Old 12-26-2008, 05:11 AM   #61
Black_Box's Avatar
Re: Twin turbo supra motor swap?
it aint shit till you lift a V10 crank shaft. its stupid heavy
Old 12-26-2008, 06:09 PM   #62
gravebox's Avatar
i hardly weigh in at about a buck 35 so i'll leave that to your cherry picker :P
i'll stay with my aluminum V6 :P
Old 04-27-2009, 09:26 PM   #63
Therealenthusiast's Avatar
Therealenthusiast is on a distinguished road
So realistically..would a 4-age fit in an xb?
Sure it's not thee most powerful engine in the world..but it'd be reasonable right?
Therealenthusiast is offline   Reply With Quote
Old 04-28-2009, 06:04 PM   #64
gravebox's Avatar
if i'm making a 2grfe V6 3.5L fit, a 4age will fit no problem with less modification.
i just don't find the 4age to be that great. it's a belt driven interfierence engine... belt snaps and you're out of an engine... pistons start slapping valves and valve stems start putting holes through the head covers and your valve springs, retainers get ground up by the came shafts and then your cam shafts shatter like glass...
i'm going with the 2grfe because:
1. it's toyota's most efficient V6 ever.
2. for a V6 it only weighs 356lbs which is very light.
3. it's a V6 to which in our chassis with 4WD will still get nearly 30mpg.
4. it requires very little modification to make it punch out alot of power.
5. it's a non-interfierence CHAIN driven motor so no issues if the chain SOME HOW manages to break.
6. the long block can be switched out with a 1gr's long block making it a 1.5grfe 4.0L V6 that revs to 8,000rpm and with turbo would still get mid 20's for mpg.
the 4age is a choice for swaps. i just don't see much out of it. the 1ZZFE would be the best option for a 4cyl engine. the 3SGTE is just too damn heavy for what it is *422lbs engine alone* and it likes to eat oil ALL the time AND you have to use the shimless valve retaining setup that the ZZ engines use on the 3SGTE's head otherwise you'll throw shims at anything over 7,500rpm on it...
so, in my opinion, the best engine choices are:
1. 2GRFE V6 3.5L *chain driven non-interfierence engine with Dual VVT-i, use for ANY application.*
2. 2ZZGE 4cyl 1.8L 180hp *chain driven interfierence engine with VVTL-i (not recommended for turboing or DD, high rpm based straight line top end)*
3. 1ZZFE 4cyl 1.8L 140hp *chain driven interfierence engine with VVT-i (great for DD and off line acceleration and easily moddified for high power)*
5. 2AZFE 4cyl 2.4L 180-ish hp *chain driven interfierence engine, not the best for top end what so ever, great mid power but poops out as you climb rpm regardless of head work. it's also a fat engine*.
6. 4AGE 4cyl 1.6L 130-ish hp *belt driven interfierence engine, not recommended for turboing. equiped with Toyota T-VIS *throttle variable intake system*, good for drifting, high rpm top end engine*.
7. 4EFTE 4cyl 1.3L turbo 135hp *belt driven non-interfierence engine, the 3SGTE little brother, unknown oil hunger characteristics...*
EDIT:
like how i skiped 4 on that last list?
Old 04-28-2009, 06:07 PM   #65
EDIT:
You've sold me, now I'd like to see someone do it.
Old 04-28-2009, 06:12 PM   #66
gravebox's Avatar
^^i'm workin on it. i have the motor already in storage at my mother's. i haven't had a chance to drive up there and get pictures yet, it's a 4 hour drive from here .
but since i got the main piece i'm probably going to end up hitting school for a bit before i keep going. that way the rest of tthe project is funded completely without any money issues *will be CNC programing and Machining with drafting and design on the side and MAYBE some welding*.
Old 05-20-2009, 08:11 AM   #67
17 years old now haha
15yroldSciontist's Avatar
15yroldSciontist is on a distinguished road
Grave did you ever get any progress on that because i want in!!!!!!!!!
15yroldSciontist is offline   Reply With Quote
Old 05-21-2009, 12:29 PM   #68
gravebox's Avatar
engine's still in storage at the moment. i'm hitting school in a couple weeks so the project is on hold for a small bit. afterwords though... oh ya... xB on steroids.
Old 06-02-2009, 03:37 PM   #69
PINOY AKO !
bBxdjsiryan's Avatar
bBxdjsiryan is on a distinguished road
Send a message via AIM to bBxdjsiryan Send a message via Yahoo to bBxdjsiryan
just put a jdm mr2 engine lol
bBxdjsiryan is offline   Reply With Quote
Old 06-02-2009, 04:14 PM   #70
I'm the man in the box
Race_King's Avatar
Race_King is on a distinguished road
Send a message via AIM to Race_King Send a message via MSN to Race_King Send a message via Yahoo to Race_King
you could have some fun but some major torque steer unless you convert it to rwd. good luck, sounds sick.
Race_King is offline   Reply With Quote
Old 06-02-2009, 04:16 PM   #71
xBtony's Avatar
Ok..Being serious..has anythought of a FWD SR20DE Swap? It makes sense to me...
If I had a spare xB I would try it.
Old 06-02-2009, 06:58 PM   #72
gravebox's Avatar
i wouldn't...
you'd have to chop the crap out of the fire wall to fit it for a rwd setup.
the reason why the 2GRFE would be the best bet is because you can atleast have 4WD and have it a transverse setup with minimal modification to the fire wall *just a bit of massaging* and then some cutting on the sub frame rails... make a new tube frame and so on. the 2GRFE engine also only weighs 350lbs *381lbs with full fluids* so it's extremely light for it's size.
you COULD do a rwd setup with the 2GRFE and still wind up doing less modification to the firewall and end up with a much more power capable power house than any 4 cylinder and you'd have monsterous torque to back it up for drifting.
Old 06-02-2009, 07:51 PM   #73
xBtony's Avatar
^U talkin to me? I said FWD...Like the SR that somes in Nissan 200SX's...Non turbo FWD 4 banger.
Old 06-02-2009, 08:51 PM   #74
gravebox's Avatar
OH! gotchya, well, doable... you'd have to do the same work to the sub frame rails as the 2GRFE would require due to the added length of the SR's block size. the front end would be retardidly over weight though too cause of that iron monster block. at that point you might as well use a 2AZFE, add a bit of liter size and reduce a butt load of weight.
Old 06-02-2009, 11:14 PM   #75
xBtony's Avatar
^Ahhh! Tru..Lol...Not like I was gunna do it..HAHA!
Old 06-03-2009, 09:48 AM   #76
ogerdgonz's Avatar
For RWD go with the 22R motor....
Old 06-03-2009, 12:48 PM   #77
gravebox's Avatar
^^ still ridiculously heavy over the other capable engine options...
in my opinion that is...
Old 02-22-2010, 08:42 PM   #78
mrjones72085 is on a distinguished road
for all the haters and non believers out there i have fit a 7 mgte motor in my 2008 xb and converted to rear wheel drive single turbo got about 480 with 373 foot lbs of torque. and yes this baby does come off the floor in 1,2 and 3rd.. pics to follow after paint job...
mrjones72085 is offline   Reply With Quote
Old 02-22-2010, 08:53 PM   #79
Black_Box's Avatar
.....pics or it didnt happen!!!
Old 02-22-2010, 09:06 PM   #80
crxgames's Avatar
Sounds awesome. Pics!
Page generated in 0.29318 seconds with 12 queries
