03-14-2008, 11:48 PM
#81 | | 06.5 TCM
| Re: wilwood rear disc conversion Great work!!! Sure there will be more stuff to dial in, but where you got allready deserves respect  |
03-16-2008, 01:36 PM
#82 | | Registered User
| Re: wilwood rear disc conversion Looking good! I cant wait to see it done. I like the fact that it fits with the Stock 15". |
03-16-2008, 04:47 PM
#83 | | Registered User
| Re: wilwood rear disc conversion Well, I have put about 400 miles on it the last two days, and all I can say is WOW! I love it! I have tried to lock them up with no luck, and e-brake works great. Very pleased so far. I did run to about 50mph and slam the brake. The ABS seams to be working fine and no ABS light! I drove about 150 miles yesterday in the rain, again with no lockup issues. So I think everything will be a go on the kits in the next couple weeks.
03-16-2008, 05:40 PM
#84 | | bBsquad reppin
| Re: wilwood rear disc conversion WOW man this is so awsome. I so would love to buy one of these setups. but I need to know if camber would work on this setup cause I need the camber for my wheels. also do you know of any other ways to make a 5 lug conversion on our cars cause I have been looking into it and thought you might have some info I could use. if you want pm me please I am in need of this 5 lug conversion bad  |
03-16-2008, 05:51 PM
#85 | |
| Re: wilwood rear disc conversion Glad to hear that you will be making a kit. Any idea how much it will run? Wouldn't mind running one and I'm close enough I could always drive down and pick it up. |
03-17-2008, 08:30 PM
#86 | | Registered User
| Re: wilwood rear disc conversion Mike is the Don, and one of the few who has the cojones to ship to the UK!!! I am well up for this when he puts up a price..I hate the thought of drums let alone have to live with them.... |
03-17-2008, 09:09 PM
#87 | | regulatin' on foolz......
| Re: wilwood rear disc conversion hummm . . . . . pink wilwood . . . . .  |
03-19-2008, 06:07 AM
#88 | | bB Squad
| Re: wilwood rear disc conversion nice its done..now we wait for pricing...
and yeah on that camber issue....we needs to know!! |
03-19-2008, 09:15 AM
#89 | | Registered User
| Re: wilwood rear disc conversion I'm not 100% on the camber issues. No one around here runs camber on their xB. The caliper bracket mount is 1/2" or 12.7mm thick, so I don't know if stacking the camber plate with the caliper bracket mount will work. |
03-19-2008, 09:42 AM
#90 | | Nothing clever to say
| Re: wilwood rear disc conversion Wow, lot,s of time and effort put into this.Cant wait to hear your final results and release date. |
03-19-2008, 04:44 PM
#91 | | bBsquad reppin
| Re: wilwood rear disc conversion Quote:
Originally Posted by Rcurry23 I'm not 100% on the camber issues. No one around here runs camber on their xB. The caliper bracket mount is 1/2" or 12.7mm thick, so I don't know if stacking the camber plate with the caliper bracket mount will work. | ah man 12.7 mm thats it. it will work it sounds like it. I run a -3 with a 10mm shim and I sit perfect. 2.7mm wont make that much of a difference. I can just get the flat part of my camber plat milled off 2.7mm.  |
03-19-2008, 04:47 PM
#92 | |
| Re: wilwood rear disc conversion I seriously hope you get these produced. More I think about it the more I want it :P |
03-20-2008, 01:00 AM
#93 | | Nor*Cal's Most Hated
| Re: wilwood rear disc conversion Wow, can't wait to hear when this is available! Hmm, maybe I should wait on rebuilding my whole rear axle. WAIT, I can't go another day w/o driving my box! Let me know when its ready to ship! |
03-27-2008, 10:02 PM
#94 | | Registered User
| Re: wilwood rear disc conversion I am waiting on a couple more items to get quoted then a final cost will be determined.
Thanks again,
Mike |
04-04-2008, 02:46 PM
#95 | | Registered User
| Re: wilwood rear disc conversion Mike just wanted to let you know I installed the 15mm spacers on my bB tiday. They fit a treat and make a big difference to the look. I took a punt getting them because I thought the hub might be slightly different but all good...worth knowing because it should mean the brake kit will be all good too!!!! cheers my man |
04-04-2008, 07:20 PM
#96 | |
| Re: wilwood rear disc conversion thats sick! l cant wait to hear how much itll cost im most definately interested |
04-04-2008, 07:29 PM
#97 | | Registered User
| Re: wilwood rear disc conversion I now have all the quotes in and it looks like it will be under $800, but that has yet to be determined. Should have the first run of kits ready in a couple weeks. |
04-05-2008, 11:32 PM
#98 | | regulatin' on foolz......
| Re: wilwood rear disc conversion great work mike, hats off! once you get everything settled, 5 lug conversion is a must!
gluck! |
04-07-2008, 09:47 PM
#99 | | Registered User
Originally Posted by SAKURA great work mike, hats off! once you get everything settled, 5 lug conversion is a must!
gluck! | Thats next! At least I hope it will be. |
04-09-2008, 11:45 PM
#100 | | Registered User
| Re: wilwood rear disc conversion Ok, this install and testing is officially done. I do have to replace the brake lines still, but that is minor. The kit has done what I wanted it to, so its time to move on to the next project. For those that are interested, please PM me for more information, as I am about to start running the parts on the machining centers. Thanks for following along and being so patient. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 08:22 PM. |
