Old 11-01-2009, 12:04 AM   #41
Re: LED Reverse Lights and More
Originally Posted by rcarmchl View Post
care to elaborate on how to do that?
Alligator clip goes to the Red/Y and probe the Blue/Y (may have to use a paper clip to connect better). Do this with the relay still connected and then disconnect the relay and test again. If the relay is good you should get the light that will dim after few sec and with disconnected relay there should be no light at all.
Old 11-01-2009, 07:00 PM   #42
ToRcHeD RS4 #274
DoWoRkJeRr's Avatar
DoWoRkJeRr is on a distinguished road
Originally Posted by RazoE View Post
nope, 1156 has a single filament at the bottom, 7440 is a wedge bulb, sort if like a big 194, like the license plate lights..
1156 will not fit...
well i got an RS4 if u cant tell by my profile pic. So i have the TYC Tails. i donno if the stock and TYC tails are the same bulbs but i mailed them these pix and they said that the bulb was a 1156 not 7440
TYC Reverse Light on the Right
DoWoRkJeRr is offline   Reply With Quote
Old 11-01-2009, 07:04 PM   #43
Supra dude here...
RazoE's Avatar
RazoE is on a distinguished road
awww, wasn't aware the TYC's were different. Yeah 1156's will work, I have LED 1156's based bulbs in my supras for the license plate lights, very nice..
RazoE is offline   Reply With Quote
Old 11-02-2009, 10:13 AM   #44
rcarmchl's Avatar
rcarmchl is on a distinguished road
OK - I may not have done it right then.
I grounded a wire and connected to the B/Y wire and got light - relay connected.
Same set up but connected to the R/Y wire and got nothing - with door open and closed.
Are you saying I need to connect it to both the blue and red wires to test? When I do that I get full power but no dimming with the relay connected.
rcarmchl is offline   Reply With Quote
Old 11-02-2009, 11:19 AM   #45
Now disconnect the relay and see what happens. There should be no more light. If there is- that means wire from the dimmer somehow melted and touching the ground.
Old 11-02-2009, 11:31 AM   #46
rcarmchl's Avatar
alright, I'll give it a go later today...thanks for the help.
Old 11-04-2009, 06:52 PM   #47
rcarmchl's Avatar
ok, with the relay disconnected i get nothing on a standard bulb....
JACKPOT...Upon further inspection I decided to pull the relay board out, circuit FRIED...I'll post pics tomorrow.
Old 11-04-2009, 07:03 PM   #48
You are still very lucky that relay operates your locks. Are you getting a new one?
Old 11-04-2009, 07:08 PM   #49
rcarmchl's Avatar
Well, since that happened I have noticed the locks sounding weak, but yeah I am getting a new one. Well, new to me, I found a used one with about 40k on it for 35 bucks...a whole lot better than the $428 the dealer quoted me.
Old 11-04-2009, 07:23 PM   #50
Great deal. I've heard many stories of people frying theirs. Any time you play with the dome light is a gamble.
Old 11-04-2009, 07:32 PM   #51
rcarmchl's Avatar
see, thats what irks me about it, I didn't change anything other than the bulb...just installed the smd led panel from oznium, the wires melted and cause the board to fry.
I have since purchase the festoon type bulbs from superbrightleds.com so I have no wires to worry about.
on another note - is ssuperstore.com still in business? or are they just really slow to respond?
Old 11-04-2009, 07:39 PM   #52
The stock bulb in the dome light draws 0.5 Amp. How much more can the relay handle safely nobody knows. I think the LEDs overheated and melted the base and something just shorted. The fuse that blew is 15 amps- no way the relay can handle even half that.
Old 11-04-2009, 07:47 PM   #53
rcarmchl's Avatar
I am pretty sure that the relay blew before the fuse went, when I lost my radio and replaced that fuse I fipped the switchon the dome light which threw sparks, that panel has a wire lead that runs to the festoon replacement, I am pretty sure that the switch caught the wire and pinched it against the metal runner inside the dome light - leading to the short in the wire leads and the overload on the relay.
Moral of the story is that I won't be using anything with wire leads in the dome lights.
Old 11-05-2009, 09:33 AM   #54
rcarmchl's Avatar
heres the relay...
Old 11-05-2009, 11:50 AM   #55
ToRcHeD RS4 #274
DoWoRkJeRr's Avatar
so i got my new LEDs yesterday...
http://autolumination.com/images/aut...1157m2w_wm.jpg
connection was finaly the right one but when i went to install it, the head of the LED was JUST BARLEY TOO WIDE... when i say jus barley i mean like "Paper Thin" too wide. i tried everything, but take the lens off the tail.
IM SOOO PISSED. so i jus returned...
Old 11-05-2009, 01:26 PM   #56
Supra dude here...
RazoE's Avatar
you can sand off a litttttle bit of the opening, but not enough so the socket will not lock..
Old 11-05-2009, 01:45 PM   #57
ToRcHeD RS4 #274
DoWoRkJeRr's Avatar
i was thinking that too but i said screw it... im looking at these now... think these will fit? 18 High Power Tower LED 1156 Style
Super Bright LEDs - Error Page
i jus donno the difference when it says CW and WW...
Old 11-05-2009, 02:23 PM   #58
Supra dude here...
RazoE's Avatar
they work, but they're not as radiant straight forward and illuminate sideways more..
for reverse lights, you want as much direct light as possible, especially if you live on a busy street the way I do..
I'd go with these..
"67-x15 LED bulb " they're 67 bulbs, but they have the same base as an 1156 bulb, but smaller..
if you watch this vid I made of my 92 Supra to show the blinker mods, you can see the EXACT same bulbs in my license plate lights..
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
they would actually be brighter if they were facing out, but they mount almost parallel to the ground, so you can imagine if they faced directly out...
Old 11-05-2009, 09:28 PM   #59
ToRcHeD RS4 #274
DoWoRkJeRr's Avatar
AHH!! VERY NICE!! thanks soo much. i saw this but i saw the 65 so i thought it was gonna be a Tiny bulb. ima order them tonight.
Old 11-12-2009, 09:46 PM   #60
ToRcHeD RS4 #274
DoWoRkJeRr's Avatar
Third Set is the Charm! lol. here ya go.
STOCK DAY/LED DAY
STOCK NIGHT/LED NIGHT
COMPARE
lemme know what u think!
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
aftermarket headlights
"B-Pillar" lights
DIY: Removing Tail Lights
Luminics Bulbs
Page generated in 0.28589 seconds with 15 queries
