Old 03-19-2008, 08:34 PM   #1
Thunderstruck's Avatar
Thunderstruck is on a distinguished road
TYC tails install
ok...so i went to go and install the tails into my xbox...
readin the directions, it calls for the battery to be disconnected....uhm...WHY????
do i have to worry about a short going back to the box?...it says to disconnect only the negative connector also...trouble is, its locked on there freakin TIGHT...even using a wrench to try to take it off, and it doesnt want to budge...
so do i really need to remove it?...anything i need to worry about wiring?...it looks like a simple swap out...
Thunderstruck is offline   Reply With Quote
Old 03-19-2008, 08:39 PM   #2
Grrr
monsterslovecandy's Avatar
monsterslovecandy is on a distinguished road
Re: TYC tails install
I didnt disconnect my battery and it went fine.
monsterslovecandy is offline   Reply With Quote
Old 03-19-2008, 08:59 PM   #3
Moved to 1st Gen Lighting & Electrical.
Old 03-19-2008, 09:25 PM   #4
Pensacola Scikotics
FLNurse67 is on a distinguished road
Send a message via AIM to FLNurse67
When I rearranged the lights in my TYC lights I didn't disconnect the battery and everything was fine as well.
FLNurse67 is offline   Reply With Quote
Old 03-19-2008, 09:29 PM   #5
crxgames's Avatar
I've changed my tails several times and never disconnected once. I run a set of tails of which maybe 4-5 sets are in the US and didn't even bother. No issues at all.
Old 03-19-2008, 11:06 PM   #6
simijoecool's Avatar
dont need to disconnect it. ull be fine
Old 03-20-2008, 12:43 AM   #7
Location: Honolulu, HI, USA (50th State/1959 Statehood)
hawaiiguy is on a distinguished road
same here...no need to disconnect battery..
hawaiiguy is offline   Reply With Quote
Old 03-20-2008, 06:25 AM   #8
ok thanks guys...before and after pics will b up by the weekend im hoping unless this cold continues...
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
DIY: Removing Tail Lights
aftermarket headlights
"B-Pillar" lights
Luminics Bulbs
Page generated in 0.16310 seconds with 13 queries
