Scion xB AppearanceThe Scion xB is craving interior and exterior modification. There's so many options to customize your Scion xB. This is where you can share with others what works and what doesn't when installing custom audio systems or Scion xB body kits.
You'll have to buy blue cold cathode tubes or blue led tubes. The ones installed as a dealer option do not change colors. The choice is made when the option is purchased. It's easy to do and not that expensive either, much less than what the dealer charged for it.
Not from the dealership.... do a search for LED lighting on here or the other sites.
check a dealership parts pricing page and the interior kit is around $200. Search this site for info on LED's and several sites can be found and for under $100 you can have better lighting for your xB. Your choice if you want the dealer stuff. I am now considering switching out my dealer installed lighting for LED or cathode tube lighting. I want a more stealth look and red seems to common. To each his own.
