Old 10-04-2008, 03:47 PM   #1
regulatin' on foolz......
Engine/VSC/TRAC/ABS/ "Light" Existing Threads
There have been many threads started in regards to Engine/VSC/TRAC/ABS/ Light's turning on due to whatever reasons. I have made it a bit easier for our CLUBxB members to search out their matters by having a compiled thread in regards to these matters.
These threads are not intended to necessarily pin point your situation or fix your problems, yet these threads may shed some light to your issues in regards to your dummy lights turning on.
I will add to this thread as I find other like threads. If you run into a thread that maybe helpful to this thread, please PM me with your findings so that it can be added.
This thread will be “Closed” for discussions, yet you can reply to the original intended thread.
VSC and TRAC OFF lights came on?
VSC/Trac Off/Check Engine Lights ON - OFF!
troubleshooting the VVTi system?
Check Engine Light + intake
Cold air intake probs.
VSC, Track off, Check Engine ... all from not putting on the gas cap
check engine light
Having Problems!
Check Engine Light Help
I NEED help...ASAP
Lights on Dash!!!!!
VSC Light, Trac Off, Engline Check Lights are all on
Help!! dash light-VSC,ABS,trac off,Brake
TSB Just saw this
SAKURA is offline
Page generated in 0.15765 seconds with 13 queries
