Old 04-10-2008, 01:04 AM   #101
bB Squad
AirecK's Avatar
Re: wilwood rear disc conversion
so what the final price at???
and does it include everything needed for this swap....
Old 04-10-2008, 01:13 AM   #102
Hey Mr. "Yeah, I'm a baller since I own" Leadsleds,
Can you give some of your minions, like me, a chance to catch up first!?! Sheesh!
LOL!
Looks like everything is included w/ Mike's conversion. I can't wait! My whole refund is going to this!
Old 04-10-2008, 04:05 AM   #103
bB Squad
AirecK's Avatar
^hey you need to slow down mr. "Magazine feature in Syphon"...so i can catch up maybe one day i'll be able to park next to ya....lol!!
Old 04-10-2008, 12:04 PM   #104
ROFLMAO!!!!!!!
I was just filler material. Yeah, that's it! Until Carter got things in place.
Old 04-10-2008, 12:05 PM   #105
Rcurry23's Avatar
Rcurry23 is on a distinguished road
Send a message via AIM to Rcurry23
OK, the conversion will include:
All mounting hardware (bolts, washers, nuts, etc..)
CNC Machined Caliper Brackets
E-Brake Cable End Mounts
Cable Clevis’
Clevis Pins
Cable Stops
New Toyota Brake Rotors
New/ Remanufactured Loaded Toyota Brake Calipers (modified)
New E-brake Cable Mounts at Caliper (not the same as the stock one)
Rotor masks (so the inside and outside of the un-used portion of the rotor can be painted before installing it)
Brake Adapters for Stainless Line at the Chassis
Chassis Adapter Clips
Banjo Adapters for the Stainless Line at the Caliper
Stainless Brake Lines
The stock xA/xB rear hubs have to be modified for this conversion. So I am going to offer two different kits. One without hubs, so the DIY’er can mod their own (which I will post on here what has to be done and there will be instructions included with the installation instructions on how to mod them)
The second kit will include already modified/exchanged hubs, with a core charge. Then the core charge will be credited when I receive the unmodified customers hubs back and they have been tested. This kit will be a little more, but you’ll get a portion of it back with the returned hubs.
Note:
I had to have these laser cut. The new calipers don’t come with them, and Toyotas warehouse in America and Japan no longer carry them. The few I did end up buying from salvage yards were badly rusted!! So I just ended up making some new ones.
I think I’ve included everything about the conversion, except the price. Because I am not a supporting sponsor yet, please PM me for more information. I wasn't able to get below the $800 goal, but I tried. I just couldn't make it happen. Comparing it to another conversion on the market that runs $900.00, that utilizes the brake shoes inside the rotor hat for the e-brake (which is why I wanted to do this, to get away from the shoe set-up), and using used salvaged parts for their conversion. I think this will be vary competitive with all new parts, and a shoeless design!
Thanks,
Mike / Alliance AutoSports, LLC.
Rcurry23 is offline   Reply With Quote
Old 04-10-2008, 07:07 PM   #106
ricksxbox's Avatar
ricksxbox is on a distinguished road
mike you kick arse. i will def be getting this setup maybe we can do it at the next install party. by the way peeps check out mikes hub spacer top notch and a great price
ricksxbox is offline   Reply With Quote
Old 04-11-2008, 09:03 AM   #107
Rcurry23's Avatar
After someone mentioned something to me and speaking with a few people about this. I do not think I will offer this second kit the way I was planning to. I will modify anyones hubs who purchases a kit for a fee. The reason behind this decision, and it makes sense, is. Some guys run camber which has put a load on the bearings in the hub. Lets say I get some ones hubs that have 55,000 miles on them, and they were used on a cambered ride. So I modify them and send them out with the next kit. And 2500 miles down the road a hub fails. I would be the blame for selling a bad hub, and I don't want that.
So rather than an exchange I will offer the un-modified conversion (where you would modify the hubs) and a modified version that would include new modified hubs! This would eliminate anyone getting someone elses abused hubs. And then as stated above, if you want me to modify your hubs, I can do that for a fee. I would only need the hubs for one day, so they would have a fast turn around if any of you decided to go that route. Sorry for the change-up, I just want to do this right for everyone.
Thanks,
Old 04-11-2008, 10:38 AM   #108
Go Mike! Go Mike! Go Mike!
Old 04-18-2008, 12:05 AM   #109
Rcurry23's Avatar
I talked to Wilwood today about my conversion and questioned them about me using a 3/8" caliper bracket rather than the 1/2" one I prototyped with. They said that they use 1/4" and 3/8" for their conversion, so they saw no problems with me using it for my kit, so I have decided to go with 3/8" caliper brackets. This will allow the guys with the OTG camber kit to use the conversion kit as well. Some or most of the camber guys use a OTG (3/8"-10mm) spacer with their camber kits, this caliper bracket will replace that 10mm spacer/shim. Just wanted to let those of you know, who asked about it working with the camber kits earlier in this post.
I also thought I'd post a couple more pictures, of the before and after shots.
The xB in out of the rain jacked up and ready to be converted!
And after
[IMG][/IMG]
Old 04-18-2008, 01:25 AM   #110
Black on Black with Black
xBink's Avatar
xBink is on a distinguished road
Wow and wow! I wonder if I can justify this to the wife... and you're thinking arond $900 for the kit?
xBink is offline   Reply With Quote
Old 04-18-2008, 03:27 AM   #111
filter524's Avatar
filter524 is on a distinguished road
Send a message via AIM to filter524
that looks hot!!! def watching this.....
filter524 is offline   Reply With Quote
Old 04-18-2008, 06:44 AM   #112
Rcurry23's Avatar
PM me for details!
Old 05-23-2008, 08:37 AM   #113
Rcurry23's Avatar
Well, all the machined parts are done and all the parts that had to be ordered and modified are done. Now I'm just waiting on the machined parts to come back from plating and anodizing. Here are a few pictures of some of the anodized parts.
Should have the plated parts back real soon. Then I can start packing up the conversions and send them to their new owners!!!
Old 05-23-2008, 11:40 AM   #114
Looks like a very well engineered kit! Black anodize is a nice touch.
Old 06-15-2008, 09:49 PM   #115
EvoluScion's Avatar
EvoluScion is on a distinguished road
Howz all the happy customers so far? Is everything going smooth? Is a version 2 in the works? Im looking for a kit that can run with 13s-15s...
Peace
EvoluScion is offline   Reply With Quote
Old 06-23-2008, 02:05 AM   #116
crxgames's Avatar
Peace
x2
10 characters.
Old 07-16-2008, 10:20 AM   #117
quickyxb is on a distinguished road
if you dont plan on racing the box, ww's are good for show! i herd their calipers tend to flex under extreme pressure! not hating, just saying i read this on ht
quickyxb is offline   Reply With Quote
Old 07-17-2008, 07:00 AM   #118
phatbb's Avatar
phatbb is on a distinguished road
wow, me thinks, you should work for willwood or some xb tuning house! haHA very impressive kit yo!~
phatbb is offline   Reply With Quote
Old 07-25-2008, 04:25 PM   #119
Rcurry23's Avatar
Just for the record, this is not a Wilwood caliper I used in the kit. These are Toyota calipers. It just got off the subject towards the begining of this thread.
The kits are going good, and I'm working on the third run right now. I just wish more people would post pictures of them installed. I've only had one post pictures on SL , on his xA.
This is what he had to say about it: "This kit is just craziness, thing stops on a dime, best investment for my car!!! I highly recommend this for anyone, especially if you are autocrossing!!
They look and work awesome Mike, thanks so much, again and again!"
Heres a picture of the kit on an xA.
Old 07-28-2008, 09:50 PM   #120
no1dad1983's Avatar
that looks crazy good
no1dad1983 is offline   Reply With Quote
Time for Brake pads already?
Page generated in 0.30905 seconds with 12 queries
