12-04-2006, 02:33 PM
#61 | | Registered User
| i dont really care if u belive me or not but i do have nitrous. Lustine and ptuning put there money together to buy me a new motor cause they sponsor me and justin did the labor work for free cause hes an awesome friend. so its not really warrenty but i didnt pay anything. Justin installed it at the dealership too. |
12-04-2006, 02:48 PM
#62 | | Registered User
| oh ok. well saying u have n20 makes 180 whp make sense. and listing out how it ISN'T warranty by anyones standards makes a LOT more sense. |
12-04-2006, 09:29 PM
#63 | | Registered User
| Quote: |
Originally Posted by VIET BOX | LOL. You just broke it in.  j/k |
12-04-2006, 10:10 PM
#64 | | Registered User
| Quote: |
Originally Posted by caden_stargate LOL. You just broke it in.  j/k | SCREW THAT I THINK THE HAMPSTER CHEWED ITS WAY OUT OF THE CAGE  |
12-05-2006, 02:25 AM
#65 | | Registered User
| Quote: |
Originally Posted by excitebox i have the same shifting habits as the one and only thundergod  and solara2xb. 4000/80 mph on highway drives, @4000 for shifts when i need power, sometimes 5k | Wow.. hearing you say this really scares me...
What kind of engine mods did you have again??
Maybe I should take it easy with my car..... |
12-05-2006, 04:34 AM
#66 | | Registered User
| Quote: |
Maybe I should take it easy with my car..... | his header was leaking causing a lean condition ( BAD )
and apparently there was excessive oil pump clearance meaning not enough oil pressure. |
12-05-2006, 09:13 AM
#67 | | Authorized Vendor
| URGENT question I am now hearing a sound occasionally from my motor.....it appears to come from by the drivers feet which is where the hole is in the chocolate rocket.
Here is the question.......Was the sound an occasional sound that was a tapping sound sort of like when you were a kid and put the baseball card in your bike spokes? Not that harsh sounding but it is like a valve tapping. or something rotating occasionally contacting something it should not. I am running a stock motor only change is TRD exhaust.
Any info helpful. |
12-05-2006, 09:32 AM
#68 | | Registered User
| Quote: |
Originally Posted by polarproject SCREW THAT I THINK THE HAMPSTER CHEWED ITS WAY OUT OF THE CAGE  | ROFLMAO!!! Good one. |
12-05-2006, 11:04 AM
#69 | | Registered User
| yeah that's scary. I have no mods on my engine at all. I'll be doing more research before I do. |
12-05-2006, 01:38 PM
#70 | | Registered User
| Quote: |
Originally Posted by hotbox05 his header was leaking causing a lean condition ( BAD )
and apparently there was excessive oil pump clearance meaning not enough oil pressure. | Ahhh.. Ic....
Well I am hoping I will not run into engine problems with this car.. I plan on keeping my engine relatively stock, Only thing I have really done is change out the Radiator Cap to the TRD and I have a TRD Exhaust..
everything else is stock...
Maybe I should install a Oil pressure gauge and take out my Vac gauge. |
12-05-2006, 02:25 PM
#71 | | Registered User
| oil temp and oil pressure gauges are always very good indicators of an engine's overall condition |
12-05-2006, 04:54 PM
#72 | | Registered User
| Quote: |
Originally Posted by hotbox05 oil temp and oil pressure gauges are always very good indicators of an engine's overall condition | Yea, How would you install the Oil Pressure gauge?? where would I tap it into.. I would be looking into getting a electrical Oil Pressure gauge...
Oil Temp.. Is that really needed?? |
12-05-2006, 05:00 PM
#73 | | Registered User
| Quote: |
Originally Posted by solara2xb Yea, How would you install the Oil Pressure gauge?? where would I tap it into.. I would be looking into getting a electrical Oil Pressure gauge...
Oil Temp.. Is that really needed?? | oil temp is a very good indicator. it's a better judgement than water temp imo. it's a vital thing.
for oil pressure you would have to buy the pressure solenoid. hooks into the same spot the dummy oil press indicator does then you would run the wire to the gauge inside. |
12-05-2006, 11:55 PM
#74 | | Registered User
| Quote: |
Originally Posted by hotbox05 oil temp is a very good indicator. it's a better judgement than water temp imo. it's a vital thing.
for oil pressure you would have to buy the pressure solenoid. hooks into the same spot the dummy oil press indicator does then you would run the wire to the gauge inside. | Cool, Thanks.. I ordered the Oil pressure gauge tonight....
Still debating on the oil temp gauge. I have the water temp gauge and volt.. so I am thinking if I should remove the volt gauge and install the oil temp...
I only have a 3 gauge pillar.. so if I get the oil temp I have to lose one of my other ones.. |
12-06-2006, 12:20 AM
#75 | | Registered User
| make sure you get the oil pressure sending unit. |
12-06-2006, 11:33 AM
#76 | | Registered User
| That's one thing I hate about new cars as they don't have enough gauges in the cluster. Even the wifes tC drives me insane as I don't know what the car is doing. xB, same thing. My 93 Daytona has more gauges stock and I can always pick up what's wrong with the car when a needle isn't where it's supposed to be. SO, I don't even check the cluster for anything anymore. Don't need to. I should get gauges too. |
12-08-2006, 03:28 PM
#77 | | Registered User
| Quote:
Originally Posted by hotbox05 make sure you get the oil pressure sending unit. | Yea.. The gauge I bought came with the sending unit..
I just recieved it in the mail today and it looks awesome.. Now the problem is how the hell do I install this thing... ?? |
12-13-2006, 06:18 AM
#78 | | Registered User
| Damn why isnt the ecu thorwing a code!!!! Those engines are leaning way out!!! Is this a common problem? Not sure I want to deal with this  . |
12-13-2006, 06:45 AM
#79 | | Registered User
| Quote:
and apparently there was excessive oil pump clearance meaning not enough oil pressure. | usually when you have an exhaust leak the o2 sensors read a lean condition, causing the pcm to richen the mix. actually causing a rich condition in the engine.  |
12-24-2006, 01:07 AM
#80 | | Registered User
| Quote:
Originally Posted by excitebox haha brad, you know its rough having the worlds only 1000whp xB with custom painted pistons and everything. it was only a matter of time before i grenaded it  | Wow, that was a good one.
Custom painted pistons.
Damn that is a funny one.
Sweet dude I just got a new set of cross drilled, custom painted pistons, from Sony!!!
Dude that is sweet, I'm gonna go with the black chrome, slotted pistons though... |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Scion xB Forum | Replies | Last Post | | Everything You Need To Know About The xB Engine | LuminicsBulbsDotCom | Scion xB Engine, Tech, & Performance | 11 | 01-20-2007 07:27 PM | | Engine Cover (echo)? | Padanky | Scion xB Engine, Tech, & Performance | 11 | 10-13-2006 10:32 PM | | blown engine | solodough | Scion xB Engine, Tech, & Performance | 4 | 07-30-2006 02:59 AM | | A better engine. | al74dart | Scion xB Engine, Tech, & Performance | 5 | 07-28-2006 03:48 PM | | Engine Dress Up Ideas | Misterflipper | Scion xB Engine, Tech, & Performance | 29 | 04-18-2006 09:38 AM | | | | All times are GMT -5. The time now is 12:21 AM. |
