06-10-2008, 09:36 PM
#21 | | Dori Dori
| Re: Got my airride!! First look at the new easystreet kit. Ill roll by there first chance I get and see about picking on up.
Steve's name on here is ScionPro I believe. |
06-10-2008, 11:45 PM
#22 | | Authorized Vendor
| Re: Got my airride!! First look at the new easystreet kit. Quote:
Originally Posted by TN_Toaster What is Steve's name on the forums? | I already have him getting prices for you. |
06-11-2008, 01:41 AM
#23 | | Gaijin :)
| Re: Got my airride!! First look at the new easystreet kit. ah yes i saw these on a local members car about alittle over a month ago. they new struts go much higher than the last struts. this is the kit i've decided on |
06-11-2008, 02:24 AM
#24 | | Authorized Vendor
| Re: Got my airride!! First look at the new easystreet kit. James if you need a price hit me up and that will be the sickest I am done modding my car rs 2 on air. |
06-11-2008, 04:38 AM
#25 | | Gaijin :)
| Re: Got my airride!! First look at the new easystreet kit. thanks i already got a hook up on it. im too into the kit to part it and to run it i need air so looks like my only option is this llol |
06-11-2008, 06:33 PM
#26 | | Nor*Cal's Most Hated
| Re: Got my airride!! First look at the new easystreet kit. Those struts look better than the prototypes I have! |
06-11-2008, 08:39 PM
#27 | | Registered User
Originally Posted by TN_Toaster What is Steve's name on the forums? | Just Steve thats it. I am just your regular plain old Scion freak. lol You can e-mail me direct at steve@scionpro.com or just call 1-888-scion94. I like to talk to my clients. |
06-11-2008, 09:02 PM
#28 | | Dori Dori
| Re: Got my airride!! First look at the new easystreet kit. ^ and he sure is helpfull.
Thanks again steve for helping me out with EVERYTHING!!! |
06-11-2008, 11:44 PM
#29 | | Registered User
| Re: Got my airride!! First look at the new easystreet kit. I'm lookin at getting the easystreet later on, when I can afford it, I'm hoping to get it before this time next year but doubtful, kinda interested in how you like this, I've heard a few bad things about the front struts but dunno if its the newest ones |
06-11-2008, 11:55 PM
#30 | | Dori Dori
| Re: Got my airride!! First look at the new easystreet kit. well anything you have heard about the front struts does most likely not apply to these. These are redesigned and hopefully there will be no problems with these.
It took me quite a while to save up and afford these. I sold a car to help fund this setup lol.
Only downside about air is all the work and space it takes up. Its definetly worth it in the end though.  |
06-13-2008, 11:27 PM
#31 | | Dori Dori
| Re: Got my airride!! First look at the new easystreet kit. Ah HA!
Yesterday I completed my air ride install. Shit is DOPE!
Im sooo soooo soooo stoked to roll around on this stuff but I got a slight dilema and so I gotta hold off.
Oh, and my camera went MIA so I gotta get a new one I guess.
Ill take my wheels off and snap pics of everything when I get a camera to. |
06-13-2008, 11:39 PM
#32 | | Registered User
| Re: Got my airride!! First look at the new easystreet kit. good to here that it all went well. I am SOOOO jealous! |
06-14-2008, 07:36 AM
#33 | | Scikotics Bristol TN
| Re: Got my airride!! First look at the new easystreet kit. yea, pics are good. I want to see how this lays out the box! gratz man |
06-14-2008, 09:45 PM
#34 | | Boooooom!
| Re: Got my airride!! First look at the new easystreet kit. Those holes dont look like they are slotted nearly enough to fix my camber issue, i had to put camber plates on mine, adjusted all the way down and it still wasnt enough. And now, with these you couldnt even add a camber plate.
i wonder how the clunking is... because thats pretty annoying. |
06-15-2008, 08:00 PM
#35 | | Dori Dori
| Re: Got my airride!! First look at the new easystreet kit. man... to be honest with you I dont know anything about those old kits. I havent even seen pics of what they look like upclose or anything.
Im happy with it so far, just need to give it like at least -3 to -4 degress of camber in the front. |
06-15-2008, 08:54 PM
#36 | | Registered User
| Re: Got my airride!! First look at the new easystreet kit. I didn't read each post in this thread but I'd like to give word to the wise. Be careful when you drop your ride and the engine is running as you'll rub one of the belts on the drive axial and eventually wear it out. I normally shut the engine off before I drop the ride but then I use it primarilly for the shows. Nice work on your install and by all means have fun.
06-15-2008, 09:09 PM
#37 | | Scikotics Bristol TN
| Re: Got my airride!! First look at the new easystreet kit. The belt rubs with just a stock EasyStreet kit and no cutting or any other modifications? |
06-15-2008, 10:38 PM
#38 | | Registered User
| Re: Got my airride!! First look at the new easystreet kit. New kit looks good. How much was it for the whole thing?
Peace |
06-15-2008, 10:52 PM
#39 | | The one and ONLY
| Re: Got my airride!! First look at the new easystreet kit. from my experience, it depends on what size wheel you have and if you remove the front sway bar, the power steering belt is what rubs. It rubs on one of the steering rods, also the axle will sit on the sub frame, so no driving at full drop in front. You can cut a small notch in it to get it to clear if you go that route.
to fix this you can do away with power steering.  |
06-16-2008, 08:04 PM
#40 | | Scikotics Bristol TN
| Re: Got my airride!! First look at the new easystreet kit. I have seen people talk about this, but I didn't realize it was a problem with just the stock kit. With a Honda, you can loop the hoses on the steering rack, add a breather and still have pretty good steering without the pump... time to google...
Hey, can you use the slow down valves/silencers on these manifolds? If so, do you know what size the port is so I can get these ordered. Thanks man.
