04-06-2006, 02:19 AM
#21 | | Registered User
| one thing i want to make clear. THERE IS NO 02 SENSOR ON THE INTAKE.
its called a Mass Air Flow sensor ( MAF sensor ). thank you |
04-06-2006, 03:11 PM
#22 | | Registered User
| lol i htink its still smog legal i think their just trying to scare us if not just save your old oem one.. |
04-06-2006, 04:21 PM
#23 | | Undercover Moderator
| Quinn (EvilScionGrrl) had posted that she had hesitation issues with her Weapon*R intake....... she has an '06 as well, could be a similar problem. Quote: |
Originally Posted by xjeepguy I cant remember where I read it on this forum, but didn't someone install a CAI on their '06 and had some problems with hesitating? I have been afraid to buy one because of that. So yours works fine, so maybe I will look into it again. Is yours a 2006.5? I know they made some changes to the boxes for the 1\2 model year like steering wheel radio controls and such, but I was wondering if the newest ones may have the issues when adding the CAI. I really want one, but I want to make sure it will run OK. Thanks for the help. | |
04-06-2006, 04:50 PM
#24 | | Nor*Cal's Most Hated
| Quote: |
Originally Posted by the brave little toaster with the 06 scions. they use a carbon filter element in their air filter in the air box. to technically make it legal, and have a carb eo nubmer on an 06 the intake companies will have to come out with a carbon element air filter that uses the same cone shape. to my knowledge, no one has made it yet. | Yup, no carbon filter = no CARB exemption number for 06s on. |
04-07-2006, 12:54 AM
#25 | | Registered User
| anyone know if this its smog legal in other states besides cali? |
04-07-2006, 01:04 AM
#26 | | Registered User
| Careful when you install the intake on the 2006's all the "idiot" lights will come on and you'll need to reset your ecu. I have heard that the lights will continue to come on even after you reset it too... |
04-26-2006, 10:02 PM
#27 | | Registered User
| Most of you guys live in Cali so you know, Cali has the strictest vehicle inspection laws on the books. Thats why every little performance part has to be CARB certified (california air research board) no TARB (texas air research board). But I have heard there is some crap you can add to your gas to pass any smog test except the visual inspection of course. |
04-28-2006, 10:18 AM
#28 | | Registered User
| it's actually California Air Resouces Board for those that want to know.
the stuff you add only cleans your system and makes it burn a little hotter, it amounts to chevron tech clean,or lucas tune up in a bottle. if you really need to pass a tail pipe sniffer all you really have to do is use a propane tourch to heat the cat up while doing the test ( learned this from a smog certified mech, hehe my son). |
04-28-2006, 01:46 PM
#29 | | Registered User
| the aftermarket aem has never been legal. |
04-28-2006, 01:47 PM
#30 | | Registered User
| Quote: |
Originally Posted by CamoTrav Careful when you install the intake on the 2006's all the "idiot" lights will come on and you'll need to reset your ecu. I have heard that the lights will continue to come on even after you reset it too... | have not heard of one case of that |
04-28-2006, 05:42 PM
#31 | | Registered User
| Well, when we had smog checks here in Minnesota, there was only one way I could get my car to pass. All I did was put a bottle of rubbing alcohol in a half of a tank of gas. Passed everytime. Oh and it doesn't hurt to drive it like a raped ape to the testing station either. Also, if you have have a product called heet out there that works too. Heet is used to stop gas lines from freezing in the cold, also it takes the water out of the fuel lines. It's alcohol too!!! |
04-28-2006, 08:30 PM
#32 | | Registered User
| I installed the AEM cold air that was from my '04 on my RS 3.0 and I have had no issues with lights or anything else. Everything is working great. |
04-29-2006, 10:26 PM
#33 | | Registered User
| I too have a CAI from AEM Park 21-567 not 21-572, my car is being glassed right now, so I don't have a way to install it to test. There's really no reason why this shouldn't work. It's a straight pipe with a filter on the end and room for the MAF sensor... done...
I'll know more next week when I get the car back from KustomAuto and actually install the CAI. I'll post reports if the other guy has had no success...
-cz3ch- |
04-30-2006, 12:26 AM
#34 | | Registered User
| i am new to this.... but i have an 06 box with the 04-05 AEM i dont have any problems with CEL or needing to reset my ECU... i just hooked it up and runnin with it for about 2 months now and no problem |
04-30-2006, 01:11 AM
#35 | | Registered User
| the difference is the filter..thats it....aem is saying don't use it to cover them...but its not going to hurt the vehicle or anything.... |
04-30-2006, 01:30 AM
#36 | | Registered User
Here's a picture of mine with the the filter on the end... it's 21-567...I'm assuming yours looks the same... |
04-30-2006, 01:47 AM
#37 | | Registered User
| Quote: |
Originally Posted by azztinthebox the difference is the filter..thats it....aem is saying don't use it to cover them...but its not going to hurt the vehicle or anything.... | Do you actually have the 21-567 on yours? |
04-30-2006, 03:46 AM
#38 | | Registered User
| I am not sure what the number is on mine but it looks alot different then that. I have the CAI that was offered through toyota on the 04-05 that dips down then back up. |
04-30-2006, 04:14 AM
#39 | | Registered User
| Quote: |
Originally Posted by GrnMachine I am not sure what the number is on mine but it looks alot different then that. I have the CAI that was offered through toyota on the 04-05 that dips down then back up. | The one that curves down and around is not what we're talking about, that's the AEM/TRD intake you were mentioning...
This is the 21-567:
More to read about this intake, which should outperform the AEM/TRD design due to the lack of bends and turns.... http://www.scionlife.com/forums/viewtopic.php?t=55160 |
04-30-2006, 12:41 PM
#40 | | Registered User
| you know i just changed my air filter for the first time....since i have bought the car it has 6600 miles on it and i bought a wix filter from o'rielly's...i can tell a difference just by doing that..so if you don't have the money to buy an intake right away look in to doing that....i was amazed and could tell a big difference in the performance...it now pulls in low rpm's with 18s on it... |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 09:45 AM. |
