Old 10-11-2006, 11:55 PM   #41
fcastle's Avatar
fcastle is on a distinguished road
Originally Posted by rollhard
I went the link, how did that intake work? I always thought there was a way to use the space behind the grille to have an intake. Any change they'll make one for non turbo cars?
fcastle is offline
Old 10-12-2006, 12:15 AM   #42
RS4 #303
sdsnybny's Avatar
Exclamation rollhard thanks but
i have more than you can see. mine is the snorkel type the filter sits way down by front fender. and since the very top of filter sits 1 inch below foglight cover i do need bypass and i dont get heat from exhaust, by the way i agree the exhaust side is a bad spot for drawing air, after turning down it angles away and toward front end. then attaches to trans bolt for securment then it upturns under foglight area it never gets close to exhaust side. here is a better pic of whole system. thanks for the heads up its always better when every body shares pos and neg experiances
sdsnybny is offline
Old 10-12-2006, 01:39 AM   #43
hotbox05's Avatar
the intake setup into the grill only benefits if you have an open grill.
and i dislike the trd intake as well . too much , too many bends , over the transmission , and blah , lol. not hating just stating.
both the aem "L" pipe and the injen have the best dyno results.
mine has the filter close to the same place as the trd/aem snake pipe but it hs only one bend and sits a few inches higher than the trd one does.
hotbox05 is offline
Old 10-12-2006, 01:59 AM   #44
choppedxb's Avatar
choppedxb is on a distinguished road
I Got The Set Up In The Photo. Smoked My Sensor Even With The Water Trap.$$$$$$$$$$
choppedxb is offline
Old 10-12-2006, 02:33 AM   #45
RS4 #303
sdsnybny's Avatar
Question what
chopped please explain did you get it really wet or do you have one of early versions that put valve train vent in before sensor thus killing many sensors cus mine enters after all sensors by throttle body avoiding coating sensors
sdsnybny is offline
Old 10-12-2006, 02:36 AM   #46
hotbox05's Avatar
not only can the pcv hose coa and ruin a maf , an overoiled / improperly oiled filter element can as well.
hotbox05 is offline
Old 10-12-2006, 02:38 AM   #47
RS4 #303
sdsnybny's Avatar
Thumbs up so true
well put hot box^^^^^^
sdsnybny is offline
Old 10-12-2006, 02:40 AM   #48
hotbox05's Avatar
i'm actually looking into getting the new aem dry filter . but it's hard to find without buying the entire intake kit.
hotbox05 is offline
Old 10-12-2006, 02:41 AM   #49
hotbox05's Avatar
take that back. just found em on ebay. just gotta find out the diameter of piping they use on the xB kits.
hotbox05 is offline
Old 10-12-2006, 02:45 AM   #50
RS4 #303
sdsnybny's Avatar
look here 1st
check this study out i think im going with apexi soon as moths leave wallet
http://mkiv.com/techarticles/filters_test/2/
http://www.overboost.com/obs/search....&search_univ=0
still have to measure my kit but i think its 2 1/4 to 2 1/2 inches not sure on mm's
the bypass valve inlets had size on them but i didn'y copy it down
sdsnybny is offline
Old 10-12-2006, 02:51 AM   #51
hotbox05's Avatar
yeah other than k&N only other filter i'd use on most cars would be apexi. uni's are decent. a lot better on a bike where i'm not as worried about service life.
hotbox05 is offline
Old 10-12-2006, 07:58 PM   #52
rollhard is on a distinguished road
Send a message via AIM to rollhard
The long intake plumbing is a waste. The longer the plumbing, the more friction there is. The more friction there is, the more heat. So, you basically defeated the purpose of having the filter located in a position where the air temperature is cooler. Another thing to consider is air pressure and density. Is the filter located in a low pressure region? As far as the intake not working well unless their is an open grill, I can prove it on the dyno. The slots on the stock grill are cut out so there is plenty of pressurized air. We make our own filters with velocity stacks inside the filter so it will be hard finding one that is going to outflow what we use already. Apexi does make a very nice filter though.
rollhard is offline
Old 10-12-2006, 11:41 PM   #53
RS4 #303
sdsnybny's Avatar
Thumbs up thanks
rollhard thanks for the info. my intake was a dealer add on negotiated at purchase before i new about what function they performed. i bought it cause of improved fuel economy. i tottaly understand the concept of shorter distance, les friction, cooler air, better pressure = more power. after all i grew up when muscle cars first came out, and ram air is THE shortest way. when i can afford it ill change to that.
sdsnybny is offline
Old 10-13-2006, 12:32 AM   #54
Hehe, although there is a BIG difference between modern EFI and old school muscle cars. Muscles cars of the past have horrific volumetric efficiency, hence why they went with the whole "bigger is better" type of thing. We now make more power than ever with tiny motors....yada yada, I know what you mean though.
rollhard is offline
Old 10-13-2006, 12:43 AM   #55
RS4 #303
sdsnybny's Avatar
Wink ya said a mouthful
how true look what newer v8's can do in comparison to old school. ive learned alot about the diff in old school and our motors when it comes to performance since may 06 when i fell in love w/xb's thanks for all the imput keep it comming after all the only dumb ? is one not asked.
sdsnybny is offline
Old 10-13-2006, 12:48 AM   #56
Thats right man! Ask away...........!
rollhard is offline
Old 10-13-2006, 03:39 AM   #57
choppedxb's Avatar
ON THE MONEY
Old 10-13-2006, 09:12 PM   #58
Clockwork Orange's Avatar
Clockwork Orange is on a distinguished road
I just got it and installed it immediatly
There is a little bump in umfff.
I gets to 60 faster thats for sure!
Clockwork Orange is offline
Old 10-13-2006, 09:43 PM   #59
hotbox05's Avatar
just got it t my house but i'm still out of town til next weeks.
hotbox05 is offline
Old 10-13-2006, 11:48 PM   #60
ThunderGod's Avatar
dom, get ova here now! so we can fab a bracket to fix that mounting problem.
mine should be coming in next!
ThunderGod is offline
Page generated in 0.25618 seconds with 13 queries
