05-10-2006, 09:08 PM
| Wiper arm I've seen this before but cant remember where....does anyone know where i can find a how-to on making the rear wiper arm point straight up instead of laying flat? i would appreciate it  |
05-10-2006, 09:11 PM
#2 | | Mother Lover...
| You should have to just pop the car off the nut holding wiper on, remove the nut and wiper and turn the wiper how you want it and tighten everything back up. I haven't done it, but I don't see how it wouldn't work.
May have to turn it on to a certain point and attach it, not sure. |
05-10-2006, 09:13 PM
| but if i did that wouldnt it turn the wrong way? i think when i seen it you had to turn the motor or something to that effect or rewire it...something |
05-10-2006, 09:14 PM
#4 | | Mother Lover...
| Quote: |
Originally Posted by Supaglove but if i did that wouldnt it turn the wrong way? i think when i seen it you had to turn the motor or something to that effect or rewire it...something | I'm thinking. |
05-10-2006, 09:17 PM
#5 | | Mother Lover...
| I guess, test it out before you just let it go swinging away. |
05-10-2006, 09:18 PM
#6 | | Mother Lover...
| You can't turn the motor. |
05-10-2006, 09:19 PM
| Yeah cant hurt to try huh |
05-10-2006, 09:20 PM
| Maybe its just for looks then....if it doesnt work i would just rather take it off IMO |
#9 | | Mother Lover...
| If it gets to crazy just shut the key off. Go for it, you can do it!  |
05-10-2006, 09:22 PM
#10 | | Mother Lover...
| My friend did it with his Protege5 when I had one and he said he just switched it around and it worked. |
05-10-2006, 09:23 PM
| Your right ill do it tommorow...it'll give me something to do...i can take the wiper arm off on the front right to move it? ha if someone gets real close to the side i can turn it on and hit them with it |
05-10-2006, 09:24 PM
#12 | | Mother Lover...
| Quote: |
Originally Posted by Supaglove Your right ill do it tommorow...it'll give me something to do...i can take the wiper arm off on the front right to move it? ha if someone gets real close to the side i can turn it on and hit them with it | Let me know, and if it works do a how-to (why not). |
05-10-2006, 09:26 PM
| no problamo ill post with pics tommorow if it works |
05-10-2006, 09:35 PM
#14 | | Registered User
05-10-2006, 09:47 PM
#15 | | Mother Lover...
05-10-2006, 10:09 PM
#16 | | Registered User
| thats it! i knew i seen it...ill post some pics tommorow when its finished |
05-11-2006, 03:39 PM
#17 | | Registered User
| The odds are if you reposition the wiper in the up mode it will contiue in the same directionright off the hatch however if you were to reverse the wires on the wiper motor it should cause it to swing down from the up position. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Scion xB Forum | Replies | Last Post | | Hatch Wiper Removal | synapse | Scion xB Exterior | 91 | 06-25-2007 03:01 PM | | Hatch wiper removal | squirrel | Scion xB Interior | 93 | 02-02-2006 01:00 AM | | | |
