Scion xB Sponsored Sales & SpecialsScion xB Sales & Specials brought to you by our Vendors. Lets show some support to the companies that keep this site online.
Image is in a civic but the materials are the same.
The CorSport harness bar attaches at the seatbelt mounts behind the front seat. Once installed this bar will provide a safe, proper attachment point for your harness restraint system (be SURE to use a 5 point harness system for maximum safety). Due to its unique shape and mounting style it is perfect for autocross competition where you want to be sure that a harness bar will not put you out of your class by being misunderstood as a bar that is adding torsional rigidity to the entire chassis. These harness bars are easily installed using a bracket mounting system and can be removed quickly when not in use, if necessary. All components are designed and made from high quality, aircraft grade materials.
This is the perfect bar for when you need to wear a harness.... such as: autocross, time trials, road racing and track days.
