot this in my opinion is not needed not enough nitrous being sprayed to warrent its use
Nitrous kits are universal the only thing that make then tune different in each car is what jets are used to make each desired amount of horsepower out put. and i would go with a wet kit as fo it supplies its own fuel from the fuel rail.
Nitrous will not change your shift point in an automatic you will go through the entire gear when your foot is on the floor like any other time it will just go fast through the gears
Get a bottle warmer and bottle psi gauge this ensures the same bottle pressure every time you go to use it.
You are able to turn nitrous on and off so is you have a remote bottle opener and you leave the switch off you can leave it in the car all the time.
Next if you wanna be sneaky i say get multiple 1# bottles and put them under the cargo cover in the back by the spare tire.
RcBOX is offline   Reply With Quote
Old 10-31-2009, 04:35 PM   #7
08swXb is on a distinguished road
ZEX makes a great kit for the Xb's and the product quality is very well too.
08swXb is offline   Reply With Quote
SLR performance chip
tsudo dual fireball exhaust
Best Intake?
Oil change time!!!!
free h.p. air box mod
Borla Dual Exhaust
2nd Gen Strup Header
Turbo 08 Xb
Page generated in 0.17641 seconds with 13 queries
