Old 11-16-2009, 01:53 PM   #1
NicholasM's Avatar
NicholasM is on a distinguished road
Engine Chirping???
Hello all,
I was trying to figure out what this is or if anyone else has had the same problem. When I start my car or it is idling I hear a noise coming from the engine that sounds either like a bird chirping or water gurgling. I'm not the best when it comes to the engine so I have no idea what it is. (That's an understatement) Does anyone have any idea what this noise is and what I could do to stop it?
Thanks, -Nick
NicholasM is offline   Reply With Quote
Old 11-16-2009, 01:58 PM   #2
Re: Engine Chirping???
May be a water pump or slipping belt?
Old 11-16-2009, 02:07 PM   #3
NicholasM's Avatar
Could be? ha. I'm going to take it in but I'd rather see if anyone knows before going to pay them just to tell me ha. I just got my oil changed and they didn't say anything about it so I would assume they would have if they thought they could get more money out of me. Thanks man
Old 11-16-2009, 02:15 PM   #4
Check this thread with video/sound, may be it's like what you got: I had a bad water pump & here is why - Scionlife.com
Old 11-16-2009, 02:35 PM   #5
NicholasM's Avatar
Yeah I already watched that one. It's nothing like that. Mine is more like a actual bird ha. I've heard it before in older cars but I don't have anything to record it to explain it more
YouTube - Toyota Yaris T-Sport Engine "Chirping"
This kind of sounds like the noise I'm talking about but mine is more high pitched or like a liquid gurgle sound. Could just be the sound quality on the video difference.
Old 11-16-2009, 02:45 PM   #6
VIP Member
enuf2spare35's Avatar
belt slipping or pulley needing replaced. I'll go with the slipping belt
Old 11-16-2009, 02:54 PM   #7
NicholasM's Avatar
Thanks enuf2spare35. I'll check it out
Old 11-16-2009, 04:15 PM   #8
scvscions's Avatar
yeah the belts are loose, happens all the time in xB's esp with the AC on, and at first startup
Old 11-18-2009, 11:58 PM   #9
Mobil 1 Man
O6er is on a distinguished road
If you are talking about that wierd vacuum leak/ wierd injector noise, it is normal on 1st gens. I thought it was a problem and so did a couple of people at my shop. Though after being next too a couple of other first gens (stock no mods) running; It sounds the same. Its normal. Apparently you can hear the injector on the driver cylinder for some reason.
O6er is offline   Reply With Quote
Old 11-19-2009, 09:26 AM   #10
djmesican's Avatar
djmesican is on a distinguished road
Send a message via AIM to djmesican Send a message via MSN to djmesican Send a message via Skype™ to djmesican
Mine has the same noise. Once i get going though it goes away. At idle it returns. It's not a belt squeeling either. I put new gates belts on and it still did it. Nice and tight. So i'm guessing 06er is right.
Have you messed with anything that caused coolant to leak out? That would be the only real way that you are hearing gurgling. Air pockets in the coolant system will make that sound.
djmesican is offline   Reply With Quote
Old 11-21-2009, 12:33 AM   #11
Mobil 1 Man
Air pockets!?!?!? HA; NOOOOO! I would know about this. I keep a constant one week check on EVERYTHING under my hood. It helps the fact I pull it in on slow days to train the newbs' at my shop on how to talk with customers; Though I have heard the horror stories of the water pump going bad; I have not had any coolant or oil burn off. And just to explain this.
Oil and coolant go hand in hand. Your system for coolant is based off so many quarts; and the best way to check is your overflow bottle. If the overflow is at the correct spot (around 1/4 from the top) Your coolant system is good. And your oil should be full. If your oil is full, so should your coolant. If one or the other starts going low your engine will run more hot than normal and both will burn off.
I have not had the horrendous sound of the water pump going bad that the videos post either. To get back to the begining; If your pump was bad the overflow would look dark and the level would most likely be low. The overflow bottle is where rust/corrosion likes to sit if something in the sytem is going bad.
If none of the above applies I would go back to what I orginally said; Its just the way the motor runs. I thought it was wierd at first to. Owninging nothing but older cars. The VVT engine runs much more differently and I have done my research and time inspecting to figure how they should run.
And trust me. Everyday I sit next to my car in the parking lot that little noise makes me paranoid as hell. Though knowing it is how they designed them gives me peice of mind.....My car is my baby lol. PM if you need anything else man.
Old 11-21-2009, 01:55 AM   #12
Nor*Cal Scion Apocalypse
awinter's Avatar
??? Huh? Dude, you make no sense. Didn't you ask what coilovers were in another post?
Originally Posted by 06er
Coilover
OK So I here this term thrown around and I was wondering if you can use these on all four corners?
Please stop representing yourself as a mechanic. Thanks!
If you have oil in your coolant, it could mean that the engine has a cracked block, head or blown head gasket.
If you are low on coolant - If the seal or bearings fail in the water pump it causes coolant to leak from the inspection port in the water pump. The water pump must be removed and replace with a new unit. You can also leak coolant from worn hoses or a hole in the radiator.
Also, oil doesn't just cook off. You lose oil due to:
Bad valve seals -If the seals fail, oil is allowed to flow down into the combustion chamber and is burned.
Worn valve guides- the excess gap allows the flow of oil down the valve stem into the combustion chamber to be burned.
Pressurized crankcase (oil pan) due to a clogged PCV valve or breather system - Carbon build-up is a by-product of an engine and can build up in the PCV system, clogging the breathing passages. This in turn pressurizes the oil pan and pushes oil up into the fuel delivery system, where it is fed into the engine and burned.
Blow-by from worn piston rings - When the rings wear out, the pressure from combustion reverses down into the oil pan, pressurizing it and forcing oil into the valve covers, through the breather system, back into the fuel delivery system, and into the engine to be burned
Old 11-21-2009, 09:17 PM   #13
Mobil 1 Man
Good points AW. Hats off ;seriously; i mean it. I am no master mechanic in any means. if any experiences I have had could help I am just throwing them out there. ^_^ thats all
Page generated in 0.23860 seconds with 13 queries
