Old 04-02-2006, 12:09 AM   #1
Anybody else screw up the A/C?
Since I installed my new stereo a month ago or so my A/C keeps blowing a fuse when I turn it on. I took the stereo out today and checked all my wire runs. I found no bare wires or unwanted grounds. I traced the wires from the A/C switch as far as I could but found no cuts or crimps. I am assuming it didn't stop working on it's own but so far I haven't been able to find any wiring goofs that would cause it to blow a fuse. Any suggestions?
I took it to the dealer the other day but they said they couldn't check it out unless I wanted to pay 280 bucks for diagnostics since I've installed after market electrical devices to the Box.
Help? Please?
Oh, there are no other electrical problems besides the A/C. Everything else works fine.
Old 04-02-2006, 12:19 AM   #2
mORON mODERATOR
Cravin's Avatar
Did you try disconnecting your stereo power leads and amp power leads then trying your A/c?
Cravin is offline   Reply With Quote
Old 04-02-2006, 12:24 AM   #3
Yup. Still blew a fuse. That's the part I can't figure out. If I don't have anything tied into the A/C power or ground how is it blowing? My brain hurts.
Old 04-02-2006, 12:33 AM   #4
mORON mODERATOR
Cravin's Avatar
You need a schematic to troubleshoot further.
Old 04-02-2006, 12:35 AM   #5
mORON mODERATOR
Cravin's Avatar
diconnect the A/C comressor clutch and see if it still blows the fuse. Does the fuse blow when you push the a/c button on or just turn the cabin fans on?
Old 04-02-2006, 12:35 AM   #6
Yeah, I'm gonna take a look again in the morning. The majority of the wire is inside of wire wrap so it makes it tough to trace out.
Old 04-02-2006, 12:36 AM   #7
Only when the A/C button is pushed. The fan switch works fine.
Old 04-02-2006, 05:48 PM   #8
Problem solved. With great confidence and a v/o meter I set about to fix my A/C problem today. I carefully removed the center console, dash and stereo, then removed the entire stereo from the dash. I removed the iPod interface unit and connecting cables. I checked every visible inch of wiring in the dash and found absolutely no cuts, nicks or smashed pieces. I carefully put everything back together and installed a new fuse. With much trepidation I inserted the key and turned it. I reached out to turn on the cabin fan switch and depress the A/C button...and the damn thing worked!!!!!!
I have no friggin' idea why but now the thing works fine. I guess I must have scared the Gremlins out of the dash wiring or something.
Happy Happy Joy Joy
Old 04-02-2006, 06:35 PM   #9
ChromiumSteel's Avatar
ChromiumSteel is on a distinguished road
Send a message via AIM to ChromiumSteel
I spent 14 years in a paper mill. The first thing the electricians would do when they had to come fix a problem, was bang on whatever it was that was acting up.
ChromiumSteel is offline   Reply With Quote
Old 04-02-2006, 06:54 PM   #10
ThunderGod's Avatar
thats called, certified tech's baby! =)
at least they came out to check the whatchumacallit, after you put in a request 9 months ago. lol
Old 04-02-2006, 11:44 PM   #11
Who am I to say this?
boxd_up_2's Avatar
Location: I have no Idea, but I bet I could Google it...
boxd_up_2 is on a distinguished road
If all else fails...use a bigger hammer!!!
boxd_up_2 is offline   Reply With Quote
Old 04-02-2006, 11:46 PM   #12
Sounds like a FORD mechanic.
Old 04-02-2006, 11:47 PM   #13
boxd_up_2's Avatar
Ewww...FORD...get it off...get it off...lol
Old 04-02-2006, 11:49 PM   #14
FORD:
Found On Road Dead
Fix Or Repair Daily
Figure On Repairs Daily
Old 04-02-2006, 11:51 PM   #15
boxd_up_2's Avatar
FORD:
Found On Road Dead
Fix Or Repair Daily
FORD backwards:
Driver returns on foot.
Hear about the new F150, it's got a heater in the tailgate...That way the owner can keep his hands warm while he pushes it in the winter...lmao
Old 04-02-2006, 11:55 PM   #16
FORD backwards:
Awesome! ROTFLMAO
Old 04-03-2006, 01:33 AM   #17
Tomas's Avatar
Glad it's 'fixed.' Hope it stays that way.
Like to mention one thing, though: "...diconnect the A/C comressor clutch and see if it still blows the fuse..." - the xB doesn't have a compressor clutch. I has a variable displacement compressor - the compressor shaft always turns.
Tomas is offline   Reply With Quote
Old 04-03-2006, 02:21 AM   #18
Rvg2151's Avatar
Rvg2151 is on a distinguished road
I Had This Problem When Installing Leds.
Look For The White Squareish THing Behind The Middle Ac Control Knob.
Is There A Spring Missing?
If Not The Greased Up Knob Behind The Spring Is Probable Unsyncronized, That Can Cause The HVAC To Blow.
$1 Dollar Part That Can Cause $100 Damage.
Good Thing Mine Was Under Warrenty.
Rvg2151 is offline   Reply With Quote
Old 04-03-2006, 08:47 AM   #19
I've still got the spring in mine. I think there must have been a pinched wire that I just couldn't see.
When you went to the dealer to get the spring replaced how did you explain it not being there? Didn't they try to get out of a warranty fix by saying that you did it?
Old 04-03-2006, 11:33 AM   #20
sid
sid's Avatar
Glad you solved it. I have taken off my middle dash including the radio for 6-10 times(intall 06 radio, leds,etc). Lucky i did not have this kind of problem.
sid is offline   Reply With Quote
Removing the Center Dash Trim surfcitylocal Scion xB Interior 10 04-12-2007 10:19 PM
Best JDM Parts
let's see those dash kits
Show us ur shift knobs.
Steering Wheel Show Off!
Door Panel Showoff...
Black Headliner, Pillars
LED dome light. . .
Page generated in 0.28133 seconds with 14 queries
