Old 03-07-2006, 05:36 PM   #1
Fix for loose factory arm rest
I posted this on "the other" website so I thought I'd put it here too. If your arm rest seems loose after removing the seats or the arm rest, the wire clamp may have slid off of the groove that holds it in place.
Here's how to fix it quickly.
The arm rest is actually two pieces. One mounts to the center console with a metal wire clamp that hooks under the seat rails.
The other mounts on top of the base and is held on by one screw on the back of the arm rest pillar.
Remove that screw, lift up on the arm rest, remove the top unit and you'll see the bottom (base) unit with the metal wire clamp.
If this is not seated, the arm rest will not be anchored and will be loose.
To reconnect the metal wire clamp, use a flat screwdriver and pry the wire clamp back on top of the pillar, making sure to seat the clamp wire in the groove provided.
Now that the base piece is attached,
replace the top piece with the arm rest and reinstall the screw. You're done.
surfcitylocal is online now   Reply With Quote
Old 03-07-2006, 05:43 PM   #2
Dew
Egistered Ruser
Dew's Avatar
Dew is on a distinguished road
Send a message via Yahoo to Dew
thanks for the tips, I will keep that in mind next time I tear my stuff apart
Dew is offline   Reply With Quote
Old 03-07-2006, 06:00 PM   #3
Might save a little time. I didn't take the two pieces apart when I pulled the seats out but from moving the arm rest out of the Box it dropped the wire clamp and it took me a minute or two to figure out why it wasn't holding in place. Hope someone else can benefit from my ooopsie!
Old 03-08-2006, 02:11 AM   #4
Who am I to say this?
boxd_up_2's Avatar
Location: I have no Idea, but I bet I could Google it...
boxd_up_2 is on a distinguished road
I'm friggin pissed, the dealer neglected to install that wire piece on mine, so mine is loose as hell. Didn't even know that piece existed.
boxd_up_2 is offline   Reply With Quote
Old 03-10-2006, 12:35 AM   #5
Spiderbox is on a distinguished road
i installed the armrest myself
dang i'm an idiot i just used all my strength to pull that wire harness up and over onto that groove almost tore off a damn fingernail.
*note to self : screwdrivers work better than fingers
Spiderbox is offline   Reply With Quote
Old 03-10-2006, 08:45 AM   #6
Like my Daddy always told me..."work smarter, not harder".
Old 03-15-2006, 04:28 PM   #7
Skeeter's Avatar
I hear ya surf city.
Old 03-15-2006, 05:17 PM   #8
good thinkin surfcity i just went with "if you're in a hole you'll have to dig your way out"
Old 03-16-2006, 08:51 AM   #9
My Grandpa used to always tell me "if you find yourself in a hole, stop digging".
Old 03-21-2006, 08:15 PM   #10
Point_Oh's Avatar
Point_Oh is on a distinguished road
surfcitylocal,
Do know how to take the rest of the center console out?
Point_Oh is offline   Reply With Quote
Old 03-21-2006, 11:42 PM   #11
Originally Posted by Point_Oh
surfcitylocal,
It's easy. If you don't have a center arm rest, remove the rubber liner in the rear cup holder. You'll find a screw in the bottom, take it out. Pull up on the console at the front by the cup holders. It will take just a little effort but the console will "pop" loose and you can take it off from there.
If you do have a center console you may or may not have the screw in the bottom of the rear cup holder depending on how your dealer installed it. If there is no screw just go to the front of the console and pull up. You'll find once it is loose that you have to work it around the e brake. It will be self evident at this point.
Good luck.
factory deck advice Dew Scion xB Audio, Video, & Security 1 02-27-2010 12:51 AM
factory tire size? backseatchris Scion xB Wheels & Tires 14 11-15-2009 02:29 AM
WTB OT: 06' factory deck Dew Wanted Scion xB Parts and Vehicle 16 08-21-2006 03:40 PM
How many factory colors on the xB? hubbard Scion xB Appearance 6 03-06-2006 12:07 AM
XB factory rear hatch spoiler thunder67 General Scion xB Discussion 14 02-21-2006 08:13 PM
Best JDM Parts
let's see those dash kits
Show us ur shift knobs.
Steering Wheel Show Off!
Door Panel Showoff...
Black Headliner, Pillars
LED dome light. . .
Page generated in 0.23623 seconds with 14 queries
