Old 03-08-2007, 06:21 PM   #1
chicagoXB is on a distinguished road
Help My Cupholder Lights Dont Work
I Cut The Switch On My Factory Cupholder Lights And Now They Dont Work Is Their A Fuse On Them Please Help
Thanx In Advance
chicagoXB is offline   Reply With Quote
Old 03-09-2007, 12:49 AM   #2
Thanx In Advance
Can you be a little more specific? You "cut" the switch on your lights?
Old 03-09-2007, 02:40 AM   #3
BoomBox's Avatar
Hey man, don't go stressin' out. It's alright. If you had the dealership install them, I know for a fact (since they did my dash/seat lightbars) that they do NOT use a lot of wire, and they can easily come from the switch if you move everything around too much.
Now, as with what Surfcitylocal said.....What do you mean by 'cut?'
Did you perhaps splice the wire to add more lights, did you cut the wire accidentally altogether and had to reconnect it?
Since they only use a single + and a single - on the switches, there's no way to get em mixed up, as long as the circuit closes it'll work.
Again though, PLEASE fill us in.
BoomBox is offline   Reply With Quote
Old 03-11-2007, 03:02 PM   #4
i cut the switch to move under the oven...and the wires touched
Old 03-11-2007, 03:34 PM   #5
BoomBox's Avatar
Well, lemme think. Ok, if you have the system to come on while the car is off, the only thing that shoulda happened is the lights would have flashed for a second. Basically a switch is a fancy way of splicing the wires (duh).
Anyways, unless you somehow blew out the system (if they're controlled by a box of sorts) then they should still work. Other than that, check your fuses, and worse comes to worse, replace em.
Old 03-11-2007, 07:03 PM   #6
thanx for the help ill look the a fuse when i have a day off
Old 03-12-2007, 12:28 AM   #7
Liesjemt's Avatar
We did that too awhile back when adding some lights awhile back.
Turns out there’s a small glass fuse down there.
Anyway, we managed to blow it.
I would check that.
So busted at work today...no more Club xB during work surfcitylocal Off Topic 31 06-25-2008 10:57 PM
Dont Try This Short_Bus_8 South West 10 02-06-2007 07:29 AM
Scion Armrest w/cupholder NIB unopened scvscions Scion xB Classifieds 1 10-15-2006 02:03 PM
dont click the game if you dont want to spend 5 hrs playing it. bB626 Off Topic 6 07-29-2006 02:41 AM
Cupholder solutions DrJWelch Scion xB Interior 45 06-19-2006 12:35 AM
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
DIY: Removing Tail Lights
aftermarket headlights
"B-Pillar" lights
Luminics Bulbs
Page generated in 0.16212 seconds with 14 queries
