Old 11-18-2009, 11:26 PM   #21
RS4 #303
sdsnybny's Avatar
Re: HID - Bi-Xenon help
Here is a good u-tube of an install on a Yaris go through it and compare it will be the same wiring as ours.
YouTube - Xenon-Vision Bi-Xenon HID Install
Old 11-18-2009, 11:31 PM   #22
rcarmchl's Avatar
rcarmchl is on a distinguished road
ok, so going to hidextra's site...the bulbs they show as replacements do not work the same as mine. My kit also says 12v...24v on the backside as well
i watched that before I did the install, the only difference I see is the that his harness has grounds at the balast and mine does not. That appears to be the main difference in the two and the diagram referenced by the mfg for install.
Guess all I can do is wit till tomorrow am and call them.
rcarmchl is offline   Reply With Quote
Old 11-19-2009, 12:00 AM   #23
RS4 #303
sdsnybny's Avatar
Good luck tomorrow, wish I was closer I take a look at it. maybe in the morning it will look diff to you and the answer will come easy.
Old 11-19-2009, 01:48 PM   #24
rcarmchl's Avatar
i was hoping the same thing...too bad that didn't work out...
so I got a hold of hidextra's tech guy, tried a few things and determined that the wiring harness was bad - they sent a new one out - will update when it gets here. I was so looking forward to getting these in today. I cleared the headlights last night so I had the bumber off and heads out - made accessing a lot easier. oh well.
I am hopeful that its just the harness, its really gonna suck if I get the new harness and they still don't work!!!
Old 11-20-2009, 02:55 PM   #25
gravebox's Avatar
your ballasts shouldn't have a ground that you need to worry about. only the switching harness that controls the hi/lo beam switching has grounds on each end near the points that you connect the ballasts to. those you can easily just bolt to the two top core suport points on the top core suport piece.
Old 11-25-2009, 09:56 PM   #26
DoWoRkJeRr's Avatar
DoWoRkJeRr is on a distinguished road
sounds like something that would happen to me.
cant wait to see the pics. they are having a black friday sale till the 29th so hopefully i finally decide to buy a set. im looking at the 6000k ones tho.
DoWoRkJeRr is offline   Reply With Quote
Old 12-04-2009, 09:02 PM   #27
rcarmchl's Avatar
got mine installed today....will take pics tomorrow ..these suckers are bright as hell, definately gonna have to adjust the headlights a bit!!!
Old 12-04-2009, 09:06 PM   #28
migi23's Avatar
migi23 is on a distinguished road
Send a message via AIM to migi23 Send a message via Yahoo to migi23
Dont pull up behind a cop and get a ticket like me!!! ugh! no bueno
Migi23
migi23 is offline   Reply With Quote
Old 12-05-2009, 02:46 AM   #29
gravebox's Avatar
^^that's why we readjust them before even leaving the house
Old 12-05-2009, 10:34 AM   #30
migi23's Avatar
Can u readjust them when I got my pw it with HID so I dnt even know how to adjust them. How do u do it??? An did all of them have a high an low beam cuz it seams like mine are always high!!!
Old 12-08-2009, 05:11 AM   #31
gravebox's Avatar
there's a couple of round teethed adjusters on the back of the headlight housing that you use a philips head screw driver on to move clockwise or counter clockwise. this will adjust the lights vertically up or down.
Old 12-08-2009, 08:51 AM   #32
migi23's Avatar
Thanks!!! Can they all do low and high beam? Or do they all have different options? I am getting a lot of middle fingers when i drive at night lol!!!
Old 12-08-2009, 02:11 PM   #33
gravebox's Avatar
if you're running sonars, the outter lights are going to be your low beam and your inner lights are going to be your highbeam. this kind of setup though will more than likely not last though because our headlight relay isn't setup for a dual light operation and will cause damage to HID ballasts when you turn your highbeams on over time without the proper addon relay.
you could simply open the headlight up and replace the low beam lights or highbeam lights for Bi-xenon projectors and get a Bi-xenon harness addon for low/high beam operation without the worry of having any blown ballasts, bulbs or burnt wires. the left over low or high beam you didn't replace can be used for whatever you want with it's on switch on the dash or what have you and the setup would be much more reliable.
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
DIY: Removing Tail Lights
aftermarket headlights
"B-Pillar" lights
Luminics Bulbs
Page generated in 0.20539 seconds with 12 queries
