Hi PCH,
Thanks for the info.
I checked out the DIY and found a write up on how to do the conversion, however, it did not really explain the wiring, it was more how to remove the headlight and install the other one. It was a nice write up, but I just want some specifics about the wiring and how you can use the existing factory wire harness that is currently plugged into a light bulb that is used as both the high beam and low beam (factory setup) for a headlight that now has two light bulbs that are separate for the high beam and low beam.
I will keep searching and see what I can find.
I really appreciate your help. Have a nice day.
