Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB
Old 01-05-2008, 05:51 PM   #1
whisper14225's Avatar
whisper14225 is on a distinguished road
Send a message via MSN to whisper14225 Send a message via Yahoo to whisper14225
Spark Plugs
Ok hitting the 30,000 mark and time o change the plugs...... what should I use???? Everything right now is stock.... and the only thins that will change will be a short ram and exhaust so I don't think that that will have bearing on the plugs but I could be wrong... soooo any input would be grreatful!!!
whisper14225 is offline   Reply With Quote
Old 01-05-2008, 07:01 PM   #2
Rocket_Sciontist's Avatar
Rocket_Sciontist is on a distinguished road
Re: Spark Plugs
NGK iridium baby
Rocket_Sciontist is offline   Reply With Quote
Old 01-07-2008, 07:14 PM   #3
grizzly_choppers's Avatar
Re: Spark Plugs
Yep, Toyota products like Denso (ND) and NGK plugs. Not really anything else. While working in our parts department I saw several dozen Toyota cars that ran like crap/got terrible mileage/flipped on CELs/whatever simply because they were running a different brand of plug.
I went with the Denso platinum myself. Factory recommended! My wife's will get the same if she ever gets to 30K...
Good luck!
-Alex
grizzly_choppers is offline   Reply With Quote
Old 08-12-2008, 09:25 PM   #4
mauiXaXbTc is on a distinguished road
Re: Spark Plugs
we just installed some NGK Iridium IX plugs gaped at 0.44. We started it up & only smooth the idle became. We went on a test run & it was a nice difference in power & shifts are smoother.
mauiXaXbTc is offline   Reply With Quote
Old 08-17-2008, 08:15 PM   #5
Miroresh's Avatar
Miroresh is on a distinguished road
Re: Spark Plugs
Sorry for the noob question, but how many of these plugs do i need to buy?
Miroresh is offline   Reply With Quote
Old 08-17-2008, 09:46 PM   #6
morningman is on a distinguished road
Re: Spark Plugs
no reason to be sorry about asking
you have a 4 cylinder there for you will need 4 plugs
and the NGK's are awsome but i also recommends the Bosch Platinum 4 plugs
morningman is offline   Reply With Quote
Old 08-18-2008, 12:30 PM   #7
Miroresh's Avatar
Re: Spark Plugs
I found this one:
Originally Posted by Advanced Auto Parts
NGK Iridium Ix Plug
Part Number: BKR5EIX
but it's gapped at 0.32, where do you get the 0.44 and again, noob question, does that make much of a difference?
Thanks again!
Edit: After some research, i guess the 32 can be changed to 44 but now my question is, why 0.44? Is this the tested and popular choice for the xBs?
Old 08-18-2008, 12:57 PM   #8
Re: Spark Plugs
$12.99 per plug? They better work well. =)
Old 08-18-2008, 01:05 PM   #9
Miroresh's Avatar
Re: Spark Plugs
small price to pay to keep my box happy So, .44?
Old 08-18-2008, 04:17 PM   #10
Re: Spark Plugs
Look at this whole thread! ScionLife View topic - Spark Plug Change
"Just changed my xB RS 1.0's plugs to NGK Iridium iX-11 with the .044 gap..."
Old 08-18-2008, 07:32 PM   #11
Wawazat?
toaster's Avatar
toaster is on a distinguished road
Re: Spark Plugs
With gas at $3.79/gallon, many are willing to try anything. Buying these more expensive plugs equates to the cost of about 10 gallons of gas (325 miles). If they add 1-2 mpg, it would take many fill ups (24) before any return on your investment is realized. (In my case it would take about 8 months.) Are they really that good?
toaster is offline   Reply With Quote
Old 08-18-2008, 09:09 PM   #12
simijoecool's Avatar
Re: Spark Plugs
actually for four plugs that would cost $52 and at ur low gas price (i paid 3.99 today, damn u florida) is close to 14 gallons. but i am still wanting to try it. haha
Old 08-18-2008, 10:06 PM   #13
Re: Spark Plugs
Originally Posted by Miroresh View Post
I found this one: but it's gapped at 0.32, where do you get the 0.44 and again, noob question, does that make much of a difference?
Thanks again!
you use a gapping tool from the auto parts store
Old 08-19-2008, 03:38 PM   #14
Miroresh's Avatar
Re: Spark Plugs
Great thread and good read. I did read around there that NGK and Scion specify the following:
According to the Xb Service manual here are the correct specs for the plug gaps:
Denso (K16RU)= 0.7 mm / 0.028 inches
NKG (BKR5EYA)= 0.8 mm / 0.031 inches
So what is it?
Also, do you guys recommend any particular torque wrenches out there? Hopefully under $50?
They linked this but wanted to get a 2nd opinion from my box brothers
3/8" Dr. Torque Wrench - 2455mit
Old 08-19-2008, 06:18 PM   #15
Wawazat?
toaster's Avatar
Re: Spark Plugs
I came up with ten gallons because I subtracted out the requisit cost of buying 4 cheap plugs at about $3.50 a piece. When I posted, I figured someone would see the the math didn't add! Thanks!
Old 08-19-2008, 06:37 PM   #16
llxll_jayson_llxll's Avatar
llxll_jayson_llxll is on a distinguished road
Re: Spark Plugs
Just a noon question, why are you gapping the plug at .044 when toyota recommends a gap of no more than .032--wouldnt that create less efficiency?
llxll_jayson_llxll is offline   Reply With Quote
Old 08-21-2008, 11:28 AM   #17
Re: Spark Plugs
Ok, I found this on the Denso web page. Now I'm getting confused
DENSO SPARK PLUGS
Old 08-21-2008, 11:35 AM   #18
Maryland Scikotics
wask0's Avatar
wask0 is on a distinguished road
Re: Spark Plugs
Good thread here, just wanted to chime in. I have a few bolt ons, headers, intake, etc. Should i still run the stock plugs or colder ones?
wask0 is offline   Reply With Quote
Old 08-21-2008, 11:49 AM   #19
Re: Spark Plugs
All I know is that I'm running a short ram intake and magnaflow exhaust with the stock plugs. I would remove your current plugs and give them a good look! How are they performing? nice amber color or sooty deposits?
Are they running to hot? Electrode burning away? It would be my guess that since we really can't make that much extra power with these engines that the stock replacements would be fine. (NGK/Denso any metal)
Old 09-24-2008, 11:41 PM   #20
FoGbOx is on a distinguished road
Re: Spark Plugs
i just went to autoparts store and picked up Bosch Platinum. just took it out of the box and put it in. no gapping no hastle just take old one out and new one in
FoGbOx is offline   Reply With Quote
rate my box, almost done
bB Pic Thread
Convert you car to run on water for $200?
"Not An xb" Bumper Sticker
Dragblock/balls - pics of whos got em!
some dirty new pics
Boso pipes!
With high SPIRITS the transformation begins........
Spark Plugs
I dont even know where to begin :(
Page generated in 0.31484 seconds with 13 queries
