When was the last time you used your key for opening your doors? Keyhole covers by KeyTechniques
Original 3.2 This is the original cover I have sold in the thousands all over the world. It has undergone 3 major revision.
Revision made on May9th New adhision promotor to prevent spyder cracking. 1.Xb, 2.Celica, 3.Spyder 4. FJ cruiser
These units cover the key hole to give the car a somewhat shaved door appearance. The key holes disturb the lines of the car and when they are covered up the car takes on a subtle refined uniform look. You may never need to use the key hole if you have the factory or aftermarket keyless entry but incase something were to happen don't worry as they can come out in an emergency and can be reused. If the optional method of installation is followed then it will be very difficult for some passer by or some punk kid to remove them without taking great interest.
You may have seen these plugs on factory automobiles like the Lexus and Mercedes and soon enough they will probably remove keyholes all together like my friends Lexus IS250 which doesn’t even have one on the driver’s side.
Each cover will be modified to fit and will be individually tested before they are painted to OEM colors and shipped out.
Pricing as follows XB covers 2 for $14.00 shipped
3 for $20.00 shipped
4 for $24.00 shipped For international shipping add $2.00 Quote:
Ordering instructions: Please follow the instructions with care. 1.) Specify on this thread you’re order with the following information: a) quantity b) paint code (Please check next post for color codes.) c) Vehicle model 2.) Paypal keytechniques@hotmail.com 3.) You must paypal the amount and indicate in the email subject box or message box the following information: a) Quantity b) PAINT CODE c) Car Make d) SCREEN NAME and name of the website where you ordered. |
Instructions on using your Keyhole covers Warning
* Your keyhole covers are not colored plastic they are painted so please treat them with care and don't manhandle them
* Do not polish your covers for 30 days. If there are and micro imperfections on the clear coat they will be leveled after you polish them.
Mounting:
The covers consist of two parts.
1.
Cover
2.
Stem
Not much work here but you can insert the cover as is first to check that it goes all the way in. If it doesn’t sit flush then turn it 180 degrees and reinsert the cover the right way It will sit relatively flush and look good but if you are very picky and look down from the very top with your face pressed against the door you may find an ever so small micro gap on one if the adjoining edges and I would not worry about it as it should not be visible as no one can see it.
Additional step:
The covers should fit relatively snug but it is best to remove the cover after you have them seated well and add a small bead of contact cement on the stem, Wait 10 minutes then insert them into place. The contact cement only touches the hinged door in one small area on the out side of the lock and the rest is floating on the inside and touches nothing. This will insure that no one can easily remove the cover or any chance of it falling out. I recommend this step to ensure your satisfaction. Contact Cement is a low tension adhesive which is water resistant available at any automotive or hardware store for under $2.00. Please only use this adhesive and not a stronger one.
Removal:
You will need to first push the cover down and insert your driver’s license or credit car through the gap and fish it out. the adhesive point on the lock hinge stretches and the cover is free to come out.
Reinsertion:
Take a Q-tip doused in Alcohol and clean the adhesion point on the out side of the lock hinge which dissolves easily and replete the procedure.
The adhesion method is non destructive and can be cleaned up easy with any solvent.
*Your covers use some of the best materials for manufacture including Chroma based paint and UV resistant clear coat which is special ordered from Germany.
Treat your covers well and it will give you many years of good service
Personal note: I am a car enthusiast just like you and trusted on many forums for my efforts and services. Please PM me if you have any complaints or problems and I will try to respond ASAP to help solve your problem.
Thanks
dev
Colors Avalible Quote:
Scion Colors tC:
SW - 040
FM - 1E0
SSM - 1E7
CSM - 1F7
BSP - 209
AP - 8Q6
BCP - 3P2
IIP - 8P4
NBM - 8S6 RS tCs
rs1.0 - 3P0
rs2.0 - 8Q1 Now avalible ! xB (colors not already mentioned by tC)
BOP - 8P8
camo - 6M7
PW - 068
TCM - 1D2
SRP (salsa red) - 3Q3
shadow mica - 1F4 RS xBs
rs1.0 - 4R8
rs2.0 - 576
rs3.0 - 6U1
rs4.0 - 3R2 Now avalible! |
