Originally Posted by yellow_sub um ok let me be more spacific. there are 3 led in each headlight. the wires comming out splice down into a total of two wires. one is black and the outer is yellow. the black one is the ground and th yellow one is where i'm stuck. i want it to go to a rocker switch so i can turn it on from under the hood. if you guys need pics let me know. thanks! |
When you say you want turn turn it on from under the hood, do you mean you want to mount the switch under the hood? I mounted Tammie's LED switch next to the factory fog lamp switch and just used the cigarrete lighter for power. You can always tap right off the battery using a lead with an inline fuse too, that would be really simple and save the trouble of having to run wires through the firewall, or tap off the battery for power and run only the ground wire through the firewall to a dash mounted switch.
Really simple to do and there are lots of options.
