10-27-2007, 04:51 PM
#1 | | Nor*Cal Scion Apocalypse
| advice wanted - debage paint fade / dull I took off my rear badges a few weeks ago, on my BSP box. used goo gone to get the tape off and then waxed, when I washed it, i notced that you can still see where the emblem was. I tried some rubbing compound and waxing.. then tried some nufinish and waxing. you can still see where it was..
any recommendations?
heres what i have to look at everytime im behind my car  |
10-29-2007, 10:26 PM
#2 | | CAN I HAS CUSTOM TITLE?
| Re: advice wanted - debage paint fade / dull Quote:
Originally Posted by AzNpImP670 use a porter cable with some poor boy polishes.. it will make it look new again... | Or you can do it very carefully by hand using many tight but light circles by hand and whatever quality polish you choose (after the section is 100% clean of course). |
10-29-2007, 10:32 PM
| Re: advice wanted - debage paint fade / dull or u can use the adhesive polish remover! takes out anything! |
10-29-2007, 11:28 PM
#4 | | Registered Abuser
| Re: advice wanted - debage paint fade / dull try washing the car.. hit the back there with a medium to fine grade clay bar, give it a 'good healthy' wax, maybe do that area a few times... with a wet cloth for massageing wax on there, get a nice little build of wax and it should shine like new. i had the same issue when i debadged also. |
11-23-2007, 04:28 AM
#5 | | Banned
| Re: advice wanted - debage paint fade / dull Nothing short of repainting will work. The paint around the emblem is faded. No amount of polishing will change that. I hate those facts so if I were you I would just put the emblem back till you have the hatch repainted down the road. |
11-23-2007, 11:24 AM
#6 | | Nor*Cal Scion Apocalypse
| Re: advice wanted - debage paint fade / dull wrong. A buffer and some polish took it right out.  |
11-23-2007, 11:36 AM
| Re: advice wanted - debage paint fade / dull Same here...  "jay" |
11-23-2007, 01:38 PM
#8 | | XrayBravo
| Re: advice wanted - debage paint fade / dull |
11-23-2007, 10:46 PM
#9 | | Banned
| Re: advice wanted - debage paint fade / dull Good luck hope it truely works but it does look sunfaded. It's a common problem with vehicles that don't spend most of their time inside a garage. |
11-24-2007, 12:52 AM
#10 | | Nor*Cal Scion Apocalypse
| Re: advice wanted - debage paint fade / dull well, so far so good.. we'll see after a couple washes if it shows back up lol. |
11-24-2007, 02:17 AM
#11 | | Banned
| Re: advice wanted - debage paint fade / dull GTA, You just got that xB? If not, the paint looks like a victum of automatic car washes. The spiderweb scratches are quite bad and I would suggest a proper polishing job using Meguires 3 step with a rotory low speed buffer and foam pad. Followed with 2 or more coats of good wax. |
11-24-2007, 03:30 AM
#12 | | Al Choholic
Originally Posted by w00st3r try washing the car.. hit the back there with a medium to fine grade clay bar, give it a 'good healthy' wax, maybe do that area a few times... with a wet cloth for massageing wax on there, get a nice little build of wax and it should shine like new. i had the same issue when i debadged also. | I did the same thing, it's works! Quote:
Originally Posted by bB2NER Nothing short of repainting will work. The paint around the emblem is faded. No amount of polishing will change that. I hate those facts so if I were you I would just put the emblem back till you have the hatch repainted down the road. | i would think if the car was older, but it would ave to be pretty beat for something that extreme, nothing a good detail shop couldnt fix! |
11-24-2007, 11:30 AM
#13 | | Nor*Cal Scion Apocalypse
| Re: advice wanted - debage paint fade / dull i got it a few months ago. i bought it used.. its an 06. |
01-30-2008, 03:52 AM
#14 | | CAN I HAS CUSTOM TITLE?
Originally Posted by bB2NER GTA, You just got that xB? If not, the paint looks like a victum of automatic car washes. | Haven't you heard of dealer installed swirls from their "detailers" on the lot?
Most cars come with them nowadays, at no charge even! So nice of the detailer... |
02-26-2009, 08:07 PM
#15 | | The Flying Toasters
| Re: advice wanted - debage paint fade / dull Detailer is an oxymoron when it comes to the dealers.
I had them wash my xB twice when I purchased it and they still missed easy to spot stuff. |
