Go Back   Scion xB Forum > Community Forums > Car Talk
Car Talk General car discussion.
Old 02-23-2006, 08:04 PM   #1
Bluestreak22 is on a distinguished road
1NZFE Toyota made or?
Can anyone out there tell me if the 1NZFE in our XB's are designed/manufactured in house at Toyota. Or are they outsourced? I have a debate of sorts with my father in law over this. My understanding is the design was a effort involving Yamaha and the engine is a BEAM type. I believe that has to do with the head design. Any help? This is my firt post and i'm a new member today. Thanks, Gary
Bluestreak22 is offline
Old 02-23-2006, 08:30 PM   #2
short bus's Avatar
???1nzfe???
short bus is offline
Old 02-23-2006, 08:36 PM   #3
ScottyTuned's Avatar
wow i havent looked this up before or anything. but i believe the toyota 1nzfe is actually a toyota endeavor though im not sure. its a pure guess. i have no reason to believe otherwise that it would be something of an offshoot like dodge does (with mitsu motors sometimes) and other companies do. being a small engine though, i wouldnt doubt that a company like Yamaha would step in and help with design.
if i had to guess though, id guess its a toyota design/build.
also, welcome to the site!
ScottyTuned is offline
Old 02-23-2006, 09:03 PM   #4
dirtyrice is on a distinguished road
The yamaha designed engine/head is the 2ZZGE...found in the Matrix XRS and Corolla XRS and the Celeca GTS.
dirtyrice is offline
Old 02-23-2006, 09:30 PM   #5
hubbard is on a distinguished road
What short bus said.
hubbard is offline
Old 02-23-2006, 10:58 PM   #6
its the xB engine for those that dont know
Old 02-24-2006, 01:59 AM   #7
the brave little toaster's Avatar
the brave little toaster is on a distinguished road
Send a message via AIM to the brave little toaster
ok.... 1NZFE is toyotas motor. all scions are toyotas motor. the 1nzfe is the same motor used in the toyota echo and the prius hybrid. these are in the xB. the 2AZ-FE ins the scion tC is the camry 4 cyl engine.
there is your answer
the brave little toaster is offline
Old 02-24-2006, 02:01 AM   #8
and yes yamaha has part in the 2zz high compression motor in the celica gts, and xrs series. thats the ONLY motor they had part on. and for those that dont know, yamaha motorsports is owned by toyota.
Old 02-24-2006, 05:12 AM   #9
hotbox05's Avatar
yamaha has touched A LOT more than just the 2zz. their designs have been in many other toyota's too just not all theirs like the 2zz , 2jzgte , 7mge/gte , and 1jzgte.
in canada toyota sells tundra's with yamaha packages.
hotbox05 is offline
Old 02-24-2006, 05:14 AM   #10
hotbox05's Avatar
prius hybrid uses the same block as the scions and echo but...... different pistons , different combustion cycle , different intake , different vvti , different timing , different compression.
the 2azfe is also used in solara's , rav4's and highlanders.
hotbox05 is offline
Old 03-01-2006, 05:57 AM   #11
RAIDERBEAST's Avatar
RAIDERBEAST is on a distinguished road
Thumbs up student of toyota technical education network (T-ten)
Im a mechanic and I used to work for toyota. Toyota has plenty of engines that have yamaha stamped into tbelt covers, cast into cranks ..... as far as being outsourced Id say negative. the only thing special about the head is the vvt-i (same as v-tec) advances valve and ignition timing as rpm increases. nuthin too special
RAIDERBEAST is offline
Old 03-01-2006, 12:41 PM   #12
hotbox05's Avatar
it's not the same as vtec. vtec is a lift motor. ours are not. we have a very chitty wannabe version of vtec.
hotbox05 is offline
Old 03-01-2006, 01:08 PM   #13
if you're a mechanic, yea you should know that vtec and vvti systems have a lot of differences to tell ya the truth. the only thing close about them in my opinion is that they control the engine, and they both have a "v" and a "t" in the name. they systems are designed totally different.
Old 03-01-2006, 03:32 PM   #14
Frogbox is on a distinguished road
the 1NZ-FE is the motor for the echo,xB,xA.
the 1NZ-FEX is the designation for the Prius motor.
Both made in Japan, forget the town/city, but designed by Toyota, built by Toyota
Frogbox is offline
Old 03-01-2006, 04:06 PM   #15
hotbox05's Avatar
yeah the prius motore is a trip. too bad it's powerless. but it's clean burning as all hell.
hotbox05 is offline
Old 03-01-2006, 07:47 PM   #16
And although the Prius engine has 13:1 compression ratio, it only 'sees' 9. It has to do with the combustion cycle...Hotbox, you are right, it is a trip. I just wonder if the only difference is the ECU or if the components are different between the xB and Prius.
Old 03-01-2006, 07:48 PM   #17
Scionscotty, maybe he was thinking VVTL-i when he said the VTEC was the same?
Old 03-01-2006, 07:57 PM   #18
hotbox05's Avatar
different intake , different air box , different pistons if i remember correctly.
hotbox05 is offline
Old 03-01-2006, 10:36 PM   #19
^^^ And don't forget a valve train that can't withstand any RPM over 4000! (Or at least not a lot of it)
Old 03-02-2006, 01:08 AM   #20
The systems both change valve timing, honda does it the complex way, toyota not so complex, the end result is valve timting adjustment while driving. I had no idea my words would undergo such scrutiny.
What made you get your scion xb ? TheBox General Scion xB Discussion 65 03-29-2008 07:25 AM
Tracy Toyota Meet March 19th! EVILDAVE South West 91 03-25-2006 12:46 AM
playing soccer, in a Toyota... bB626 Off Topic 2 01-28-2006 02:59 PM
The offical "why would anyone do that to a car" thread
i <3 vw's
190-300+HP Hayabusa powered XB
More Japanese Vanning pics!!!!!
Post up pics of your old rides...56k...no
lifted Smart car...
has anybody seen this yet? (Nissan Cube)
ratrod anyone?
Bippu, Boso, Victory and twice pipes
what?! 600hp Widebody Smart Car!!
Page generated in 0.23178 seconds with 14 queries
