Old 10-27-2009, 03:45 AM   #1
RCRat is on a distinguished road
Interior Painting Problem
Okay so I started to paint my interior pieces with that new "Fusion" plastic paint....Well, When I painted it on I started with a thin white base coat to really bring out the green I was going to coat it with and then afterward I added about 4 coats to the pieces and it looks nice...but not shiny!! Kinda dull looking...
So I hit my A/C controls with a quick final coat and BAM! they shined!! So I hit my shifter ring (silver piece) and BAM! shined right up!!! I hit my window control piece again and DAM! it crinkled up and it is ruined....
Any ideas as to why it crinkled up and why some pieces are shining and others aren't?
RCRat is offline   Reply With Quote
Old 10-27-2009, 08:15 AM   #2
CausaMortis is on a distinguished road
Re: Interior Painting Problem
I'm goin through the same thing except my crinkled up piece is the piece inside the shifter ring. That's also the piece that I didn't sand very well bc of the lines that run through it. Not meaning to sound like a smart a** but are you prepping and sanding? I work my way up from 120 to 600 grit right now but I would recommend goin up to 1500 grit. Let me know how it works out bro, me and you are doin the same project right now
CausaMortis is offline   Reply With Quote
Old 10-27-2009, 12:35 PM   #3
Suspension Whore
859Toaster's Avatar
wasn't clean. There was an oil or chemical on them. You should always wet sand, and clean before painting. I don't care what the can says.
Old 10-27-2009, 04:38 PM   #4
bullybull's Avatar
bullybull is on a distinguished road
^^^ yup. Wet sanding is great to do. When I did mine I wet sanded and then cleaned them with rubbing alcohol to make sure they were clean before paint.
bullybull is offline   Reply With Quote
Old 10-27-2009, 05:01 PM   #5
Just let your soul glo...
uprising's Avatar
or another option is to take it to a shop and pay them to do it!
Old 10-27-2009, 07:14 PM   #6
Mother Lover...
Armor-All, it is most likely the problem. Needs to be cleaned off really good.
Old 10-27-2009, 09:52 PM   #7
I guess nobody actually read the thread...But, this was like the 5th coat of green after said base coat of white...my problem was not re4lated to the plastic being clean otherwise it would have happened during the initial white base coat or the 2nd or 3rd green coat.
So it being clean is not the problem...and yes I did clean said pieces with denatured alcohol and made sure it was completely dry, prior to painting.
No sanding is required with Fusion paint...according to the can it bonds without sanding.
Old 10-27-2009, 09:58 PM   #8
Pippy Longstocking is hot
shortbus_8's Avatar
x2 contaminant , the oil form your fingers can reak havock and you not even know its on there
i clear all parts to be painted with rubbing alcohol
shortbus_8 is offline   Reply With Quote
Old 10-28-2009, 04:08 PM   #9
06 TCM xB-RS
gravebox's Avatar
ACTUALLY
because you used your AC on the final coat, it caused the paint to stretch from condensing it's self from the cold. as soon as the warm air hits it, it expands and beging to rinkle or even bubble. bubbling will happen more of the piece wasn't cleaned or you handeled them without latex gloves on *skin oils penetrate the paint and doesn't allow it to dry properly*.
the best thing to do for a flat paint like that is to simply get a can of clear coat which will give it a clear and protective shine.
Old 10-28-2009, 09:47 PM   #10
Originally Posted by gravebox View Post
ACTUALLY
Check this out....I start repainting my window controls piece and this time I kept the spray can in the house during coats (kept can warm) and every coat is nice and shiny!!! So I learned that temp does play a huge factor in painting.....
Old 10-28-2009, 10:00 PM   #11
Mother Lover...
I work at a Bodyshop, but good luck with your problem. Next time, get it done right.
Old 10-28-2009, 10:04 PM   #12
Yeah, that's why I said "according to the can"...I agree with you...I should have sanded; between each coat too...yes?
Old 10-28-2009, 10:08 PM   #13
Mother Lover...
My interiors:
Always sand before your first coat, red scotch brite works great.
Best JDM Parts
let's see those dash kits
Show us ur shift knobs.
Steering Wheel Show Off!
Black Headliner, Pillars
LED dome light. . .
Door Panel Showoff...
Page generated in 0.22435 seconds with 13 queries
