Scion xB AppearanceThe Scion xB is craving interior and exterior modification. There's so many options to customize your Scion xB. This is where you can share with others what works and what doesn't when installing custom audio systems or Scion xB body kits.
on the rear hatch, the plastic trim piece covering the handle/lights to be exact.
The right(passenger) side suddenly feels loose and has play to it as if a tab popped out. I can lift it away from the hatch. Anyone else experience this and whats the fix?
There are 2 10mm nuts and a plastic tab, sounds like the nut and stud may ahve pulled or the plastic tab. Pull the rear door panel off, and look at what is going on.
theres actually 3 10mm nuts and a plastic tab to be exact, or at least for the 04.
im looking at one right now. i have one on the floor next to my shoe.
