09-25-2009, 10:26 PM
#21 | | JDM is a way of Life . .
| Re: 2zz-ge head swap Quote:
Originally Posted by Wookie384 The 2ZZ-GE head will not fit onto the 1NZ-FE block, same thing with the 1ZZ head. The 5 speed from the Matrix only fits the 1ZZ, and the 6 speed from the 2ZZ only fits the 2ZZ. If you want to add a 6 speed trans. to a 1NZ-FE that is possible but finding the correct transmission is really hard! | there you go. |
09-25-2009, 10:28 PM
#22 | | Race car builder
| Re: 2zz-ge head swap You can swap in a 2ZZ-GE with trans but you will need access to custom mounts, possibly custom axels, and a very good electrician. I know someone who successfully swapped a 1ZZ into his Echo (which uses same/similar mounts).. |
09-25-2009, 10:32 PM
#23 | | JDM is a way of Life . .
| Re: 2zz-ge head swap so for this, engine swap is the best bet i think since head swap is not possible. |
09-29-2009, 08:34 PM
#24 | |
| Re: 2zz-ge head swap C160's are not hard to find. There are several on ebay right now...
Look into the 1nz-fxe from the prius. Bottom end + our top end should prove interesting gains on a standalone management system in theory. It's never been tried though... |
10-17-2009, 03:19 PM
#25 | | Registered User
| Re: 2zz-ge head swap So which 6 speed bolts up to our motor?C160 or C60? |
10-29-2009, 06:01 AM
#26 | | Race car builder
| Re: 2zz-ge head swap C160 from a JDM Toyota Levin fits our 1NZ-FE, you will need to use your bell housing from the stock 5 speed, along with corolla s axel seals. |
10-29-2009, 09:44 AM
#27 | | Registered User
| Re: 2zz-ge head swap So you have to swap internals from c160 to our trans?What years for the Coralla S axel seals?So our stock axels will work as well as stock mounts?Sorry for all the questions.I'm serious about this swap,I want to do it when income tax return comes in. |
10-29-2009, 10:33 AM
#28 | |
Originally Posted by Wookie384 You can swap in a 2ZZ-GE with trans but you will need access to custom mounts, possibly custom axels, and a very good electrician. I know someone who successfully swapped a 1ZZ into his Echo (which uses same/similar mounts).. | This guy?
Awesome setup. Any more info on it? Build pics anywhere? Quote:
Originally Posted by bBwannabe So you have to swap internals from c160 to our trans?What years for the Coralla S axel seals?So our stock axels will work as well as stock mounts?Sorry for all the questions.I'm serious about this swap,I want to do it when income tax return comes in. | I'm pretty sure you just have to swap the bell housing. I'm fairly certain the axles may bolt up, but I'm looking at this swap from a different angle than putting it on a 1nz. There was an article around a few years ago about installing a C160 onto a 1nz on scionlife.
11-05-2009, 12:44 AM
#29 | | Race car builder
I'm pretty sure you just have to swap the bell housing. I'm fairly certain the axles may bolt up, but I'm looking at this swap from a different angle than putting it on a 1nz. There was an article around a few years ago about installing a C160 onto a 1nz on scionlife. | Yes! That was Justin (AKA: Wraith on the forums), He Installed the C160 with the stock xB bell housing into his Echo. Note in that picture though the Echo has a 1ZZ-FE with supercharger, the new owner of the vehicle did that. When Justin had it there was a supercharged 1NZ-FE with a c160 installed. |
11-05-2009, 03:36 AM
#30 | |
| Re: 2zz-ge head swap ACTUALLY to my knowledge, the manual trans of the matrix DOES infact fit on the 1NZ. it is NOT the same tranny used on the manual xB, but it does share a simular bolting pattern and center shaft. it IS slightly longer than the xB's manual and requires a small bit of cutting to the subframe rail on the driver side of the engine bay. you'll need the gasket set for the Celica / Matrix setups for it to seal properly and the xB's axels to what i can remember, fit just fine on it. |
11-05-2009, 08:56 AM
#31 | | Supra dude here...
Originally Posted by Wookie384 Yes! That was Justin (AKA: Wraith on the forums), He Installed the C160 with the stock xB bell housing into his Echo. Note in that picture though the Echo has a 1ZZ-FE with supercharger, the new owner of the vehicle did that. When Justin had it there was a supercharged 1NZ-FE with a c160 installed. |
I forgot all about Justin. He used to have a 2.2L 5SGTE (3SGTE head, 5SFE block) 3rd Gen Camry
Currently he rocks a Sienna on some baller rims...  |
11-05-2009, 09:31 AM
#32 | | Registered User
| Re: 2zz-ge head swap So which is the easiest 6 speed swap?The one out of the levin? |
11-05-2009, 10:41 AM
#33 | |
| Re: 2zz-ge head swap That camry just screams legal in california.  |
11-16-2009, 06:14 PM
#34 | | Registered User
| Re: 2zz-ge head swap Hey guys, former xb owner, current 03 gts owner. Just to let you know, you will never get a 2zz head on a 1nz, and if you somehow did, you wouldn't have lift, which is the reason to get a 2zz, period. Would love to see a 2zz in an xb, it would be a reason to get my xb back. Good luck, I hope you get something done.
P.S. 2zz makes 180hp stock so PLEASE don't even think about a 1zz. Do it right get the vvtL-i. |
11-16-2009, 08:44 PM
#35 | | Supra dude here...
| Re: 2zz-ge head swap early 2zz's make 180, later ones were what, 165..? pretty crappy in my opinion.. |
11-18-2009, 11:21 AM
#36 | | Registered User
| Re: 2zz-ge head swap I'm almost positive that even the 05's had 180 hp, the late models decreased rev limiter didnt change rated hp, I don't think. I really don't care to argue your comment on how you value the motor. As this is an xb forum, and I had an xb, I can tell you the transition to the gts was a good one. The 2zz in the xb would be a great compromise for someone that can't have a car without a useful backseat. How practical, or even possible the swap is, is yet to be known. But size, reliability, and power wise, its miles ahead of any other possible swap and much more over a boosted/Frankenstein 1nz. |
11-18-2009, 03:25 PM
#37 | | Supra dude here...
| Re: 2zz-ge head swap no one's arguing with you, settle down cowboy..
I had forgotten about celica GT-S's and was referring to the Matrix and Corolla XRSs, which had 164hp, not sure what the Celica had. Hell, if you wanna get technical you can grab a 2ZZ out of an Elise and terrorize the streets... |
11-19-2009, 03:08 AM
#38 | | Registered User
| Re: 2zz-ge head swap Sorry if I sounded argumentative, I wasn't trying to be. I wasn't thinking of the corolla/matrix, them I wouldn't know about so your probably right. As far as the lotus transplant, only the ecu differs, and would bring extensive wiring problems. If not make it down right impossible, which is most likely. |
11-19-2009, 08:45 AM
#39 | | Supra dude here...
| Re: 2zz-ge head swap It's cool, haha, we both forgot the car the other was referring to..
If it were up to me, actually, I'd actually try to drop a 20v 4AGE in this here son'a *****..! |
11-20-2009, 09:03 AM
#40 | | Registered User
Originally Posted by RazoE no one's arguing with you, settle down cowboy..
I had forgotten about celica GT-S's and was referring to the Matrix and Corolla XRSs, which had 164hp, not sure what the Celica had. Hell, if you wanna get technical you can grab a 2ZZ out of an Elise and terrorize the streets... | If I found an Elise w a 2ZZ in it, I'd just drive the Elise  |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 08:57 AM. |
