06-03-2009, 06:06 PM
#21 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) hey padanky....you dont rub in the front with df's do you? |
06-03-2009, 09:08 PM
#22 | |
| Re: **camber Who Wants It** (2nd Gen) Quote:
Originally Posted by shawnofthedead420 hey padanky....you dont rub in the front with df's do you? | I do, but no major damage. No tire shredding, slowly rolls the fender itself. You just have to go slow over speed humps, dips rub while driving, you get used to it. You just have to drive like your on super lowpro's or something, Cautious. You will really get to know the roads in your area. |
06-03-2009, 09:49 PM
#23 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) would it help if you put more narrow tires for a stretch? if so, what size tire would you suggest for some 16x8's? just trying to prepare myself. |
06-04-2009, 06:59 AM
#24 | |
Originally Posted by shawnofthedead420 would it help if you put more narrow tires for a stretch? if so, what size tire would you suggest for some 16x8's? just trying to prepare myself. | Should help, maybe some camber bolts too. 205/50/16 down to 195/50/16 or 195/45/16 |
06-04-2009, 08:45 PM
#25 | | bBsquad reppin
| Re: **camber Who Wants It** (2nd Gen) just do a 195/40/16 man. you will love it  |
06-05-2009, 02:26 PM
#26 | |
Originally Posted by dancar420 just do a 195/40/16 man. you will love it  | ^^^ Crazy stretch, I googled for images.  |
06-05-2009, 11:19 PM
#27 | | bBsquad reppin
| Re: **camber Who Wants It** (2nd Gen) it aint that bad really  |
06-05-2009, 11:58 PM
#28 | |
| Re: **camber Who Wants It** (2nd Gen) Yea, them don't look too bad. I think I was seeing a few on 9" wheels and 8". |
06-14-2009, 12:16 AM
#29 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) I have mine done by a Toyota tech where I work:
BTW, wheels are 18 x 8.5 (F) and 18 x 9.5 (R) and was rubbing so much prior to <camber install. now no more......
06-14-2009, 12:16 PM
#30 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) whats the offset on those wheels? |
06-15-2009, 10:02 AM
#31 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) I'm in. Lets get some pictures. |
07-02-2009, 12:13 PM
#32 | |
| Re: **camber Who Wants It** (2nd Gen) Dan, Any updates? Progress? |
07-03-2009, 12:52 AM
#33 | | bBsquad reppin
| Re: **camber Who Wants It** (2nd Gen) Sorry fellas I have been so busy. And the car I was using I can't use anymore. Shaunofthedead I think I might need you to be the test car now if you down for it. |
07-03-2009, 07:06 AM
#34 | |
| Re: **camber Who Wants It** (2nd Gen) Any chance a tC has the same set-up? Maybe you could find a tC to use if so. |
07-03-2009, 10:22 AM
#35 | | bBsquad reppin
| Re: **camber Who Wants It** (2nd Gen) Not sure if the tc is the same. I think they are different cause they have an independent rear end. But I am not sure tho. I would rather build it off the 2nd gen to make sure it's right. |
07-08-2009, 10:17 PM
#36 | | HELA FASS DOOO
| Re: **camber Who Wants It** (2nd Gen) I am interested....of course I am running 17x7.5 wheels with NF210, moving to DF210 in due time, and want to get that tilt as it is pretty bad arse. And to add I also want to use spacers, 15mm in front and 30mm in back (i think), not sure of the combination's but I am sure I will figure it out, eventually
The List...
1.Padanky
2.shawnofthedead420
3.help23
4.
5.
6.
7.
8.
9.
10. |
07-09-2009, 12:50 AM
#37 | | xclusive scions
| Re: **camber Who Wants It** (2nd Gen) The List...
1.Padanky
2.shawnofthedead420
3.help23
4. masterBb
5.
6.
7.
8.
9.
10. |
07-09-2009, 07:27 AM
#38 | | Registered User
Originally Posted by dancar420 Sorry fellas I have been so busy. And the car I was using I can't use anymore. Shaunofthedead I think I might need you to be the test car now if you down for it. | im certainly down! lmk what you need. |
07-30-2009, 10:12 PM
#39 | | Registered User
| Re: **camber Who Wants It** (2nd Gen) I can speak for about 3 Vegas 2nd gen owners!! Guys you've most likely met Dan lol
1.Padanky
2.shawnofthedead420
3.help23
4. masterBb
5. l337biker(jon from vegas)
6. Neek(self explanatory)
7. Kai(supercharged 2nd gen who came out for The Premiere)
8.
9.
10. |
07-30-2009, 11:51 PM
#40 | | bBsquad reppin
| Re: **camber Who Wants It** (2nd Gen) damn I have been so busy sorry fellas. I have been trying to get stuff ready for SEMA  thanks Jon for the peeps on this....... |
