Old 08-21-2009, 01:39 AM   #1
lets play beer pong!
synapse's Avatar
synapse is on a distinguished road
Send a message via AIM to synapse
wireing air suspention help
im doing a minitruck style set up and want to loose the switch box and do 4 switches 1 for the front 1 for the back and 1 for driver side and 1 for pass. side 4 switches total and im using a valve block now still wires the same as 8 seprate valves just need help figuring out the wiring so as not to get wires crossed
synapse is offline   Reply With Quote
Old 08-21-2009, 02:01 AM   #2
elusive_xb's Avatar
Re: wireing air suspention help
id give them a try.... ive known the owner for close to 15 years....
AVS / airbagparts.com
1489 NORTH THESTA ST
FRESNO,CA 93703
(559) 486-5444
(559) 486-5155 (FAX)
Old 08-21-2009, 02:05 AM   #3
synapse's Avatar
just need to know the wireing thats all i allready have the parts
Old 08-21-2009, 02:08 AM   #4
elusive_xb's Avatar
how many switches do u have right now? and what do they do?
does this help?
Old 08-21-2009, 02:15 AM   #5
synapse's Avatar
i curently have a 7switch boh but i am building a custom console in witch i am puting just 4 switches in and i dont want to mess up the wireing i want front back side side only im just wanting to jknow what the layout for the wiring is to do front back side side with the 4 switches
--------box*--------
Old 08-21-2009, 02:22 AM   #6
elusive_xb's Avatar
maybe eleminate the middle switch, connect the upper left and lower left to 1 switch, upper right and lower right to 1 switch, and leave the upper and lower middle switch how they are.... im no professional but thats how i would do it....
what brand is the switch box??
im sure you can google it and call them and get a diogram....
sorry if im not much help but thats what i would do....
Old 08-21-2009, 10:49 AM   #7
synapse's Avatar
the thing is im gonna have to hand wire everything due to my console layout
Old 08-25-2009, 07:03 PM   #8
www.ScionApocalypse.com
Just1n's Avatar
contact the air suspension.....randode@randode.com
Old 09-03-2009, 12:30 PM   #9
IloveSpeedbumps is on a distinguished road
I've never used a switchbox. So I can't say how to mod one. I used custom switches in my car, they are all hidden. I just ran a main power, and a main ground, then attached the switch to the power wire on the valve I wanted that switch ton control.
IloveSpeedbumps is offline   Reply With Quote
Old 09-05-2009, 03:38 PM   #10
ahughejazz24's Avatar
ahughejazz24 is on a distinguished road
I think you would be better off just controlling each bag independently. I mean, how hard would it be to push two switches at the same time to get the front, or the back, or the left or the right to go up??? Besides, since the rear is so light, it's gunna jump up faster than the front when you do side to side, and it would be impossible to adjust the psi in one bag if you wire up the switch box like you want to.
ahughejazz24 is offline   Reply With Quote
Old 09-05-2009, 03:43 PM   #11
synapse's Avatar
true but i do have almost 500 lbs of audio in the back
Time for Brake pads already?
Page generated in 0.34449 seconds with 13 queries
