Old 06-15-2006, 04:46 PM   #21
heathenbrewing's Avatar
Originally Posted by backseatchris
-i did not try the fuses themselves going different directions but i will.
That wont make a difference.
Im leaning towards a bad ground myself. Let me know how it turns out.
heathenbrewing is offline   Reply With Quote
Old 06-15-2006, 04:53 PM   #22
backseatchris's Avatar
i use the neg on the battery....but i have a pretty good ground on the car. its on a screw @ the parking brake. I really think the problem is that its not getting enough power
backseatchris is offline   Reply With Quote
Old 06-15-2006, 05:07 PM   #23
It would be quick and easy to check to be 100% sure though.
Old 06-15-2006, 05:10 PM   #24
Big_Kokujin's Avatar
So Taz, just to make sure; i can lenthen the +/- but not the wires after the in/converter right?
Old 06-15-2006, 05:13 PM   #25
You get a yes vote from me anyway.
Old 06-15-2006, 05:22 PM   #26
DodgerGirl's Avatar
DodgerGirl is on a distinguished road
Hey Taz, how much do you charge?
DodgerGirl is offline   Reply With Quote
Old 06-15-2006, 05:26 PM   #27
where is a good place to ground a wire?
the connection with the ground wire and the ring terminal is very tight and the connection with the ring terminal and the screw holding it in place is very tight.
What could i do to ground it any better? Just curious, maybe im forgetting something
Old 06-16-2006, 12:33 AM   #28
You can lengthen the wires after the converter provided you are using the 4 inch cold cathodes and do not extend it beyond another 5-6 inches. Any further and the light output will dim.
surfcitylocal is online now   Reply With Quote
Old 06-16-2006, 12:37 AM   #29
You will do best using a ground point that is already in place. You can find them throughout the vehicle. Scion uses white wires for the grounds. You'll notice several wires all connected to the body with a screw, you can use that same point. If you are looking for one in the ceter console area, there is a perfect ground point at the mounting for the e-brake.
Old 06-16-2006, 10:30 AM   #30
ok, so i just tried the ground point exactly where ya said and still it lights up the exact same way. I dont think its getting enough power from the fusebox? Im out of ideas
Old 06-16-2006, 10:36 AM   #31
FYI, if you use the e-brake bolt as a ground point its a PITA to get back in. Unless you have the brake off, like all the way down...I fought with it for 15 minutes while it was up...
Old 06-16-2006, 10:50 AM   #32
Skeeter's Avatar
I think i used one of the bolts for the shifter as a ground.
Old 06-16-2006, 10:55 AM   #33
Skeeter's Avatar
The packaging says they use 500mA, which is .5 amps or 1/2 amp. When I ran them without a fuse the invertor didnt last long, so a fuse is recomended STRONGLY. I am using .5 amp fuses on each set of cathodes.. Hope this helps Chris.
Chris You found 16 sets of 12inch cathodes on ebay for $10??????
Old 06-16-2006, 11:07 AM   #34
i bought 8 sets of 2 for $10. Sorry i wasnt talking correctly when i said 16 cathodes. i meant individual not sets. my bad.
Is there any way to use a fuse without going through the fusebox?
Old 06-16-2006, 02:31 PM   #35
okay, i even hooked it up to the car battery and it is dim. grrrrr
Old 06-16-2006, 02:36 PM   #36
It sounds like a bad transformer.
But why did you initially say when you hooked it to the battery it worked fine, now you say you hooked it directly to the car battery and no glow?
Very odd.
Not trying to give you a hard time, but dbl check the wiring and try plugging a different (as in none you have installed so far, if you still have a few) transformer. It is possible to fry those bad boys.
Old 06-16-2006, 02:38 PM   #37
Originally Posted by Skeeter
....When I ran them without a fuse the invertor didnt last long, so a fuse is recomended STRONGLY....
I think that all that testing with a battery (if it was a car battery) may have killed the transformer. They tend to work for a while when having a full 12V applied, but they do fail quickly under that load.
Old 06-16-2006, 03:40 PM   #38
Very odd.
When i say i hooked it up to a battery then, i mean one of these.
this is the first time that i hooked it up straight to the car battery.
I opened a new box and did try a new transformer. It worked just fine with one of those little batteries, but when i tried hooking up to the fuse, its extremely dim and only lights up about 1/4 of the tube. Ive tried multiple ground points, and have even run new wire. Then when i tried the car battery with a new transformer, still the same results as the fuse box hook up. And just to make sure i didnt blow the transformer, i tried the 9v battery again, and it was working fine.
I have no clue whats going on.
Old 06-16-2006, 06:30 PM   #39
Skeeter's Avatar
a 9 volt isn't enough to fire the cathodes., 12 volts gets stepped up to around 700 volts or so,with very low current. And yes you can fuse them without going through the fuse box, i used round fuse holders simular to what Big_Kokujin used, I picked up a 10 pack of fuse holders for $5 at a electronics place. You can run it them without a fuse for a short period of time. Sounds like you found a good deal on those cathodes
Old 06-16-2006, 10:38 PM   #40
Are you sure you're using cold cathodes? They shouldn't be able to run off of a 9v battery. The converter is designed to use 12v and ups the voltage for the bulbs to light up. When you tried it with the 9v where you connecting the converter to the battery or just the bulb? Interesting situation you've got going there. Post a pic of your stuff if you've got one.
DIY:Adding cold cathodes to the Oh S**t Handles 56k no way surfcitylocal Scion xB Lighting 85 08-01-2006 12:28 PM
Cold Cathode finally working! surfcitylocal Scion xB Lighting & Electrical 6 04-14-2006 10:32 AM
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
DIY: Removing Tail Lights
aftermarket headlights
"B-Pillar" lights
Luminics Bulbs
Page generated in 0.28930 seconds with 13 queries
