Go Back   Scion xB Forum > The Marketplace > Scion xB Classifieds > Miscellaneous
Miscellaneous For all non-related miscellaneous items including xB toys.
Old 04-23-2009, 07:39 PM   #1
Easily Amused
1stGenRex's Avatar
1stGenRex is on a distinguished road
65" Toshiba HDTV
I am selling this because I am moving to a smaller place and I cant take it with me. The picture is great and there are no burned in areas of any kind.
Price is $450 OBO
* 65-inch widescreen (16:9 aspect-ratio) HD-compatible projection television featuring CrystalScan HDSC upconversion to 1080i/540p
* HDMI (High-Definition Multimedia Interface) HDTV input provides a pure, uncompressed video connection with DTV receiver or set-top box
* PowerFocus HD CRTs enhance sharpness and brightness; PowerFocus HC lenses offer 50 percent higher contrast than other lens systems
* 3D Y/C digital comb filter with Vertical Contour Correction accurately processes RF and composite-video (DVD, VCR, camcorder) signals
* DFine high-speed velocity-scan modulation improves the definition at picture edges
Technical Details
* Brand Name: Toshiba
* Model: 65H84
* Display Technology: Projection
* Display Size: 65 inches
* Image Aspect Ratio: 16:9
* is_hdtv_compatible: Y
* Height: 59.9 inches
* Width: 59.9 inches
* Depth: 26 inches
* Weight: 240.3 pounds
A huge picture and beautiful styling are important, but equally so are the refinements within the set that you only see when you experience its incredible picture. Toshiba's 65-inch widescreen, HDTV-ready 65H84 is a projection television that's well equipped to make the most of your high-end digital and analog source components.
The 65H84's exclusive PowerFocus HD lens system was designed specifically for HDTV programming. Most lens systems cannot faithfully reproduce a high-definition signal. PowerFocus HD uses six elements and a quality color-correction system to produce an image that is up to 65 percent sharper than an image produced by standard lens systems. The PowerFocus HD's higher beam current and finer beam spot provide a 30 percent increase in sharpness and a 10 percent increase in brightness over standard CRTs. Toshiba's four-element PowerFocus HC lenses offer 50 percent higher contrast than comparable 5-element lenses, giving you clear, deep, three-dimensional images.
The set's TheaterFine HD super fine-pitch screen uses a .52 mm design to reduce the space between lines on the lenticular screen, thereby sharpening the image. And since not everything you watch will be high-definition in origin (wouldn't that be nice), CrystalScan HDSC upconverts all video signals (including 480i/p) to 1080i HD. This significantly reduces jagged-line artifacts for a smoother, more natural image. (Selectable 540p, for those who want a progressive-scan image from a progressive-scan source, is available through the onscreen menu.) CableClear DNR+ Digital Noise Reduction circuitry--selectable by input--optimizes poor NTSC signals from antenna or cable by eliminating video noise (snow).
Meanwhile, DFine high-speed velocity-scan modulation improves the definition at picture edges, creating sharper images by slowing the CRT (cathode-ray tube) beam's horizontal scanning during demanding work--say, when rendering transitions from light to dark parts of an image--and speeding it up when scanning easily rendered sections, like broad dark areas.
A 3D Y/C (4 MB, 10-bit) digital comb filter with Vertical Contour Correction processes RF and composite-video signals for a sharp, clean picture. This advanced filter significantly reduces detail noise, seen as shimmering or flicker, in complex or intricate scenes. The TouchFocus digital convergence system (which creates perfect corner-to-corner focus at the press of a button) and AccuFocus 56-point manual convergence system let you choose the best calibration method for your system.
The 65H84 is loaded with connections of all stripes, including a HDMI (High-Definition Multimedia Interface) HDTV input, which gives you a pure, uncompressed video connection with your DTV receiver or set-top box (not included). HDMI supports standard-definition (SD), enhanced definition (ED), or high-definition (HD) video, plus multi-channel digital audio--all using a single cable. It transmits all ATSC HDTV standards and supports up to 8-channel digital audio, with bandwidth to spare to accommodate future enhancements and requirements.
For audio, the 65H84 offers SRS WOW, combining SRS 3D (which creates a wide three-dimensional sound field), TruBass (which boosts bass frequency perception for dramatic low-frequency effects), and Focus (which raises the perceived sound image vertically to clarify voices) to greatly enhance your home-theater sound.
The set's split-cabinet design allows the cabinet to be divided for ease of delivery and installation.
Product Description
As your source for digital home entertainment, Toshiba offers one of the most extensive television lineups in the industry. Whether you're looking for the latest in HDTV, the flattest FST Pure flat-screen TVs, or the highest quality in portable televisions, Toshiba has what you want.PRODUCT FEATURES:CableClear DNR+ by Input optimizes signals from RF, Composite and S-Video connections by eliminating video noise and automatically adjusting sharpness;Day/Night Mode sets the television for optimum viewing in any room environment. The Day/Night Mode will set the television to full brightness for daytime viewing in rooms with ambient room light. The Night mode is ideal for dark rooms by reducing brightness to create the ideal picture for this environment. The Day Mode is used in full brightness for daytime viewing in rooms with ambient room light;SRS WOW technology takes the performance of the television's existing speakers to a whole new level to offer the consumer superior sound quality with no additional speakers required;4-Item Illuminated Universal Remote with DVD Control allows for easy operation in a dark living room or home theater environment;Direct Video Input Selection allows the user to directly select from the remote's numbered keypad without scrolling through all the inputs.
1stGenRex is offline
Old 04-24-2009, 11:12 PM   #2
Easily Amused
1stGenRex's Avatar
Re: 65" Toshiba HDTV
Bump!!!!!!!!!!!!!!!!!!!!!!
Old 04-28-2009, 12:58 PM   #3
Easily Amused
1stGenRex's Avatar
Price Drop $450 OBO
will take $400...I need this GONE
Old 05-04-2009, 06:23 PM   #4
Easily Amused
1stGenRex's Avatar
Price Drop again
1980 Toyota Corona Wagon (Restored)
Xtra Toys for grabs
FS: Scion Swag, Hats, Shirts, & Much More
Fiberglass SUBWOFFER BOX for SaLE!
green tree pythons for sale
Clubxb decals
Corolla F/S
Fs/ft: 2004 Vw R32
WTB/Choro-Q bB cars
Mercedez benz ML+Adapters 4X100 to 5X112 and stock tires
Page generated in 0.16170 seconds with 13 queries
