Old 10-07-2009, 04:41 PM   #1
devodem's Avatar
devodem is on a distinguished road
Send a message via Yahoo to devodem
airbag light, vsc and traction control light????
I just install my new NRG hub and quick release but know my airbag light, vsc light and traction control light are on. Does anyone know how to turn them off?
devodem is offline   Reply With Quote
Old 10-07-2009, 04:44 PM   #2
Todd2die4's Avatar
Todd2die4 is on a distinguished road
Re: airbag light, vsc and traction control light????
Todd2die4 is offline   Reply With Quote
Old 10-07-2009, 08:51 PM   #3
devodem's Avatar
thanks will this also work for the VSC and traction control?
Old 10-07-2009, 09:15 PM   #4
Todd2die4's Avatar
talk to PCH or gravebox
theyre like the master techs here
Old 10-07-2009, 09:33 PM   #5
OK, what did you do with the airbag's spiral cable assembly that goes under the steering wheel? If you had to remove it to install the NRG hub then you lost the Steering Wheel Position Sensor and that's why your Trac/VSC light is On. For SRS (airbag) light you need to do resistors instead of the airbag you don't have anymore, like Todd2die4 said.
Old 10-08-2009, 06:15 AM   #6
devodem's Avatar
Is there a way to get rid of the Trac/VSC light?
Old 10-08-2009, 10:26 AM   #7
What's your answer about the spiral cable? If you took it out then VSC/Trac system will not work right and all you can do is tape over the light or take the LED out. No such problem when using MOMO/Sparco hubs BTW.
Old 10-08-2009, 02:27 PM   #8
devodem's Avatar
Yeah i had to remove it when putting in the NRG hub.
Old 10-08-2009, 02:53 PM   #9
Unless there is some way to mod the NRG hub or spiral cable to work with each other - nothing you can do but simply cover the lights. Or switch to a different hub.
Old 10-08-2009, 09:25 PM   #10
devodem's Avatar
Damn that sucks.......
Old 10-10-2009, 05:22 PM   #11
devodem's Avatar
I tried the DIY: Airbag Delete Resistors but that did work. I followed it to a T but still nothing.
Old 10-10-2009, 05:26 PM   #12
Eav10xB's Avatar
yeah you need to put that traction control back on, because it is scary when you are driving down the street and you try and turn and that shit kicks in you are screwed happened to Yellow_sub and myself driving home from the gym one day. effin scary bro.
Eav10xB is offline   Reply With Quote
Old 10-10-2009, 07:07 PM   #13
devodem's Avatar
You went back to your stock steering wheel?
Old 10-10-2009, 11:17 PM   #14
Air Bag and Trac/VSC/ABS are totally different systems. The reason yor SRS(Air Bag) light came on is because you lost the airbag in the steering wheel. Installing resistors in the harness will take care of that light.
The reason you have VSC/Trac lights is because you took the spiral cable assembly out and it contains the Steering Wheel Position Sensor. No way around that one.
You can run aftermarket steering wheel using MOMO/Sparco hub and still have the spiral cable in place, so no warning lights will be on as long as you have done the resistors.
Best JDM Parts
let's see those dash kits
Show us ur shift knobs.
Steering Wheel Show Off!
Door Panel Showoff...
Black Headliner, Pillars
LED dome light. . .
Page generated in 0.23323 seconds with 13 queries
