Old 06-13-2006, 11:46 AM   #1
xfLipm0d3x's Avatar
xfLipm0d3x is on a distinguished road
Send a message via AIM to xfLipm0d3x
Will camber solve this problem?!?
First off, I was unsure whether I should've posted this under wheels&tires or under here.. but I think this would be the right place to put it.. anyways.. here's the situation.. I'm running Sportmax 962s Staggered.. 18x7.5 in the front & 18x8.5 in the rear w/ all four tires wrapped in 215/35/18 tires.. and I also have OTG's Rear Spacer Shims.. and recently added a Progress Lowering Springs with the 2" all the way around.. and the problem is.. when I have 2 people in the back weighing from 200-300lbs.. when i hit potholes.. i get this big CLANK noise in the rear.. it sounds as if i have like my spare tire loose and its bouncing up and down.. well anyways.. I got out of the car and checked out what it was and.. it turns out to be that the body of the car in the rear.. is slamming onto the tire every time I hit a bump/pothole.. and you can see on the tire.. that the thread on the side is peeling off.. it's like little pieces of thread.. well anyways.. i was just wondering if I added some camber on the rear section if it would solve this problem.. Thanks a bunch guys!
xfLipm0d3x is offline   Reply With Quote
Old 06-13-2006, 11:50 AM   #2
Banned
MussBus is on a distinguished road
Send a message via AIM to MussBus
I am not a master of knowledge But I believe that adding the camber would'nt help your situation. Might need to look into some different suspension. That's my two cents but I hope that another member is able to help you out alot more.
MussBus is offline   Reply With Quote
Old 06-13-2006, 12:00 PM   #3
xfLipm0d3x's Avatar
ya.. i was thinking about that too.. but that 2" drop looks SOOO CLEAN.. if not i'll probably change my springs to something that'll give me a 1-1.5" drop..
Old 06-13-2006, 12:04 PM   #4
Banned
Let me know if you do and I might be interested in the springs!
Old 06-13-2006, 12:05 PM   #5
xfLipm0d3x's Avatar
alright.. .. i shall let u know.. and i only put about 20 miles on 'em bcuz i turned around and took my civic out ever since I started rubbing..
Old 06-13-2006, 12:06 PM   #6
the brave little toaster's Avatar
the brave little toaster is on a distinguished road
Send a message via AIM to the brave little toaster
sidewall tread or , normal tread. if its sidewall its rubbing on inner fender and camber would work. if not then ur drop is too low for those wheels
the brave little toaster is offline   Reply With Quote
Old 06-13-2006, 12:07 PM   #7
Shoot a PM to Squirrel. He was running the exact set-up on his box. Check with Matty as well, they should be able to point you in the right direction.
Old 06-13-2006, 12:08 PM   #8
xfLipm0d3x's Avatar
sidewall thread.. .. yay! camber! i wanted to get some OTG's Rear Camber Shims
Old 06-13-2006, 12:09 PM   #9
xfLipm0d3x's Avatar
I haven't seen Squirrel around in a while and Ill go ahead and send them a PM.. thanks Dion.
Old 06-13-2006, 12:25 PM   #10
BigWill184's Avatar
BigWill184 is on a distinguished road
Send a message via AIM to BigWill184 Send a message via Yahoo to BigWill184
i know that matty guy has similar rims and he is runing a camber in the back and I believe he also has his rear fenders rolled....
BigWill184 is offline   Reply With Quote
Old 06-13-2006, 12:35 PM   #11
fender rolling is also needed. our team member is running the same model and size wheels. he also did some gridning too.
Old 06-13-2006, 12:36 PM   #12
actually i think his are 8.5 and 9.5
Old 06-13-2006, 12:36 PM   #13
xfLipm0d3x's Avatar
The yellow arrow indicates where it is rubbing and where the thread wear occurs..
Thanks again guys!
Old 06-13-2006, 12:38 PM   #14
oh yea. same problem he had. but he drove all the way to tracy =). we took out a bunch of stuff from his car to lighten it up lets just say for the ride home =)
Old 06-13-2006, 12:50 PM   #15
I have 8.5s also, but Matty was running 9.5s. You can either run camber or roll the rear fender lips. You jjust have to be careful how much you put in back if you chhose not to roll the fenders. I'm not running the OTG rear spacers either, just camber plates.
Old 06-13-2006, 12:55 PM   #16
xfLipm0d3x's Avatar
being the newbie that i am.. h0w w0uld u exactly.. "roll the fenders" .. and what would be a decent amount of camber without doing TOO much..
Old 06-13-2006, 01:01 PM   #17
I have a fender rolling tool that folds the fender lip up and out of the way. e dgrees of negative is a pretty condervative setting for everyday driving while still having better handling, response, and a decent amount of tire wear.
Old 06-13-2006, 01:03 PM   #18
BOXlover11's Avatar
BOXlover11 is on a distinguished road
Send a message via Yahoo to BOXlover11
Why not just ditch the spacers. That would save you time and money, and I'm sure you could find a buyer on here real quick for those bad boys. That 10mm is where you are getting your rub from. It would still have the staggered look with the larger lip in the rear. JMo though, cuz i dont dig the -5 camber deal
BOXlover11 is offline   Reply With Quote
Old 06-13-2006, 01:11 PM   #19
xfLipm0d3x's Avatar
could you point me a direction on where to get a decent camber? or would I run to OTG for their -3 degree camber? I LOVE the look of camber
Old 06-13-2006, 01:21 PM   #20
Dew
Egistered Ruser
Dew's Avatar
Dew is on a distinguished road
Send a message via Yahoo to Dew
yeah like me, lemme know if you decide to ditch the OTGs
Dew is offline   Reply With Quote
Installed -5 degree camber today.... yellow_sub Scion xB Suspension, Chassis & Brakes 50 06-22-2006 08:47 AM
PA: One Ton Garage -3° camber shims excitebox Scion xB Classifieds 11 04-12-2006 02:03 PM
ive got a problem...help!!!! smalltownscionman General Scion xB Discussion 2 04-03-2006 12:17 PM
More Camber and new mounts for air ride! Dajap Scion xB Suspension, Chassis & Brakes 49 02-12-2006 03:37 PM
Remote Entry Problem hubbard Scion xB Audio, Video, & Security 14 02-03-2006 02:16 AM
Body Drop on 20's
Page generated in 0.28180 seconds with 14 queries
