Old 04-25-2006, 07:19 PM   #1
FatalJRA is on a distinguished road
What PSI should I use on my tires?
I just got 17" wheels and tires. The brand tires are Kumo and the maximum PSI is 40. My friend who has a shop set them for 36 PSI. Is that too much. I noticed the stock 15" wheels had a posted recommened 29 PSI. Could someone tell me what they recommend. Thanks.
FatalJRA is offline   Reply With Quote
Old 04-25-2006, 08:51 PM   #2
superjeer's Avatar
superjeer is on a distinguished road
30 or 32 should do it. Higher will hurt, but will protect your rim more from potholes
superjeer is offline   Reply With Quote
Old 04-26-2006, 01:13 AM   #3
Who am I to say this?
boxd_up_2's Avatar
Location: I have no Idea, but I bet I could Google it...
boxd_up_2 is on a distinguished road
30-35 should be fine. The Max PSI rating on the side wall of the tire is recommended for a full load at each corner. For example, if your tire has a max load rating of 1000 lbs, that means that with all 4 tires there is a max load rating of 1000 lbs at each corner, so 4000 lbs total. Being that the box only weighs about 1800 to 2000 lbs (can't remember) each tire will never even see close to its max weight capacity therefore you wouldn't need to inflate them to the Max PSI recommended. I would however use a little more pressure in the front than in the rear (engine weight).
boxd_up_2 is offline   Reply With Quote
Old 04-26-2006, 07:36 AM   #4
EticketXb's Avatar
EticketXb is on a distinguished road
Fatal - as a X-tire guy (10yrs in the biz) I can recommed anywhere between 30-36psi, its really up to you and what feels comfortable. As tires heat up they can gain as much as 6psi so running at 4psi below the max is the most I'd recommed. And if you run your tires in the lower PSI range be aware that if you overload them you could become victim to the Ford Explorer Rollover effect.....(Little tireguy J/K...the recall about 5 yrs back.....Not a tire issue..a underinflation issue) Try some different PSI's untill you find what you like....but always remeber to go off COLD TIRE PSI........
EticketXb is offline   Reply With Quote
Old 04-26-2006, 07:45 AM   #5
hotbox05's Avatar
i'd say 32-34.
Help deciding on wheels and tires for RS3 SoonerFever Scion xB Wheels & Tires 28 07-12-2006 04:34 PM
Vibrations (is it the tires?) Scion-Doll Scion xB Wheels & Tires 23 04-26-2006 07:27 AM
CA: FS: WORK Eurolines 18" Rims Wheels & Tires xB xA tC hahajoey Scion xB Classifieds 8 03-22-2006 05:08 PM
OH:Rims and Tires F/S floodgate Scion xB Classifieds 0 03-13-2006 10:01 PM
Does anyone know where i can get a good deal on tires smalltownscionman General Scion xB Discussion 6 01-03-2006 02:28 AM
Time for Brake pads already?
Page generated in 0.15069 seconds with 14 queries
