10-17-2007, 02:30 PM
#41 | | Registered User
| Re: wilwood rear disc conversion I am very interested in this thread. I want a rear disc conversion bad. what do you think this would cost? there is a guy that has that Willwood setup on an xa around my way. |
10-18-2007, 12:50 PM
#42 | | Registered User
| Re: wilwood rear disc conversion |
10-18-2007, 01:07 PM
#43 | | Al Choholic
10-19-2007, 01:01 PM
#44 | | Registered User
| Re: wilwood rear disc conversion Looks good keep us posted! |
10-20-2007, 02:26 PM
#45 | | Registered User
10-20-2007, 02:59 PM
#46 | | It's a lifestyle.
| Re: wilwood rear disc conversion That looks nice, keep it up! Can't wait to hear how it works when you get it on your ride. |
#47 | | Al Choholic
| Re: wilwood rear disc conversion nice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!! |
10-21-2007, 11:19 PM
#48 | | Registered User
| Re: wilwood rear disc conversion Quote: |
anyhow , i dont like the bbk like wilwood and endless cuz i would HAVE to run 17+ rims on my xb to clear those huge calipers. the toyota corrola rear disk was looking good cuz i can order some cross drilled rotors to match the front and still fit 15's.
| I tried a stock xB steelie tonight and there are no clearance issues with this set-up. So it looks like you could run 15"-? wheels. Heres a couple pictures just to show it mounted up. It has about 3/8" to 1/2" betwen the caliper and the wheel. So if you use your stockers in the winter, it won't be a problem!  |
10-21-2007, 11:32 PM
#49 | | RS4 #303
| Re: wilwood rear disc conversion looking way cool cant wait to see the finished kit.
now that you have it mocked up close to final fit what is the measured difference between the mounting surface on rear member to mounting surface on rotor compared to the difference from stock member to drum mounting surface
by the way your doing a great job thank you |
10-21-2007, 11:36 PM
#50 | | Registered User
| Re: wilwood rear disc conversion Sorry Steve, what are you wanting to know? I guess you lost me in that post. I'll be more than happy to answer, just need to figure out what it is your talking about. The caliper bracket moved the hub out 5/8". just like the OTG or others spacers would. |
10-21-2007, 11:46 PM
#51 | | RS4 #303
| Re: wilwood rear disc conversion i got that, but what is the difference from back of hub to wheel mounting surface on new set compared to stock hub to drum wheel mounting surface
since this is from a diff set up the measurement might not be the same.
ie; if you used a caliper tool and measured hub to front on both what is the diff not counting the brake caliber bracket. hope this helps |
10-22-2007, 01:02 AM
#52 | | Registered User
10-22-2007, 11:26 PM
#53 | | Registered User
| Re: wilwood rear disc conversion Steve, I calipered from the backside of the hub to the wheel surface and the new set-up with the disc is .100 narrower than the drum. Not a big difference at all. |
10-22-2007, 11:34 PM
#54 | | Registered User
| Re: wilwood rear disc conversion i odnt know if i missed it i someone has asked already but will this still work with the stock E-brake??? i would so wanna buy a set that does! |
10-23-2007, 12:21 AM
#55 | | Registered User
| Re: wilwood rear disc conversion after installing the wilwood big brake kit on my friends xa, i think i will stay stock, but I would love to have a set of these rear disc conversion.. |
10-23-2007, 11:44 AM
#56 | | Registered User
| Re: wilwood rear disc conversion Staticlink05: Thats the plan. I'm waiting on a stock E-Brake cable from the local Toyota dealer now. I'm trying to make this as a complete replacement Drum to Disc conversion.
Well, I've ran into a snag! After mounting this up so many times, standing back looking at it, and taking pictures of the progress. I was yet to notice that the bleeder valve was below the brake line! That won't work! I liked the position of this set-up, but I'm gonna have to make some new brackets to rotate it up some more. If I leave it where it is and flip the caliper over, you would have to drill two holes in the hub flange on the swingarm, for the E-brake cable to go through. As I think most people could do that. They shouldn't have to. So they are re-drawn, now I just have to start making them. On a good note, the brakelines are here, and the E-brake cable, so..... Just wanted to keep you updated!
10-23-2007, 01:09 PM
#57 | | RS4 #303
10-24-2007, 03:39 AM
#58 | | Undercover Moderator
| Re: wilwood rear disc conversion Things are looking very interesting, Mike.  |
11-04-2007, 12:58 PM
#59 | | RS4 #303
| Re: wilwood rear disc conversion Mike
how about an update how did it come out. |
11-04-2007, 01:12 PM
#60 | | Doin it like only EZ can
Join Date: Oct 2007 Location: Custom county (sacramento)
Originally Posted by sdsnybny Mike
how about an update how did it come out. | 2X on that. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 09:53 AM. |
