Old 09-15-2006, 02:35 AM   #1
iheartmyxb's Avatar
iheartmyxb is on a distinguished road
Send a message via AIM to iheartmyxb
Having Problems!
Ok I Have Been Having Problems With M Yxb Its Really Really Weird And Was Wonderin If Any Of U Have Any Suggestions..
Ok Everyonce In A Whiel My Traction Control Check Enginelight And Tcs Or Some Other Botton Comes On
After A While It Will All Be Ok ..
But Give It Some Time Then The Traction Control Go's Out With Check Engine Light On And The Other Botton
What The Hck?
I'm Trying To Get To The Bottom Of This!
iheartmyxb is offline   Reply With Quote
Old 09-15-2006, 02:38 PM   #2
iheartmyxb's Avatar
dang does anyone know!?!?! seriously this is ridiulous
Old 09-15-2006, 02:58 PM   #3
the brave little toaster's Avatar
the brave little toaster is on a distinguished road
Send a message via AIM to the brave little toaster
traction control, vsc and check engine?
sounds dumb but have you checked to make sure your gas cap is tight?
the brave little toaster is offline   Reply With Quote
Old 09-15-2006, 03:00 PM   #4
would also check to make sure your wheel speed sensors arent grubbed up and theres no metal flakes that would alter the magnetism. that and they are fully plugged in
Old 09-15-2006, 05:29 PM   #5
scikotics
Mad_Sciontist's Avatar
Mad_Sciontist is on a distinguished road
Send a message via MSN to Mad_Sciontist Send a message via Yahoo to Mad_Sciontist
yep what he said. First check your gas cap. Also I've heard if you top off your tank it can cause these problems also. Not sure way that is. Just heard from someone on this site said he had that problem. Good luck
Mad_Sciontist is offline   Reply With Quote
Old 09-15-2006, 05:43 PM   #6
iheartmyxb's Avatar
thanks ok i'll check the gas cap but i dont know what the numberr 2 one is really saying.
Old 09-16-2006, 04:16 AM   #7
iheartmyxb's Avatar
ok gas cap wasnt the problem.. =(
help me fix it..
Old 09-16-2006, 08:30 AM   #8
HORNBLASTER
madmaxb's Avatar
madmaxb is on a distinguished road
Do u have a air intake on ur xb . If so go and make sure ur all ur clamps are tight on it and maybe try checkin ur mass air flow sensor. If ur ur tripin ur check engine light u may try goin to auto zone and see if the have a scanner for codes .I know auto zones down here will come out put there scanner on ur car for free and tell u what code it is. If u get a code number u can post it on here im sure some of us on here will be able to help ya out or at least tell ya were to look for the problem.
madmaxb is offline   Reply With Quote
Old 09-16-2006, 08:44 AM   #9
backseatchris's Avatar
It could be a c1201 engine control system malfunction
a poo12 camshaft malfunction.
should be under warranty
backseatchris is offline   Reply With Quote
Old 09-16-2006, 11:49 AM   #10
2nd gen xB
dsimes's Avatar
dsimes is on a distinguished road
Send a message via Yahoo to dsimes
help me fix it..
how many starts/stops did you have since you checked the gas cap?
it usually takes as many as 5 start/stops for the light to go out.
dsimes is offline   Reply With Quote
Old 09-16-2006, 12:58 PM   #11
youngguy is on a distinguished road
Is your car under warranty? If so I would let the Scion shop check it out. Barn
youngguy is offline   Reply With Quote
Old 09-16-2006, 03:13 PM   #12
iheartmyxb's Avatar
its underwarranty yes
um i think i've hit that 5 start/stops.
i dont have an intake.
so i dont know what the problem could be this is just insane!
Old 09-16-2006, 07:36 PM   #13
iheartmyxb's Avatar
anymore suggestions..?
Old 09-16-2006, 08:07 PM   #14
scikotics
Go out get in your box and push the odometer button in and hold it in while you turn your key to the on position. That should reset it if that is the problem. If that's not it take it to the dealer. Hope this helps.
Old 09-16-2006, 08:35 PM   #15
^^ what he said will do nothing.
thats just a maintenance light that ur resetting. dont do that
Old 09-16-2006, 08:58 PM   #16
iheartmyxb's Avatar
haha ok then what do i do!
Old 09-16-2006, 09:15 PM   #17
this is a warrenty covered problem. take it to the dealer. have em hook up the mastertech, find out the real problem.
Old 09-16-2006, 09:48 PM   #18
scikotics
My bad. I mis read I thought she said she hit the 5,000 mile thing. I see she said the 5 stop/start thing. Brain dead today I guess.
Old 11-01-2006, 08:24 PM   #19
hectik's Avatar
hectik is on a distinguished road
Send a message via AIM to hectik Send a message via Yahoo to hectik
im having the same problem with the check engine light and the vsc and the traction control light on the dash, i tried taking out the short ram intake and installing a cold air, but after i was done all the lights apeared on the dash! plus my engine is bogging like crazy at 1500rpm, does anyone no if the maf is the problem?
hectik is offline   Reply With Quote
Old 11-01-2006, 09:15 PM   #20
HORNBLASTER
madmaxb's Avatar
sounds like check maf connector then check make sure all ur clamps are tight with no air leaks listen for air being sucked in some were not suposed to be
clutch problems popeye General Scion xB Discussion 14 12-05-2006 03:57 PM
Rear Tailight Problems. DJArchngl Scion xB Audio, Video, & Security 7 08-25-2006 08:57 AM
Radio and A/C problems azztinthebox Scion xB Audio, Video, & Security 7 08-22-2006 09:02 AM
Problems with local dealership Tigerlily General Scion xB Discussion 10 07-02-2006 02:18 AM
attached image problems Dajap Website Discussion 13 03-14-2006 05:51 PM
Best JDM Parts
let's see those dash kits
Show us ur shift knobs.
Steering Wheel Show Off!
Black Headliner, Pillars
LED dome light. . .
Door Panel Showoff...
Page generated in 0.25434 seconds with 14 queries
