09-25-2008, 12:00 AM
#21 | | Nor-Cal Balliztik
| Re: Spark Plugs To be honest i didn't like the NGK Iridiums. In my opinion they aren't that great. The next time I change my plugs I will try the bosche iridiums with 4 electrodes and see how that is. |
09-25-2008, 01:30 AM
#22 | | bB Squad
| Re: Spark Plugs i just switched to NGK V-power....no need for iridiums for me.... and gapped at .32 |
09-25-2008, 01:50 AM
#23 | |
| Re: Spark Plugs Quote:
Originally Posted by AirecK i just switched to NGK V-power....no need for iridiums for me.... and gapped at .32 | well aireck, how is it so far? any changes?
i hit 30k so im looking around for plugs |
09-25-2008, 03:32 AM
#24 | | bB Squad
| Re: Spark Plugs only difference i noticed was i was getting up the hills much easier..not struggling at all...
but i also changed the oil , filter, and finally put on that new ingen airfilter cone...
but yeah ... and were only $8+ for the 4 plugs..
oh and im at 72k..... and just switched to full syn..had it back in the day then switched to half syn now back on full..weird..damn dealership mis communication...lol!! |
09-25-2008, 07:43 AM
#25 | | Registered User
| Re: Spark Plugs [quote=AirecK;393192]
oh and im at 72k..... and just switched to full syn..QUOTE]
yeah I noticed a HUGE difference when going from dino oil to Mobil 1. sooo much of a smoother idle.
Seriously guys... just get the stock replacement. NGK brand. we have a 100 HP box and it doesnt ROCK. we dont have high compression, we dont have high HP, and most of us arent turboed, no need for colder plugs.
Platinum plugs and iridium plugs should come pregapped for your specific tolerances... the electrode is fragile and if you chip the plat or irid coating on it the plug is no good. |
09-25-2008, 09:20 AM
#26 | | Nor-Cal Balliztik
| Re: Spark Plugs tell that to NGK... They said Pre-Gapped i checked the gap and they were at .52 when they should have been, i believe it was like .30 something. Don't remember i just remember it being a biznatch to get back to the required gapping. |
11-30-2008, 08:35 PM
#27 | | Registered User
| Re: Spark Plugs I am running Denso Iridiums SK16R11 factory replacement from a 2000 Echo motor. Definately an improvement over factory plugs |
12-01-2008, 04:11 PM
#28 | | (Polar) White Toast
| Re: Spark Plugs |
01-02-2009, 12:14 PM
#29 | | Registered User
| Re: Spark Plugs [quote=mntegra01;393233] Quote:
Originally Posted by AirecK oh and im at 72k..... and just switched to full syn..QUOTE]
Platinum plugs and iridium plugs should come pregapped for your specific tolerances... the electrode is fragile and if you chip the plat or irid coating on it the plug is no good. | So which one is the stock replacement for the NGK brand? |
01-02-2009, 12:43 PM
#30 | |
Originally Posted by boxit So which one is the stock replacement for the NGK brand? |  |
01-10-2009, 01:06 AM
#31 | | Registered User
| Re: Spark Plugs I have over 75,000 miles on the Denso Iridium's and they work great |
01-10-2009, 01:56 AM
#32 | | mean green machine
| Re: Spark Plugs question -- i bought the cheap  ngk v power plugs and checked the gap and it was set at like .29 would it make a difference if i change the gap and what gap setting should i change it too
thanks |
01-10-2009, 03:32 AM
#33 | | Registered User
| Re: Spark Plugs Just FYI, I think it was already mentioned by someone earlier, but you should always check the gap on new plugs. Just because they say they are pre-gapped, doesn't mean that they are correct. It's been my experience to have at least 1 out of 4 plugs to be out of spec straight out of the box. |
01-10-2009, 03:07 PM
#34 | | Registered User
Originally Posted by trinixb question -- i bought the cheap  ngk v power plugs and checked the gap and it was set at like .29 would it make a difference if i change the gap and what gap setting should i change it too
thanks | that is fine
.44 for iridium |
05-18-2009, 09:28 PM
#35 | | Registered User
| Re: Spark Plugs NGK Iridium fan here also... |
05-22-2009, 11:53 PM
#36 | | Registered User
| Re: Spark Plugs So how much do they differ in price compared to performance? |
05-23-2009, 02:02 AM
#37 | | Registered User
Originally Posted by 06xbox I am running Denso Iridiums SK16R11 factory replacement from a 2000 Echo motor. Definately an improvement over factory plugs | what gap you running these at? |
05-23-2009, 08:41 AM
#38 | | Turbo charged Toaster
| Re: Spark Plugs Just about to reach my 30k mark. Any suggestions for a turbo'ed xb? I should probably be running a cooler plug. |
06-20-2009, 01:02 PM
#39 | | Registered User
Originally Posted by sciond I have over 75,000 miles on the Denso Iridium's and they work great | now over 90,000 |
06-28-2009, 10:49 PM
#40 | | Race car builder
| Re: Spark Plugs USDM xB uses A .032 gap, not a .32. I myself use OEM Toyota Denso Iridiums (Toyota P/N 90080-91184 & Denso P/N SK16R11) which are gapped at .044 I did this because the JDM xB uses this gap, thats the Gap that the motor was originally designed for, I tried it out to see if it helps with my rough idle and it did, and I'm happy with it.
Bosch has caused a lot of Japanese cars I know of personally to fail smog here in So. Cal. when equipped with Bosch parts, So I do not use Bosch parts in Japanese cars. I only use Denso or NGK. Also, having more than one ground electrode is useless since electricity follows the path of least resistance, those 3 extra ground electrodes are just a marketing gimmick. |
