Old 02-20-2006, 08:48 PM   #21
CBSIMONSEZ's Avatar
CBSIMONSEZ is on a distinguished road
Send a message via AIM to CBSIMONSEZ
Try this site for all your bulb needs including LEDs that are a direct replacement for blubs, ( resistors installed ). Me, i needed the #1157 for the front marker/turn signal and a set of #7440 for the rear turn signals. 4 bulbs and shipping was 12 and change.
www.autolumination.com
CBSIMONSEZ is offline   Reply With Quote
Old 02-20-2006, 10:35 PM   #22
Thanks, I happen to be looking on eBay for my brother in law tonight and found Sylvania bulbs for really cheap too!
Old 02-21-2006, 11:09 AM   #23
R_lilbox's Avatar
R_lilbox is on a distinguished road
nice city lights! that looked real easy. i'm liking that emblem also
R_lilbox is offline   Reply With Quote
Old 02-21-2006, 11:34 AM   #24
Resolve's Avatar
Resolve is on a distinguished road
Originally Posted by Dajap
Looks good man, Where did you get the led with the resistor already on? Do they come 12v plug and play? Also how much? Thanks in advance. Chris
Hey Jap these are like the LEDs i have except mine are orange.. got the at http://www.superbrightleds.com/mini_tubes.htm for 16.95 and $5.00 shipping.. very easy install.. ans i mounted mine form the top so you dont see led unless you bend down and look up at top of headlight housing. or you are very far back.. I can show you the hook up on these next time we meet up if you want..
Resolve is offline   Reply With Quote
Old 02-22-2006, 01:23 AM   #25
-=(( Gcat ))=-
Gcat007's Avatar
Gcat007 is on a distinguished road
"Break and pray" or "Oven" methods? I want some more info on this. I thought the amber peice inside just popped out easily...
Gcat007 is offline   Reply With Quote
Old 02-22-2006, 04:51 AM   #26
1LowXB's Avatar
i have a perfect set i cleared i will just swap them if you pay shipping...
1LowXB is offline   Reply With Quote
Old 02-22-2006, 08:18 AM   #27
One method is to use a screwdriver and hammer to break out the plastic the other method involves baking the lights in the oven to loosen the sealant. Once the sealant is soft you pull the halves apart and remove the plastic piece. Then you bake them again to soften the sealant and press them back together.
Old 03-06-2006, 10:07 PM   #28
Switch added for on/off operation of LED's.
Left: LED's Middle: Fog lights Right: open
Old 03-17-2006, 11:04 AM   #29
sid
sid's Avatar
Hi Surf!
I finally put on the citylights, but did not clear my amber, i'm too lazy to take off the headlights. man that 5mm LED won't fit, how did you do it? I only fit 3mm LED.
sid is offline   Reply With Quote
Old 03-17-2006, 11:19 AM   #30
Looking good Sid. I did have to massage the 5mm a little to get it in there. It doesn't look like there is a whole lot of difference in the amount of light output between them! Nice work.
Old 03-17-2006, 11:38 AM   #31
sid
sid's Avatar
thanks you sir, well, I have to sacrifice the remaining 3mm I have. Its an easy swap(not soldered) so probably i'll trim some 5mm and get it to fit. its kinda hard trying to work it out when the headlights are in the car
Old 03-17-2006, 11:41 AM   #32
I think that's what made the differnce when I did it. I could get the led into a position that would be really tough if they were still in the Box.
Old 03-21-2006, 12:37 PM   #33
STICK 1NZ's Avatar
STICK 1NZ is on a distinguished road
Send a message via AIM to STICK 1NZ Send a message via Yahoo to STICK 1NZ
Here's mine. Kinda old pic but the idea is there.
STICK 1NZ is offline   Reply With Quote
Old 03-21-2006, 06:46 PM   #34
^^^^^^Oh so nice!^^^^^^^
Show me your Tails!!!
Under Car Neon
"THE HEADLIGHT" thread
DIY: Removing Tail Lights
aftermarket headlights
"B-Pillar" lights
Luminics Bulbs
Page generated in 0.22795 seconds with 13 queries
