Go Back   Scion xB Forum > Scion xB - Generations > 1st Gen: 2003 - 2007 Scion xB
Old 09-24-2009, 10:57 PM   #41
JDM is a way of Life . .
bippu is on a distinguished road
Re: Spark Plugs
using Denso IK16 Iridium Plugs 0.4 gap. got it for around 2,000.00 pesos roughly $42.00. Also using same for my Altis.
bippu is offline
Old 09-27-2009, 12:25 AM   #42
xPartyx's Avatar
Re: Spark Plugs
Originally Posted by Wookie384 View Post
USDM xB uses A .032 gap, not a .32. I myself use OEM Toyota Denso Iridiums (Toyota P/N 90080-91184 & Denso P/N SK16R11) which are gapped at .044 I did this because the JDM xB uses this gap, thats the Gap that the motor was originally designed for, I tried it out to see if it helps with my rough idle and it did, and I'm happy with it.
Bosch has caused a lot of Japanese cars I know of personally to fail smog here in So. Cal. when equipped with Bosch parts, So I do not use Bosch parts in Japanese cars. I only use Denso or NGK. Also, having more than one ground electrode is useless since electricity follows the path of least resistance, those 3 extra ground electrodes are just a marketing gimmick.
most helpful post in here. = thank you.
and finally, someone else agrees with me on that 4 electrode BS!
xPartyx is offline
Old 09-27-2009, 12:47 AM   #43
elusive_xb's Avatar
Re: Spark Plugs
Originally Posted by Rocket_Sciontist View Post
NGK iridium baby
thats all i use.... do it
elusive_xb is offline
Old 10-15-2009, 02:49 PM   #44
PINOY AKO !
bBxdjsiryan's Avatar
bBxdjsiryan is on a distinguished road
Send a message via AIM to bBxdjsiryan Send a message via Yahoo to bBxdjsiryan
Re: Spark Plugs
go to the dealer and get the sp. stock is always good
bBxdjsiryan is offline
Old 12-25-2009, 05:59 PM   #45
jeffinflorida is on a distinguished road
Re: Spark Plugs
I changed my plugs yesterday. My car is an XB 2006 w 25000 miles on it.
I went with Bosch +2 - $4.99 each at Autozone. Tell you the car seems to have a little more pep to it. Also put in a new pcv valve.
Easy as pie to put new plugs in. And yes, I used anti-seize lube on the threads.
Gonna take a raod trip soon so I tell you if the mileage changes in either direction. Been getting about 27 or so.
jeffinflorida is offline
bB Pic Thread
rate my box, almost done
some dirty new pics
Convert you car to run on water for $200?
Dragblock/balls - pics of whos got em!
"Not An xb" Bumper Sticker
Boso pipes!
Spark Plugs
With high SPIRITS the transformation begins........
My xB is quick, but not fast....I cured that.
Page generated in 0.14192 seconds with 12 queries
