Old 11-02-2009, 08:54 PM   #1
silvertoast's Avatar
N E 1 running an AFE intake
is anyone running one of these AFE intakes. if so how do u like it??
i currently have a trd cai and i like it but its a pain to remove the filter to clean.
n-e-1-running-afe-intake-bvd-kkw-wk-kgrhgooki4ejllm-wwnbkqmvgkn-qKkw!Wk~$(KGrHgoOKi4EjlLm,WWnBKQmvGKN)Q~~_12.jpg
ID:	12258  n-e-1-running-afe-intake-dae5_1_b.jpg
silvertoast is offline   Reply With Quote
Old 11-03-2009, 02:37 PM   #2
Just let your soul glo...
uprising's Avatar
Re: N E 1 running an AFE intake
how often do you clean your filter?
Old 11-03-2009, 07:09 PM   #3
try to clean it every couple of months, i use my car for work and drive around 100 miles a day so it stays dirty (i mean dirty) i try to keep it clean to keep my gas mileage up.
Old 11-06-2009, 10:00 PM   #4
I just cut the CAI that came on the car and bought an AEM filter. Its a tight fit using the stock rubber hose, but it will fit.
n-e-1-running-afe-intake-airfilter1.jpg  n-e-1-running-afe-intake-airfilter2.jpg
Kazzak is offline   Reply With Quote
Old 11-06-2009, 11:45 PM   #5
babelbox's Avatar
babelbox is on a distinguished road
I did the same thing and shorten my Fujita CAI. Check out this thread. But I noticed that the Intake Air Temp registering in my ScanGauge was high. I was noticing about 10-12 degrees hotter than the outside temp when cruising. When idling, it can go up to about 30-40 degrees more than the outside temp. I'm not really sure if there is any harm done if the intake air is too hot but I changed to a Fujita SRI.
babelbox is offline   Reply With Quote
Old 11-07-2009, 03:46 AM   #6
Nor*Cal Scion Apocalypse
awinter's Avatar
warmer air leads to better fuel efficiency so you shouldn't worry. Colder air = denser air; denser means more fuel can be burned which means more hp and less efficiency or lower mpg.
Old 11-07-2009, 04:07 AM   #7
Military B from OH
JP_Extreme's Avatar
Yep I know all about this living in OH and all. I have a bombz CAI with a APC filter and to remove it you have to lay on your back and crawl under the bumper to remove it. That is a pain, but it helps I only do it while I have the car jacked up while I am changing my oil.
Page generated in 0.23417 seconds with 14 queries
